Thanks Sam. Been away a couple of days, so only just had chance to do this. I enabled debug mode for the sound component. Started party mode, then hit next to start a new track and captured this:
22:49:24 T:3024269312 DEBUG: LIRC: Update - NEW at 213248972:197 0 KEY_NEXT linux-input-layer (KEY_NEXT)
22:49:24 T:3024269312 DEBUG: OnKey: sleep (0xdf) pressed, action is SkipNext
22:49:24 T:3024269312 DEBUG: DoWork - Saving file state for audio item musicdb://songs/4822.mp3
22:49:25 T:3024269312 DEBUG: Loading settings for musicdb://songs/2798.mp3
22:49:25 T:3024269312 DEBUG: CPlayerCoreFactory::GetPlayers(musicdb://songs/2798.mp3)
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
22:49:25 T:3024269312 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
22:49:25 T:3024269312 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
22:49:25 T:3024269312 DEBUG: CPlayerCoreFactory::GetPlayers: adding audiodefaultplayer (3)
22:49:25 T:3024269312 DEBUG: CPlayerCoreFactory::GetPlayers: for video=0, audio=1
22:49:25 T:3024269312 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: PAPlayer (3)
22:49:25 T:3024269312 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
22:49:25 T:3024269312 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
22:49:25 T:3024269312 DEBUG: CPlayerCoreFactory::GetPlayers: added 2 players
22:49:25 T:3024269312 DEBUG: CSMBFile::Close closing fd 10001
22:49:25 T:3024262176 DEBUG: CActiveAE::DiscardStream - audio stream deleted
22:49:25 T:3024262176 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
22:49:25 T:3024269312 INFO: CActiveAEResamplePi::~CActiveAEResamplePi
22:49:25 T:3024269312 DEBUG: CActiveAEResamplePi:DeInit
22:49:25 T:3024269312 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.audio_mixer handle 0x5689a68
22:49:25 T:2685400096 DEBUG: OnPlayBackStopped: play state was 2, starting 1
22:49:25 T:2685400096 DEBUG: Thread PAPlayer 2685400096 terminating
22:49:25 T:3024262176 INFO: CActiveAEResamplePi::~CActiveAEResamplePi
22:49:25 T:3024262176 DEBUG: CActiveAEResamplePi:DeInit
22:49:25 T:3024262176 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.audio_mixer handle 0xa0f195e8
22:49:25 T:3024269312 DEBUG: CSMBFile::Open - opened mp3/Levellers/Letters From The Underground/02-Death Loves Youth.mp3, fd =10001
22:49:25 T:3024269312 DEBUG: Open - probing detected format [mp3]
22:49:25 T:3024269312 DEBUG: Open - setting usetoc to 0 for accurate VBR MP3 seek
22:49:25 T:3024269312 DEBUG: Open - avformat_find_stream_info starting
22:49:25 T:3024269312 DEBUG: ffmpeg[B442B000]: [mp3] Estimating duration from bitrate, this may be inaccurate
22:49:25 T:3024269312 DEBUG: Open - av_find_stream_info finished
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: Input #0, mp3, from 'musicdb://songs/2798.mp3':
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: Metadata:
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: title : Death Loves Youth
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: album : Letters From The Underground
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: encoded_by : Encoded with FreeRIP
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: genre : Folk Rock
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: artist : Levellers
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: album_artist : Levellers
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: TLEN : 231640
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: track : 2/11
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: date : 2008
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: Duration: 00:03:51.69, start: 0.000000, bitrate: 192 kb/s
22:49:25 T:3024269312 INFO: ffmpeg[B442B000]: Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 192 kb/s
22:49:25 T:3024269312 DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0
22:49:25 T:3024269312 DEBUG: FactoryCodec - Audio: passthrough - Opening
22:49:25 T:3024269312 DEBUG: FactoryCodec - Audio: passthrough - Failed
22:49:25 T:3024269312 DEBUG: FactoryCodec - Audio: FFmpeg - Opening
22:49:25 T:3024269312 DEBUG: FactoryCodec - Audio: FFmpeg - Opened
22:49:26 T:3024269312 DEBUG: CSMBFile::Open - opened mp3/Levellers/Letters From The Underground/02-Death Loves Youth.mp3, fd =10000
22:49:26 T:3024269312 DEBUG: unrecognized ID3 frame detected: MCDI
22:49:26 T:3024269312 DEBUG: unrecognized ID3 frame detected: TLEN
22:49:26 T:3024269312 DEBUG: CSMBFile::Close closing fd 10000
22:49:26 T:3024269312 DEBUG: SeekTime - seek ended up on time 0
22:49:26 T:3024269312 DEBUG: Previous line repeats 1 times.
22:49:26 T:3024269312 INFO: CActiveAEResamplePi::CActiveAEResamplePi
22:49:26 T:3024269312 INFO: CActiveAEResamplePi::Init remap:(nil) chan:2->2 rate:44100->44100 format:6->3 bits:16->32 dithe r:0->0 norm:0 upmix:0
22:49:26 T:3024269312 INFO: CActiveAEResamplePi::Init 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
22:49:26 T:3024269312 INFO: CActiveAEResamplePi::Init 0.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00
22:49:26 T:3024269312 INFO: CActiveAEResamplePi::Init 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
22:49:26 T:3024269312 INFO: Previous line repeats 5 times.
22:49:26 T:3024269312 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_mixer input port 232 output port 231 m_handle 0x5689a68
22:49:26 T:3024269312 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_mixer) - port(232), nBufferCo untMin(1), nBufferCountActual(1), nBufferSize(524288), nBufferAlignmen(32)
22:49:26 T:3024269312 DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.audio_mixer) - port(231), nBufferC ountMin(1), nBufferCountActual(1), nBufferSize(524288) nBufferAlignmen(32)
22:49:26 T:3024269312 DEBUG: ffmpeg[B442B000]: [mp3] Could not update timestamps for skipped samples.
22:49:27 T:3024269312 INFO: AudioDecoder: File is queued
22:49:27 T:3024262176 INFO: CActiveAEResamplePi::CActiveAEResamplePi
22:49:27 T:3024262176 INFO: CActiveAEResamplePi::Init remap:(nil) chan:2->6 rate:44100->44100 format:3->3 bits:32->32 dithe r:0->0 norm:1 upmix:1
22:49:27 T:3024262176 INFO: CActiveAEResamplePi::Init 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
22:49:27 T:3024262176 INFO: CActiveAEResamplePi::Init 0.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00
22:49:27 T:3024262176 INFO: CActiveAEResamplePi::Init 0.50 0.50 0.00 0.00 0.00 0.00 0.00 0.00
22:49:27 T:3024262176 INFO: Previous line repeats 1 times.
22:49:27 T:3024269312 DEBUG: AudioDecoder::GetReplayGain - Final Replaygain applied: 1.000000, Track/Album Gain 89.000000, P eak 0.000000
22:49:27 T:3024262176 INFO: CActiveAEResamplePi::Init 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
22:49:27 T:3024262176 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_mixer input port 232 output port 231 m_handle 0xa0f195e8
22:49:27 T:3024262176 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_mixer) - port(232), nBufferCo untMin(1), nBufferCountActual(1), nBufferSize(524288), nBufferAlignmen(32)
22:49:27 T:3024262176 DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.audio_mixer) - port(231), nBufferC ountMin(1), nBufferCountActual(1), nBufferSize(524288) nBufferAlignmen(32)
22:49:27 T:3024269312 INFO: PAPlayer::PrepareStream - Ready
22:49:27 T:3024269312 DEBUG: PlayFile: OpenFile succeed, play state 1
22:49:27 T:2685400096 NOTICE: Thread PAPlayer start, auto delete: false
22:49:27 T:2685400096 DEBUG: PAPlayer::Process - Playback started
22:49:27 T:2685400096 DEBUG: OnPlayBackStarted: play state was 1, starting 0
22:49:27 T:3024269312 DEBUG: CGUIInfoManager::SetCurrentSong(musicdb://songs/2798.mp3)
22:49:27 T:3024269312 DEBUG: Loading additional tag info for file smb://LS-GL613/mp3/Levellers/Letters From The Underground/ 02-Death Loves Youth.mp3
22:49:27 T:3024269312 DEBUG: CSMBFile::Open - opened mp3/Levellers/Letters From The Underground/02-Death Loves Youth.mp3, fd =10000
22:49:27 T:3024269312 DEBUG: unrecognized ID3 frame detected: MCDI
22:49:27 T:3024269312 DEBUG: unrecognized ID3 frame detected: TLEN
22:49:27 T:3024269312 DEBUG: CSMBFile::Close closing fd 10000
22:49:27 T:3024269312 DEBUG: CAnnouncementManager - Announcement: OnRemove from xbmc
22:49:27 T:3024269312 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnRemove
22:49:27 T:3024269312 DEBUG: GetRandomSong query = select * from songview WHERE songview.idSong not in (6156, 6722, 5080, 3 829, 5110, 5722, 2798, 4822, 990, 3464) ORDER BY RANDOM() LIMIT 1
22:49:28 T:3024269312 DEBUG: SELECT albumview.*,albumartistview.* FROM albumview LEFT JOIN albumartistview ON albumview. idAlbum = albumartistview.idAlbum WHERE albumview.idAlbum = 303 ORDER BY albumartistview.iOrder
22:49:28 T:3024269312 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
22:49:29 T:3024269312 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
22:49:29 T:3024269312 INFO: PARTY MODE MANAGER: Adding randomly selected song at 9:[smb://LS-GL613/mp3/Levellers/Zeitgeist [Bonus Disc]/10-Hobo.mp3]
22:49:29 T:3024269312 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
22:49:29 T:3024269312 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
22:49:29 T:3024269312 DEBUG: UPnP: Building didl for object 'musicdb://songs/2798.mp3'
22:49:29 T:3024269312 DEBUG: LIRC: Update - NEW at 213253050:197 0 KEY_NEXT_UP linux-input-layer (KEY_NEXT_UP)
22:49:29 T:2513429536 NOTICE: Thread JobWorker start, auto delete: true
22:49:29 T:2513429536 DEBUG: DoWork - Saving file state for audio item musicdb://songs/4822.mp3
22:49:29 T:3024269312 DEBUG: CGUIMediaWindow::GetDirectory (playlistmusic://)
22:49:29 T:3024269312 DEBUG: ParentPath = [playlistmusic://]
22:49:29 T:2496652320 NOTICE: Thread BackgroundLoader start, auto delete: false
22:49:29 T:2513429536 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0x60a4418
22:49:29 T:2513429536 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferC ountMin(2), nBufferCountActual(2), nBufferSize(130032), nBufferAlignmen(16)
22:49:29 T:2513429536 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0 x55d2170
22:49:29 T:2513429536 DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin( 1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16)
22:49:29 T:2513429536 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.image_decode handle 0x60a4418
22:49:29 T:2513429536 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.egl_render handle 0x55d2170
22:49:29 T:2513429536 DEBUG: DecodeJpegToTexture: decoded special://masterprofile/Thumbnails/0/01cc7745.jpg 540x540
22:49:29 T:2513429536 DEBUG: DoWork - took 137 ms to load special://masterprofile/Thumbnails/0/01cc7745.jpg
22:49:30 T:2496652320 DEBUG: Thread BackgroundLoader 2496652320 terminating
22:49:40 T:2892284960 DEBUG: script.module.osmcsetting.updates : - blurp 999 - MyMusicPlaylist.xml
22:49:59 T:2513429536 DEBUG: Thread JobWorker 2513429536 terminating (autodelete)
