since i upgraded to RC3 my volume are VERY low (HDMI, and Analogue too ) i have to set my TV on max volume level to hear silent music.
any ideas? maybe a bug?
i tried an other OS (retropie) to test if my pi is broken but it works well. only on OSMC RC3 i cant hear any sound.
Check you have the master volume in Kodi turned right up. (+/- keys on a keyboard)
There was a bug in older versions of OMXplayer that caused the volume to be much higher than it should be for intermediate settings of the master volume, now this is fixed you will have to set the master volume higher to get the same output volume.
Sorry, I gave the wrong default port number - fixed. (Default is 80 not 8080)
So did turning up the master volume fix the sound issue ? On a Pi it’s usually best to leave the master volume at maximum especially on the Analog out, which can be quite noisy and distorted at low volume settings. (Due to hardware limitations of the analog port)
It shouldn’t have, and unless you lost all your Kodi settings, (corrupted guisettings.xml) very unlikely. More likely you had it set to something like 70% which would be a large volume drop on the new version of Kodi but an almost imperceptible drop on the old version.
