Hello,
I have no sound since the upgrade. As I have updated this weekend from 2017.01-1 to ver 2017.03-1 and yesterday to 2017.04-1 and as I have not used OSMC in between it is unclear which version caused the issue.
The Raspberry 1 is connected via HDMI.
I just changed ignore_CEC and tried hdmi_drive=2 in config .txt without success.
Any help is welcome.
Br,
J
jfw:
Hello,I have no sound since the upgrade. As I have updated this weekend from 2017.01-1 to ver 2017.03-1 and yesterday to 2017.04-1 and as I have not used OSMC in between it is unclear which version caused the issue.The Raspberry 1 is connected via HDMI.I just changed ignore_CEC and tried hdmi_drive=2 in config .txt without success.
Br,
Try to power down the Pi and your TV and disconnect them for a couple of minutes.
Check if you might by accident have muted the Pi (e.g. Press volume up)
If none of the two works provide debug enabled logs
Hello,
The PI is conncted via HDMI to a AV receiver.
When looking in the logs I have noticed (no pass through)
22:26:34.348 T:2645394416 NOTICE: Creating InputStream
22:26:34.574 T:2645394416 NOTICE: Creating Demuxer
22:26:35.056 T:2645394416 NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
22:26:35.223 T:2645394416 NOTICE: Opening stream: 0 source: 256
22:26:35.224 T:2645394416 NOTICE: Creating video codec with codec id: 28
22:26:35.242 T:2645394416 NOTICE: Creating video thread
22:26:35.243 T:2645394416 NOTICE: Opening stream: 1 source: 256
22:26:35.243 T:2645394416 NOTICE: Finding audio codec for: 86018
22:26:35.248 T:2637005808 NOTICE: running thread: video_thread
22:26:35.271 T:2645394416 NOTICE: Creating audio thread
22:26:35.289 T:2662171632 NOTICE: running thread: CVideoPlayerAudio::Process()
22:26:35.366 T:2662171632 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
I have resetted the audio settings to default, set pass through… and know it works… I have no clue what happened. Anyway. It is working now.
Thanks for the help
br,
