I am using a Vero 4K+ and just updated to Kodi 19. I am not getting any sound played on every single movie. Either there is no sound at all (on 7.1 files as far as I could observe) or there is heavy white noise (2.0 and 5.1 files). System sounds work good however.
Passtrough for all formats is activated which worked fine before the upgrade.
reproduce the issue
However, setting the screen to 1080@60p leaves the OSMC screen “zoomed in”. It is slightly larger than the TV now. I tried rebooting the vero4k+ and removed the power for some minutes from the home cinema system, but still the menu doesn’t fit the screen.
I had the same problem everything working fine on audio before Kodi19 now no stream on most audio or white noise I turned off stereo upmix as advised and it did the trick audio back to normal now.
