Hello all, what can be the reason, that 4K videos are now not played back in 4K. This has worked in the past. I have not used the Vero 4K+ for a longer time, may be even not after the March update.
If I change the Interface resolution the TV indicates 4K, but I know this is not recommended and everything is very laggy.
reproduce the issue
The video your playing is 50fps and your TV is not displaying support for that frame rate at 4K resolution so Kodi is prioritizing smooth video over higher resolution. If you configured a white list you could go into the video settings during playback and override this, but I don’t suspect you would find it to be a preferable viiewing experience.
I haven’t changed any hardware component since I bought the Vero 4K in 2020. And there are several files in UHD and 50fps which have been displayed correctly in the past.
I tried the whitelist, but UHD with 50fps is not in the list, highest value is 30fps.
In the specification of the TV also 3840x2160@60p is listed.
The supported formats of your TV come from your TV as you can see in the log…
====================== Display Cap CTA =================== g0gjk991
480p60hz
576p50hz
720p50hz
720p60hz
1080p24hz
1080p30hz
1080i50hz
1080p50hz
1080i60hz
1080p60hz*
2160p24hz
2160p25hz
2160p30hz
smpte24hz
---------------------- Display Cap CTA END --------------- g0gjk991
Perhaps your TV did a firmware update and that changed something. Perhaps what you played previously wasn’t 50fps but 25fps which your TV reports as being supported.
The list is only what your TV is reporting as supported. What I meant was that you could force it to something like 2160p25 which would give you the resolution at the cost of a correct frame rate.
A change of cable no, a change of ports might not be outside the realm of possibilities. If ports on your TV had different specs this should be outlined in the user manual for the TV.
For sure the videos (I made them myself) have always been in 50p, but of course a firmware change of the TV is possible. Today I made a firmware update, but still the same behavior. At the TV a firmware downgrade is not possible.
Is it possible for test purposes to went back to the firmware of mid 2020 for the Vero?
Hi all, thank you for your support. I tried the manual override and added 2160p50hz. After that the TV shows when the playback starts: 3840x2160@31Hz. Around 30 seconds everything went well, but after that the playback has interrupts. So it seems that I have to accept, that my TV no longer is able to playback 4K@50Hz. Maybe I contact Sony why they made this change. (@sam_nazarko: my last hardware change (TV, AVR really everything) was the vero in early 2020 and I have watched my videos until early 2022 in in 4K@50Hz)
