No update after 2020-06-10
I’ve been away from my Vero2 setup for a long time through illness. Got back to it today and getting ‘no update available’ when I try to run an update? I’m guessing the Vero2 is pretty old and maybe no more updates? Or I’ve got so far behind something more drastic is required like a re-install?
You should be able to update up to Kodi 18.9
I suppose if the user update function in OSMC keeps failing at ‘Cache Updated - Please Wait’ then I may need to reinstall?
Yes, you’re likely on an old version without an upgrade path anymore.
