No updates - oct 2020.10-1
Hello,
i cant update / find updates in my vero 4k ; currently running oct 2020.10-1
https://imgur.com/a/v8rcS68
Any idea how can i update to the latest version?
it got somehow push up notification and updated to 2021.08-1; then i did manual check for the updates and upgrade it again.
As far I can see Confluence is not working anymore? thanks
Should be available for Kodi 19, you might just need to update the Repository and then update and reenable Confluence
https://kodi.wiki/view/Add-on:Confluence
This hotfix also solved the update problem for me. Thanks!
