Hi guys!
First of all some basics:
Vero4k+
osmc latest
SSH installed and enabled
wifi connected
Vero is HDMI connected to Denon AVR x4500h
CEC is turned off on the Denon as I control everything with one of the following methods
Vero controlled via Logitech Harmony, Kore App, Yatse App or OpenHab Binding
Here’s the problem:
After waking the machine up from hibernation, I get no video signal. I’ve to use Kore, Yatse or webinterface and start a video file. Even if I hit any button on a remote, and Vero reacts to it, I get no signal.
Thanks in advance!
Dom
reproduce the issue
Thanks @darwindesign
Did the steps and here’s the log: https://paste.osmc.tv/afejiyedad
After the second reboot I did the following:
- set machine to hibernation
- wake up from hibernation (no video signal)
- used Kore to start Zoolander.mkv
- stopped playback via harmony remote
- grab-logs -A
Regards
Dom
Did you reproduce the issue before uploading the logs? In your case this would be putting into suspend, waking it and the video not coming up, and then ssh and then grab-logs -A
Also have you tried switching the source on the AVR to something else then back to the Vero input to see if the Video comes back up.
On a separate note, as I doubt it is related, we recommend settings your UI to 1080p as any higher gives a performance penalty.
Your side note did the trick
It’s not just that the transitions are much smoother, setting the UI resolution to 1080p even solved my problem and I get a picture after wake up.
Thanks a lot!
