Ok. Thanks!
@pinn73. Sorry. Can I bother you with the firmware version of you Onkyo? If it’s not the same, at least you’ll know you shouldn’t update yet haha
His log from an OOM issue shows he is on the same version of OSMC as reported in your log.
This is primarily why I suspect something else.
Thanks, Sam!
I’m on 2139-8050-7090-0010
Thanks, @pinn73! Replied to your PM
Should I use this hotfix?
There’s a workaround for problematic receivers and it should be in an update shortly. For now:
Go to My OSMC -> Updates -> Manual Controls
Enter vumilakacu
Press OKNow go to My OSMC -> Updates -> Manual Controls and check for updates again. Complete the updates.
Found out now that it’s a problem with the AV receiver itself. 4k Blu-ray player is now experiencing this same issue. Thanks to everyone who helped. Especially @pinn73!
