No video signal when osmc starts after update
Did an update today from my osmc, and after restart, I get black screen. I get the osmc splash, and after that it goes black and tv reports no signal. Think the atv is connected with component video.
Logs: http://paste.osmc.io/eroqiweweq
I did ā€œsudo umount /boot sudo fsck.hfsplus -f /dev/sda1 sudo mount -o force,rw /dev/sda1 /bootā€, assuming that’s what you ment. No change in behaviour. Still goes black after osmc splash. I’ve had the problem with unclean shutdowns before, and that only led to updates not installing correctly I think. Not video signal lost after the splash.
This is from your log today
dpkg: error processing archive /var/cache/apt/archives/atv-image-4.2.3-20-osmc_20_i386.deb (--unpack):
 unable to clean up mess surrounding `./boot/vmlinuz-4.2.3-20-osmc' before installing another version: Read-only file system```
You should follow the commands I linked to above with `sudo apt-get update && sudo apt-get dist-upgrade && sudo reboot`
First things must be handled first.
You might want to run ā€˜apt-get -f install’ to correct these.
atv-kernel-osmc : Depends: atv-image-4.2.3-20-osmc but it is not installed
E: Unmet dependencies. Try using -f.
Followed the suggestion, and redid sudo apt-get update && sudo apt-get dist-upgrade && sudo reboot. Picture came back. Thanks!
