I’ve been successfully using Live TV on a RaspBMC using the TV headend client to receive a stream from a different R-Pi running TV Headend as a server.
Decided to update to the new Kodi system on OSMC, plays video fine on my network but if I try Live TV all I get is audio.
Server working fine as I get Live TV video on my phone and netpad but Kodi sound only from Live TV
I’ve checked the config settings for Kodi, the R-Pi and the TV Headend client but can find nothing obvious.
Unsure if Kodi or TV Headend problem but it did work fine under RaspBMC
Hmmm, maybe you are covered then. Sorry, I am not sure.
I am not an expert on this, by any means. I can tell you that my setup has both backend PVR and frontend server on the same Pi2. And in my case, I found the LiveTV stream unusable without an MPEG-2 license.
If you are viewing content that the MPEG-2 license would normally offload to to hardware decoding, you are putting unnecessary stress on your pi and taking resources away from things where it might be better used to improve performance otherwise.
