In MyOSMC Network Wreless = Status No wireless connection
https://paste.osmc.tv/aniquhodaq
Do I need to reenter the network credentials after swapping dongles or should it just connect?
The underlaying network connection manager âconnmanâ saves the settings related to devices, so: Yes, reenter the credentials once again!
OK Iâll give that a try. Thanks
Yes that was actually the problem - once I reentered all the details everything worked as expected. Stupidly I missed that.
So I guess this dongle can be added to the âIt worksâ list after all.
Thanks everyone for your help.
Edit : reinstalled kernel 4.19 and all is still working.
Hi All,
I wenth through this thread. I have the same problem, my wifi dongle stopped working.
What are a recommended wifi dingles which will work? Is there some list of supported HW?
I am using the CanaKit 150 MBPS 802.11N/G/B mini usb wireless adapter on my Raspberry Pii with Kodi and OSMC. It works on my pii 1, 2, and 3. I was previously using the Edimax until it failed to be recognized. The CanaKit adapter is approximately $15 on Amazon.
Because I tend to delay updating OSMC on my old Pi (simply because the requests to update normally appear just as I am about to watch something) I have recently fallen foul of this update in the past week because my Pi1 had an Edimax-branded WiFi dongle.
After reading through the posts in this thread I then did a search for MT7601U and picked up a âWireless-Nâ USB adapter (as it was described) from eBay for ÂŁ4.
After a bit of messing around (including moving the Pi1 into another room where I had a spare Ethernet connection) I was able to confirm that it looked as though the new adapter was being recognised, but no IP config. I was about to ask âSo, what next?â when I re-read through the thread and picked up on MyOSMC. Took the Pi back to its original location, connected it back to the TV along with a Logitech K400 keyboard to make navigation a little easier. Found MyOSMC and got the new WiFi adapter connected to the access point.
Looks like everything is OK and can confirm this WiFi adapter works find in a Pi1 with OSMC:-
hello I am using a raspberry pi 2 with OSMC and after upgrading to the
kernel 4.19.55-6-osmc the wifi no longer appears in the configuration menu.
I realized that I was using a Realtek based wifi dongle which is no longer supported so I switched to a new Ralink dongle that should work.
I inserted the new dongle in the usb port but the wifi configuration menu does not reappear.
Dmesg says:
new high-speed USB device number 4 using dwc_otg
New USB device found, idVendor=148f, idProduct=5370, bcdDevice= 1.01
New USB device strings: Mfr=1, Product=2, SerialNumber=3
Product: 802.11 n WLAN
Manufacturer: Ralink
So I wanted to configure via command line the wifi and tried to use connmanctl but I was not able to figure out why it is not working:
connmanctl> scan wifi
Error /net/connman/technology/wifi: Method âScanâ with signature ââ on interface ânet.connman.Technologyâ doesnât exist
can anyone suggest me which commands I should use?
thanks in advance
I had forgotten
connmanctl> enable wifi
Error wifi: Method âSetPropertyâ with signature âsvâ on interface ânet.connman.Technologyâ doesnât exist
Please provide the full system journal. grab-logs -J
(Youâll need to have it connected by cable.)
osmc@osmc:~$ grab-logs -J
Logs successfully uploaded.
Logs available at https://paste.osmc.tv/pefomiyuko
Mar 23 18:01:41 osmc systemd-udevd[205]: ctx=0x22ff290 path=/lib/modules/4.19.55-6-osmc/kernel/drivers/uio/uio.ko error=No such file or directory
Mar 23 18:01:41 osmc systemd-udevd[205]: ctx=0x22ff290 path=/lib/modules/4.19.55-6-osmc/kernel/drivers/staging/vc04_services/vchiq-mmal/bcm2835-mmal-vchiq.ko error=No such file or directory
It seems like the kernel update didnât work correctly. Iâd suggest you try to reinstall the kernel package:
sudo apt-get install --reinstall rbp2-image-4.19.55-6-osmc
If that works, reboot. Since youâre using a Pi2, itâs possible that the SD card might be having some issues.
it worked thanks a lot
Hello, i have the same Problem after a update.
I already reinstalled the Version.
and tryed this as well, but it didnt work:
here are some logs:
http://paste.osmc.tv/jabogeqati
http://paste.osmc.tv/mihuvaraye
The adapter is using an âout-of-treeâ Realtek chipset, which is no longer supported in OSMC (and hasnât been supported for over a year). However, Sam says support for some of the out-of-tree chipsets will be reintroduced at some point in the future.
that one is over 3 years old⌠i used a OSMC Version from 3 Years ago, but i have to update, since most of my main apps are dead now.
so i have to get a new adapter or what is the last version, which supports my adapter?
and thanks for the repley
I think that support for the Realtek chips was removed in kernel 4.19, so the last installation image with 4.14 was July 2019.
Thank you, it is fine again and the apps are also working again
