No Wi-Fi connection after update
Interestingly on buster lite, my (now depreciated) D-link DWA-131 wifi dongle:
pi@raspberrypi:~ $ lsusb
Bus 001 Device 004: ID 2001:3319 D-Link Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Dmesg:
[   53.331778] usb 1-1.5: new high-speed USB device number 4 using dwc_otg
[   53.462903] usb 1-1.5: New USB device found, idVendor=2001, idProduct=3319, b        cdDevice= 2.00
[   53.462919] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber        =3
[   53.462929] usb 1-1.5: Product: Wireless N Nano USB Adapter
[   53.462938] usb 1-1.5: Manufacturer: Realtek
[   53.462948] usb 1-1.5: SerialNumber: 00e04c000001
Of course having said that, ifconfig does not show the usb device, so that’s a bust.
Well my gut feel points to an issue with the Dongle but then it also should have the Issue under Win10.
Any other Raspberry Pi you can test it with?
Or maybe run either Linux LiveCD or a Linux Virtual machine on your PC to check.
Unfortunately no other Pi’s available, but I’m inclined to agree to it being a dongle issue. A fresh install of OSMC August image and OSMC does not like the mediatek adapter, but it is happy with the D-Link Realtek adapter.
After applying all the latest updates neither adapter’s are recognised in MyOSMC
Hi everyone, I have the same problem using an ASUS N10 nano wife dongle. Is this adapater longer supported? Thanks
The Asus usb-n10 is based on a Realtek RTL8188EUS chipset so it is not currently supported.
(FYI I deleted the thread you started as it was redundant to this post)
I was using wired previously but moving my pi3 across the room so would like to switch to wireless and encountered the same. bummer. Adding my logs to the mix.
https://paste.osmc.tv/koqolonota
The wireless on the RPi 3 was only affected in that it can no longer use tethering with the current builds. Just connecting to an existing network should still work. Did you go into MyOSMC and turn the wireless on?
Yeah. Wireless does not show up as an option. Only Wired and MySQL.
Just ordered a Vero 4k+ for the comfort of knowing it will be supported and the 801.11ac for 5ghz will be nice. I really like OSMC over my previous OpenElec install and figured I can re-purpose the pi for something else.
That’s a smart move.
When you migrated everything to the Vero I suggest to first try with a clean Raspian Install to check if the wifi comes to live because there is definitely something wrong
Nov 22 11:14:49 Lilac123 rpi-btuart[324]: bcm43xx_init
Nov 22 11:14:49 Lilac123 systemd[1]: brcm43xx.service: Control process exited, code=exited status=1
Nov 22 11:14:49 Lilac123 systemd[1]: Failed to start Broadcom 43xx bluetooth HCI.
Nov 22 11:14:49 Lilac123 systemd[1]: brcm43xx.service: Unit entered failed state.
Nov 22 11:14:49 Lilac123 systemd[1]: brcm43xx.service: Failed with result 'exit-code'.
Good tip, thanks. It would not surprise me if there is a hardware issue with the Pi. It can get pretty hot here so the Pi is baking in spite of heatsink and fan.
Could you please tell me where i could find a list of supported devices?
I have found some devices with Ralink chipset… do you know if this one is still supported?
There is no list that I am aware of.
I do not know but from what I understand most adapters that are not based on Realtek chipsets are expected to have the same compatibility as with the previous kernel.
I ordered a dongle that claimed to contain the MT7610U chipset but unfortunately it was actually Realtek based. I have also ordered Ralink RT5370 and Mediatek MT7601 based dongles.
I will report the details and success/fail on these when I receive them.
Hi, an update:
MediaTek MT7601U VID:148f, PID:7601 with kernel 4.14
Did not work !! Looks like exactly the same issue as user Jonathan_Szoke
Means also the urb error?
Im actually not sure.
In dmesg the only reference I can find is:
[ 2.583321] usb 1-1.4: New USB device found, idVendor=148f, idProduct=7601
[ 2.583336] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.583343] usb 1-1.4: Product: 802.11 n WLAN
[ 2.583350] usb 1-1.4: Manufacturer: MediaTek
[ 2.583357] usb 1-1.4: SerialNumber: 1.0
I don’t see any other errors here but the wifi does not come up and at boot I see some error msg about Samba (just like when I use the Realtek with the 4.19 kernel)
What is lsmod saying
osmc@osmc:~$ lsmod
Module Size Used by
8021q 32768 0
garp 20480 1 8021q
stp 16384 1 garp
llc 16384 2 garp,stp
iptable_nat 16384 0
nf_conntrack_ipv4 16384 1
nf_defrag_ipv4 16384 1 nf_conntrack_ipv4
nf_nat_ipv4 16384 1 iptable_nat
nf_nat 32768 1 nf_nat_ipv4
nf_conntrack 139264 3 nf_conntrack_ipv4,nf_nat_ipv4,nf_nat
iptable_mangle 16384 0
arc4 16384 2
iptable_filter 16384 0
uinput 20480 1
mt7601u 106496 0
mac80211 765952 1 mt7601u
evdev 24576 4
cfg80211 626688 2 mac80211,mt7601u
rfkill 28672 4 cfg80211
snd_bcm2835 32768 0
snd_pcm 114688 1 snd_bcm2835
snd_timer 36864 1 snd_pcm
snd 86016 3 snd_timer,snd_bcm2835,snd_pcm
bcm2835_gpiomem 16384 0
bcm2835_thermal 16384 0
ir_lirc_codec 16384 2
lirc_dev 20480 1 ir_lirc_codec
gpio_ir_recv 16384 0
rc_core 45056 4 ir_lirc_codec,lirc_dev,gpio_ir_recv
uio_pdrv_genirq 16384 0
fixed 16384 0
uio 20480 1 uio_pdrv_genirq
ip_tables 24576 3 iptable_mangle,iptable_filter,iptable_nat
x_tables 36864 3 iptable_mangle,ip_tables,iptable_filter
ipv6 475136 42
Ok so but under MyOSMC still no WiFi section?
Guess would need to check full dmesg output. Can upload via dmesg | paste-log
