No wireless networks available in kodi / osmc
this happened after an update for youtube plugin and a reboot, although i fail to see the connection
the plugin has been uninstalled since then but nothing changed
under system → system info → network eveything appears as busy ( mac address, ip address, etc)
same goes for summary, where operating system, system uptime and total uptime appear as busy
under myosmc → network , no wireless networks are available, and when i try to configure manually i get an “unhandled exception caught” - i need to access the logs to see exactly what happened, but i used to connect via the wi-fi network in order to get to them before, so i;m still trying to reach them from inside kodi
any ideas how i can get this going again?
Sometimes I need to restart connman to resolve this kind of behavior.
sudo systemctl restart connman
i already tried rebooting, shutting down and restarting, same behaviour. no wireless networks found
sorry i don’t yet have physical access to the logs, but here are two pics with errors which i think are relevant to my situation? https://imgur.com/a/mb7FeUL
Mmhhh, only idea I have is that for some reasons the connman wifi configuration got corrupt.
The problem is, you cannot delete the related directory with kodi’s file mgr since you need root-permissions for this.
Adhoc, I suggest
  • connect the Vero with a LAN cable to your network (no hdmi required)
  • figure out the new IP the device got on your router and use an appropriate terminal program like putty to ssh login to the Vero, user:osmc, password:osmc
  • remove the specfic directory: sudo rm -R /var/lib/connman/wifi_*
  • shutdown the Vero: sudo shutdown -h now … and wait a minute
  • place the Vero V to the previous location, connect the hdmi cable and power it on
From here the device should have no knowledge anymore about the wifi configuration and you should try to configure the wifi with MyOSMC within the GUI.
Plan B if the network access via cable is not possible for any reasons:
  • connect a USB keyboard to the Vero
  • in the GUI select power -> exit
  • immediately, when the desktop gets black or you see the blue splash screen, hit the escape key on the keyboard (doesn’t hurt to hit it several times); if it does not work at once, retry it several times restarting with power -> exit
  • from the login prompt, follow the steps already mentioned above
    (be careful since the keyboard mapping might be wrong/strange)
thanks a lot for your suggestion, deleting that folder worked for me. everything is ok now!
revisiting this issue, any idea why this keeps happening? i seem to be needing to follow these steps every couple of days in order to get wireless working
A log might give some more details as to what is going on
got it, i’ll keep an eye out for when this issue appears again and see if i can spot something in the logs. thanks
@JimKnopf i also tried to connect to do the sudo rm -r wifi_* command via usb keyboard straight from vero, and although it did delete what it was supposed to, it still did not work
so i reconnected to it with an ethernet cable, tried to re-do the commands by ssh-ing into it - of course, there was nothing else to delete, and after plugging it back in its place with hdmi it worked. so maybe just connecting it via ethernet cable has something to do with it?
btw, here is a log of my machine when wi-fi was not working. https://paste.osmc.tv/raw/mopagagaxe
i was tringy to go into setting - system info - and check the network device and it hanged. maybe line 603 about avahi demon not being available?
@habarnam The suggested method is only intended for the case that the problem occurs once and is not a recurring workaround!
Posting the individual Kodi log file doesn’t really help either; we usually need a log set with kernel logging, as you can read in all the current posts here.
Whatever went wrong with this YouTube update, based on your description I suggest you completely reinstall the device with the latest release from scratch.
You are also welcome to try uploading a current log set here again, in the hope that this will show the reason that something is corrupting your wifi configuration.
But this only make sense if you’re able to connect the box with an ethernet LAN cable to your router WITHOUT a reboot, after the wifi failed. Rebooting the Vero results in the loss of the kernel logs from interest. If you cannot prepare such data collection, better invest your time in a fresh installation of the box. Instructions for a debug log set follow:
@JimKnopf again, thanks for this. I’ll enable kernel logging and try to access the logs once the problem occurs again
