Hi there, im currently usiing a Pi0 Wifi, and using OSMC.
I am trying to get the NordVPN app installed and working on this device. I know NordVPN now have their own app for Linux to save using the openVPN solution that i had used in the past using a great tutorial.
However i decided to try and use the following guide to install the main application:
1. Get the NordVPN repo setup .deb package
You can Download the file here or at the top of this page
2. Install the NordVPN repository
Open the terminal and run the following: sudo apt-get install {/path/to/}nordvpn-release_1.0.0_all.deb
3. Update the apt-get package list
Type this command: sudo apt-get update
4. Install NordVPN
Almost there! Enter the last command to install NordVPN: sudo apt-get install nordvpn
This has all installed with no issues. So that bit is all good.
my issue is when i try and login (which i belive then will ask for username/pass)
the Command for this is “nordvpn login”
When i type this or in fact anything like nordvpn -h or just nordVpn i get the following message
“Illegal instruction” - i have had a look on line and that might mean something is protected on OSMC or on the PI itself?
Any help would be great thanks ![]()
Regards
Chris
