I have 4k rip direct from makemkv. The audio is dts-HD MA but the vero4k+ GUI shows it as only dts and that’s what is output. If I select audio settings on the GUI it show English - Surround 5.1 - 0 Channels - 6 Channels.
This would normally say DTS-HD MA 5.1(SIDE)
Running mediainfo on the file gives the following audio info:
Audio
ID in the original source medium : 4352 (0x1100)
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Duration : 1 h 41 min
Bit rate mode : Variable
Bit rate : 3 816 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Delay relative to video : 6 s 6 ms
Stream size : 2.71 GiB (6%)
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Original source medium : Blu-ray
Any suggestions? I’ve never had any problems like this before.
Every other dts-HD MA file I have shows correctly on the GUI and is displayed on my amp. The vero seems to think this one is dts. It’s a new 4k disc so I haven’t had this one working correctly.
That’s right. I only ripped that one audio track. The vero thinks it’s dts. If I select audio settings on the GUI it show English - Surround 5.1 - 0 Channels - 6 Channels.
Why (Kodi’s) ffmpeg would be getting a different reading from mediainfo I’ve no idea. If you install an up-to-date version of ffmpeg and run ffprobe on that file do you get a different result from what’s reported in Kodi?
We’re also wondering about that ‘Delay relative to video’ entry. Sounds odd but I wouldn’t know how to deal with it.
I think there must be something off about the audio track. I also ripped it as FLAC but the sync is way out (and strangely smaller filesize). I’ll just stick with the lossy for now.
I’m not suggesting you update the ffmpeg that comes with Kodi. That one is specific to Kodi but is behind the bleeding edge ffmpeg. I just wondered if a more recent ffmpeg would report something different. If so, it could be something Team Kodi could look into. But if you don’t have that on a PC, say, it’s not worth the bother.
This is looking like the answer is to redo the rip rather than anything that can be fixed in OSMC.
I’ve tried a few rips. Even gave the disc a clean!
ok I have this version of ffmpeg on my laptop:
7:4.4.2-0ubuntu0.22.04.1
I ran the audio through ffprobe and the result is:
Not really. You want to know what ffprobe reports when analysing the whole rip, not just the audio track. If it’s a big file, just post the audio part, we don’t need to see all the Chapter stuff.
When ffmpeg (in Kodi) reads a file, it only reads so much. I’m wondering whether that 6 second delay on the audio track means ffmpeg is not finding it. Struggling with the maths and I don’t know if that read buffer size can be adjusted easily.
OK so ffmpeg 7 gets it right while 6 (shipped with Kodi) does not.
You could take this up with Kodi but I’m guessing they will say they’ve moved on and won’t want to spend time fixing a Version 21/FFmpeg 6.0.1 corner case.
