Not directly Vero but related
Among other things I use my Vero 4k+ to play MKV files that have atmos audio as its one of the few things to do this.
The only way I can tell if its atmos is to actually play the file and see what my AVR tells me the sound form is. The vero just says Dolby and Media info is no more help. Is there any software tool to say if its Atmos ?
Thnaks
MediaInfo might help you.
depending on your skin, they often list audio format in the ui
Thanks for the skin suggestion, I tried all 4 and still got the same info (DD+ 5.1), and no atmos
check here as I think you have atmos already: https://www.reddit.com/r/hometheater/comments/6zuagf/what_is_the_difference_between_dolby_digital_plus/
I do , but the vero only says Dolby until I actually play the file, and so does media info. I just wanted a way to find out if it was Atmos with out getting the AVR to play the file.
Agree with @Chang_loo - MediaInfo does show this
Taken from Dolby_Atmos_Natures_Fury_1920x1080_ATMOS_71-thedigitaltheater.mkv
Audio
Format                                   : MLP FBA 16-ch
Format/Info                              : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name                          : Dolby TrueHD with Dolby Atmos
Codec ID                                 : A_TRUEHD
Duration                                 : 1 min 51 s
Bit rate mode                            : Variable
Bit rate                                 : 6 320 kb/s
Maximum bit rate                         : 9 849 kb/s
Channel(s)                               : 8 channels
Channel layout                           : L R C LFE Ls Rs Lb Rb
Sampling rate                            : 48.0 kHz
Frame rate                               : 1 200.000 FPS (40 SPF)
Compression mode                         : Lossless
Stream size                              : 83.8 MiB (25%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Number of dynamic objects                : 15
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
Taken from Dolby_Atmos_shattered-3Mb.mp4
Audio
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Format settings                          : Dolby Surround EX
Codec ID                                 : ec-3
Duration                                 : 50 s 17 ms
Bit rate mode                            : Constant
Bit rate                                 : 448 kb/s
Channel(s)                               : 6 channels
Frame rate                               : 31.250 FPS (1536 SPF)
Compression mode                         : Lossy
Stream size                              : 2.67 MiB (13%)
Service kind                             : Complete Main
Default                                  : Yes
Alternate group                          : 2
Encoded date                             : 2016-12-06 07:08:34 UTC
Tagged date                              : 2016-12-06 07:08:34 UTC
Complexity index                         : 12
Number of dynamic objects                : 11
As Dolby Atmos in home cinema equipment is embedded inside a Dolby TrueHD or Dolby Digital Plus stream, some tools just see the main stream without checking for (or differentiating for) sub-stream data.
Sortted thanks. I was only aware of mediainfo from with in MPC-HC which I use to play files on my PC, this only says DD+ or DD True HD for atmos files.
I have just installed the standalone media info program and that tells me its Atmos.
