Nothing has changed )i.e. I have made no changes to the system/source locations) but recently I have to manually scan everything I put on. Is there maybe a different/better scraper I should be using? Thanks
reproduce the issue
upload the log set (all configs and logs!) either using the
Are you sure it is both movies and TV and not just new episodes from shows that had already been in your library? What are your scrapers currently set as? Do you use nfo files?
