Lately, I’ve noticed that the Vero isn’t switching for content in 25 fps, causing a sort of weird playback. Is anyone else seeing this? I don’t really know if it coincided with the most recent update, because I don’t watch 25 fps stuff all that much.
Also, I don’t know if PlexKodiConnect might be the culprit. The show plays properly in my Apple TV with the Plex client, but not with InfusSo, I don’t know who is to blame. Mostly asking to see if anyone else has the problem.
Logs would give us some answers, but if you have 25fps progressive material you would need to set your GUI resolution to 25fps and/or whitelist that resolution and use adjust refresh rate.
25fps interlaced material (50i) is best played at 50p.
Thanks for that, but it’s not giving me the option to whitelist any refresh rates such as 25 or 50. The TV and AVR are capable of those rates–I can watch it on the Apple TV4k with Infuse, and it switches to 50 fps.
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Ok, I plugged the Vero direct into the TV, and same thing–it plays that show at 60hz.
This is a different TV than what I had a couple of weeks ago. Is it possible that Kodi is not updating the refresh rates? I had a TCL R615 that died, and replaced it with this, the 2019 model.
How are you determining what the TV is receiving from the Apple TV? Does this TV have some kind of an osd/info you can bring up that shows what it is actually receiving? I think it is possible that the TV supports it, but just doesn’t report it.
Yes. Pressing the “OK” button on the TV remote while something is playing displays the resolution and frame rate. The TV definitely supports it–not only by seeing it in the osd/info, but the playback doesn’t have the jitters–it plays as smoothly as 60hz.
