Nothing but rectangle arc color after installing OSMC on RP2
tried different SD cards,
tried to install from MAC and PC
same result:
TV displays colored rectangle
any ideas ?
Are you certain you have installed the Rpi2 image and not the Rpi1?
I’m getting results too! Any solutions
certain 110% :smiley:
I downloaded my version from the Pi site is there a better site to choose from? I’m using OS X.
I used sd formatter to fix that with some sd cards. it also happened, when the img downloaded incorrectly with the installer(connection was problematic)
