I am currently attempting to set up the nova-t-usb2 (Hauppauge WinTV-NOVA-T-USB2 - LinuxTVWiki) on a Rpi3 with TVHeadend
The device is being listed in lsusb however the /dev/dvb folder is not being created.
I have tried following this guide: Compile Kernel on RPI2 from RBP2-sources-osmc
Please note, The dmesg Product field changed to SOHO-FX2 ater following the guide above
Command output
lsusb
Bus 001 Device 008: ID 2040:9300 Hauppauge WinTV NOVA-T USB2 (cold)
Bus 001 Device 007: ID 2109:2813 VIA Labs, Inc.
Bus 001 Device 006: ID 2109:2813 VIA Labs, Inc.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
dmesg
[ 139.367846] hub 1-1.3.1:1.0: USB hub found
[ 139.368628] hub 1-1.3.1:1.0: 4 ports detected
[ 139.705201] usb 1-1.3.1.4: new high-speed USB device number 8 using dwc_otg
[ 139.849141] usb 1-1.3.1.4: New USB device found, idVendor=2040, idProduct=9300
[ 139.849159] usb 1-1.3.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 139.849168] usb 1-1.3.1.4: Product: SOHO-FX2
[ 139.849177] usb 1-1.3.1.4: Manufacturer: Hauppau<U+2067>攀
[ 139.849186] usb 1-1.3.1.4: SerialNumber: 9301-00-F008B2D8
[ 139.901740] dvb-usb: found a 'Hauppauge WinTV-NOVA-T usb2' in cold state, will try to load a firmware
[ 139.903045] dvb-usb: downloading firmware from file 'dvb-usb-nova-t-usb2-02.fw'
[ 139.932468] usbcore: registered new interface driver dvb_usb_nova_t_usb2
lsmod
Module Size Used by
dvb_usb_nova_t_usb2 16384 0
dvb_usb_dibusb_mc_common 16384 1 dvb_usb_nova_t_usb2
dvb_usb_dibusb_common 16384 2 dvb_usb_dibusb_mc_common,dvb_usb_nova_t_usb2
dib3000mc 36864 1 dvb_usb_dibusb_mc_common
dibx000_common 20480 1 dib3000mc
dvb_usb 32768 2 dvb_usb_dibusb_common,dvb_usb_nova_t_usb2
dvb_core 114688 1 dvb_usb
cmac 16384 1
bnep 20480 2
hci_uart 24576 1
bluetooth 409600 23 hci_uart,bnep
ecdh_generic 36864 1 bluetooth
iptable_nat 16384 0
nf_conntrack_ipv4 16384 1
nf_defrag_ipv4 16384 1 nf_conntrack_ipv4
nf_nat_ipv4 16384 1 iptable_nat
nf_nat 32768 1 nf_nat_ipv4
nf_conntrack 139264 3 nf_conntrack_ipv4,nf_nat_ipv4,nf_nat
evdev 24576 1
uinput 20480 1
iptable_mangle 16384 0
iptable_filter 16384 0
brcmfmac 262144 0
brcmutil 16384 1 brcmfmac
cfg80211 626688 1 brcmfmac
rfkill 28672 7 bluetooth,cfg80211
snd_bcm2835 32768 0
snd_pcm 114688 1 snd_bcm2835
snd_timer 36864 1 snd_pcm
snd 86016 3 snd_timer,snd_bcm2835,snd_pcm
bcm2835_thermal 16384 0
lirc_rpi 16384 2
lirc_dev 20480 1 lirc_rpi
bcm2835_gpiomem 16384 0
rc_core 45056 2 dvb_usb,lirc_dev
uio_pdrv_genirq 16384 0
fixed 16384 0
uio 20480 1 uio_pdrv_genirq
binfmt_misc 20480 1
ip_tables 24576 3 iptable_mangle,iptable_filter,iptable_nat
x_tables 32768 3 iptable_mangle,ip_tables,iptable_filter
ipv6 487424 42
