Ntp not working on new Vero V, and solution
Received my shiny new Vero V last week, so far have only done the OSMC updates and tweaked some of the config in the gui before it goes “live” to replace my Vero 4k.
Yesterday I noticed an ntp error every couple of hours in syslog, which can also be seen by checking the service status:
osmc@tim-verov:~$ systemctl status ntp.service
* ntp.service - Network Time Service
     Loaded: loaded (/lib/systemd/system/ntp.service; enabled; vendor preset: enabled)
     Active: active (running) since Wed 2025-04-09 18:03:03 AEST; 4 days ago
       Docs: man:ntpd(8)
    Process: 3136 ExecStart=/usr/lib/ntp/ntp-systemd-wrapper (code=exited, status=0/SUCCESS)
   Main PID: 3142 (ntpd)
      Tasks: 2 (limit: 3659)
     Memory: 1.9M
     CGroup: /system.slice/ntp.service
             `-3142 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 105:108
Apr 13 18:03:03 tim-verov ntpd[3142]: leapsecond file ('/usr/share/zoneinfo/leap-seconds.list'): expired 107 days ago
Apr 13 21:03:03 tim-verov ntpd[3142]: frequency file /var/lib/ntp/ntp.drift.TEMP: Permission denied
Apr 14 01:03:03 tim-verov ntpd[3142]: frequency file /var/lib/ntp/ntp.drift.TEMP: Permission denied
Apr 14 03:03:03 tim-verov ntpd[3142]: frequency file /var/lib/ntp/ntp.drift.TEMP: Permission denied
Apr 14 05:03:03 tim-verov ntpd[3142]: frequency file /var/lib/ntp/ntp.drift.TEMP: Permission denied
Apr 14 07:03:03 tim-verov ntpd[3142]: frequency file /var/lib/ntp/ntp.drift.TEMP: Permission denied
Apr 14 11:03:03 tim-verov ntpd[3142]: frequency file /var/lib/ntp/ntp.drift.TEMP: Permission denied
Apr 14 13:03:03 tim-verov ntpd[3142]: frequency file /var/lib/ntp/ntp.drift.TEMP: Permission denied
Apr 14 16:03:03 tim-verov ntpd[3142]: frequency file /var/lib/ntp/ntp.drift.TEMP: Permission denied
Apr 14 17:03:03 tim-verov ntpd[3142]: frequency file /var/lib/ntp/ntp.drift.TEMP: Permission denied
Ownership of directory /var/lib/ntp doesn’t look right, i.e. ntp user has no write permission:
osmc@tim-verov:~$ ls -ld /var/lib/ntp
drwxr-xr-x 2 129 messagebus 4096 Sep 23  2020 /var/lib/ntp
Comparing that to my soon to be retired vero 4k:
osmc@tim-vero4k:~$ ls -ld /var/lib/ntp
drwxr-xr-x 2 ntp ntp 4096 Apr 14 17:38 /var/lib/ntp
So, changed ownership on the directory and restarted ntp service:
osmc@tim-verov:~$ sudo chown ntp:ntp /var/lib/ntp
osmc@tim-verov:~$ sudo systemctl restart ntp.service
     Active: active (running) since Mon 2025-04-14 18:08:08 AEST; 6s ago
       Docs: man:ntpd(8)
    Process: 7317 ExecStart=/usr/lib/ntp/ntp-systemd-wrapper (code=exited, status=0/SUCCESS)
   Main PID: 7323 (ntpd)
     Memory: 1.1M
             `-7323 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 105:108
Apr 14 18:08:11 tim-verov ntpd[7323]: Soliciting pool server 139.99.135.247
Apr 14 18:08:12 tim-verov ntpd[7323]: Soliciting pool server 162.159.200.123
Apr 14 18:08:12 tim-verov ntpd[7323]: Soliciting pool server 27.124.125.251
Apr 14 18:08:12 tim-verov ntpd[7323]: Soliciting pool server 27.124.125.252
Apr 14 18:08:12 tim-verov ntpd[7323]: Soliciting pool server 194.195.249.28
Apr 14 18:08:13 tim-verov ntpd[7323]: Soliciting pool server 162.159.200.1
Apr 14 18:08:13 tim-verov ntpd[7323]: Soliciting pool server 119.18.6.37
Apr 14 18:08:13 tim-verov ntpd[7323]: Soliciting pool server 13.55.50.68
Apr 14 18:08:14 tim-verov ntpd[7323]: Soliciting pool server 27.124.125.250
Apr 14 18:08:14 tim-verov ntpd[7323]: Soliciting pool server 110.232.114.22
So, no more errors, and about 90 minutes later there is an ntp.drift file:
osmc@tim-verov:/var/lib/ntp$ ls -l
total 4
-rw-r--r-- 1 ntp ntp 7 Apr 14 19:08 ntp.drift
I am seeing the same thing on both of my Vero Vs. I changed the folder permissions and the errors went away.
Jeff
Seeing the same thing also, so corrected permissions. Looks like the install script for OSMC/Vero-V needs correcting, so as to set the correct permissions on /var/lib/ntp
From when is your install/build? Can check with grab-logs -P -I
My permissions are correct but my build is very old
osmc@osmc-verov:~$ ls -ld /var/lib/ntp
drwxr-xr-x 2 ntp ntp 4096 Apr 15 20:47 /var/lib/ntp
I’m having the same issue and corrected permissions.
osmc@HTPC:~$ ls -ld /var/lib/ntp
Result of grab-logs -P -I:
Grabbing log UNAME ...
Grabbing log cmdline ...
Grabbing log Debian version ...
Grabbing log OSMC Build Information ...
Writing logs to temp file ...
Logs created on: 2025-04-15 18:45:55 - (Uptime = 763.75)
0wwkXuO5  :  UNAME
0wwYYuO5  :  cmdline
m4ls932a  :  Debian version
ps9k90Ws  :  OSMC Build Information
====================== UNAME =================== 0wwkXuO5
Linux HTPC 4.9.269-80-osmc #1 SMP PREEMPT Sun Mar 2 14:02:42 UTC 2025 aarch64 GNU/Linux
---------------------- UNAME END --------------- 0wwkXuO5
====================== cmdline =================== 0wwYYuO5
console=ttyS0,921600 earlycon=aml-uart,0xfe07a000 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 logo=osd0,loaded,0x7f800000 vout=1080p60hz,enable hdmitx=,444,8bit hdmimode=1080p60hz cvbsmode=576cvbs osmc.root_wants_resize= mac=94:cc:04:60:0b:26 systemd.unified_cgroup_hierarchy=0 root=/dev/osmcroot rootfstype=ext4 quiet console=tty0 osmcdev=vero5
---------------------- cmdline END --------------- 0wwYYuO5
====================== Debian version =================== m4ls932a
11.11
---------------------- Debian version END --------------- m4ls932a
====================== OSMC Build Information =================== ps9k90Ws
OSMC filesystem assembled on jenkins at Mon 11 Dec 2023 02:00:44 AM UTC using Debootstrap version 1.0.123+deb11u1
---------------------- OSMC Build Information END --------------- ps9k90Ws
Had the same issue, thanks for this quick fix!
It would be nice if it would respect dhcp option 42 though.
Linux osmc-v 4.9.269-81-osmc #1 SMP PREEMPT Mon Mar 17 09:44:05 UTC 2025 aarch64 GNU/Linux
OSMC filesystem assembled on jenkins at Mon 07 Aug 2023 03:24:13 PM UTC using Debootstrap version 1.0.123+deb11u1
osmc@tim-verov:~$ grab-logs -P -I
Logs created on: 2025-04-16 17:54:23 - (Uptime = 160349.94)
0wwkXuO5  :  UNAME
0wwYYuO5  :  cmdline
Linux tim-verov 4.9.269-80-osmc #1 SMP PREEMPT Sun Mar 2 14:02:42 UTC 2025 aarch64 GNU/Linux
console=ttyS0,921600 earlycon=aml-uart,0xfe07a000 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 logo=osd0,loaded,0x7f800000 vout=1080p60hz,enable hdmitx=,444,8bit hdmimode=1080p60hz cvbsmode=576cvbs osmc.root_wants_resize= mac=94:CC:04:60:0E:36 systemd.unified_cgroup_hierarchy=0 root=/dev/osmcroot rootfstype=ext4 quiet console=tty0 osmcdev=vero5
11.11
OSMC filesystem assembled on jenkins at Sun 02 Mar 2025 04:10:15 PM UTC using Debootstrap version 1.0.123+deb11u1
Ok it’s not realted to the built then.
So super strange. Seems to be that @sam_nazarko must use his magic powers to understand why some systems have wrong permissions
Any ideas @sam_nazarko why the permissions were set incorrectly on /var/lib/ntp ? and how this could be corrected ?
Hi @thebream
Thanks for the report. It’s interesting.
If you ordered the Vero V recently, it’s a long standing issue hence it still being present with a fairly monitor filesystem:
From the top of my head, it could be two problems:
  • Bad postinst not setting permissions probably. This was a known Debian issue in the past.
  • Some sort of kernel configuration missing / not set which isn’t allowing NTP to set the permissions.
It can obviously be fixed, but will need some investigation.
Anyone got a Pi up and running on latest OSMC that can quickly check if it’s an issue there too? It will be a few days before I can directly test on a PI otherwise.
On a RPi4 here with latest greatest OSMC from staging this is not an issue.
On a VeroV shipped in January with OSMC from staging the device is affected.
Perfect, thanks @JimKnopf
FWIW, here are my order details:
Order number: 71223
Date: March 25, 2025
And, just to be a little pendantic, the permissions are ok, it’s the ownership that is is wrong. The file in my example is owned by uid 129 (which does not exist in /etc/passwd, so no name shown in “ls”), and gid 104 (“messagebus” in /etc/group).
Also FWIW, I mentioned in my original post that I had “done the OSMC updates” - I would have checked for updates, but according to /var/log/apt/history.log there have been no updates applied (all I can see is that I have installed rsyslog, logrotate and rsync), i.e. the system was already “up to date” when I fired it up.
Interesting…
On one test system I’ve got:
-rw-r--r-- 1 ntp ntp 8 Apr 17 11:23 /var/lib/ntp/ntp.drift
And:
cat /etc/osmc_build_info
OSMC filesystem assembled on jenkins at Tue 28 May 2024 12:40:35 AM UTC using Debootstrap version 1.0.123+deb11u1
This is a relatively old root filesystem.
I can’t upgrade NTP:
root@osmc:/home/osmc# apt-get install ntp
Reading package lists... Done
Building dependency tree... Done
ntp is already the newest version (1:4.2.8p15+dfsg-1).
ntp set to manually installed.
Here’s the build info from 2 of my systems wherre the filesystem ownership was wrong.
osmc@Kodi-Florida:~/.kodi/temp$ cat /etc/osmc_build_info
osmc@Kodi-BR:~/.kodi/temp$ cat /etc/osmc_build_info
These were both off the same order. I have a newer Vero V from late last year. I’ll check it when I get time.
Thanks,
Jeff
I got my new Vero V out of the box.
osmc@osmc:~$ cat /etc/osmc_build_info
Here’s the default ownership:
I changed ownership and all is well.
Thanks,
Jeff
Not sure if this is helpful, but I appear to have a different OSMC build but the same directory ownership problem:
osmc@osmc:/var/lib/ntp$ cat /etc/osmc_build_info
osmc@osmc:/var/lib/ntp$ ll
total 8
drwxr-xr-x  2  129 messagebus 4096 Sep 23  2020 .
drwxr-xr-x 18 root root       4096 Apr 16 16:57 ..
Vero V that was installed out of the box last week.
Still thinking.
@JimKnopf reports that reinstallation of ntp (sudo apt-get install --reinstall ntp) fixes the issue. So I think we can just fix ownership in network-osmc which should work for new and existing installs.
Newer versions of Debian use systemd-timesyncd, which is why this is probably not a massively reported issue. And existing installations… exist…
See
Notice the conditional, because maybe systemd-timesyncd will be sufficient enough in the next Debian release. We’ve already had requests to make it installable which is why we made it a conditional dependency here:
I’d welcome some opinions on such a change.
To test this update:
  1. Login via the command line
  2. Run the following command to add the staging repository:
  3. Run the following commands to update: sudo apt-get update && sudo apt-get dist-upgrade && reboot
  4. Your system should have have received the update.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
