Mediainfo:Blade.Runner.2049.2017.2160p.BluRay.x265.10bit.HDR.DTS-HD.MA.TrueHD.7.1.Atmos-SWTYBLZ
Video
Format : HEVC
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2 h 43 min
Bit rate : 10.1 Mb/s
Width : 3 840 pixels
Height : 1 600 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.068
Stream size : 11.5 GiB (52%)
Title : Blade.Runner.2049.2017.2160p.BluRay.x265.10bit.HDR.DTS-HD.MA.TrueHD.7.1.Atmos-SWTYBLZ
Writing library : x265 2.6+22-ff02513b92c0:[Windows][GCC 6.3.0][64 bit] 10bit
Encoding settings : cpuid=1173503 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1600 / interlace=0 / total-frames=235152 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50) / max-cll=457,179 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / analysis-save=(null) / analysis-load=(null) / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 457 cd/m2
Maximum Frame-Average Light Level : 179 cd/m2
Audio #1
Format : TrueHD
Format profile : TrueHD+Atmos / TrueHD
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 4 597 kb/s
Maximum bit rate : 5 022 kb/s
Channel(s) : Object Based / 8 channels
Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : / 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Stream size : 5.25 GiB (24%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
Bit rate mode : Variable / Constant
Bit rate : 3 840 kb/s / 1 509 kb/s
Channel(s) : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Stream size : 4.37 GiB (20%)
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 748 MiB (3%)
Language : English
Service kind : Complete Main
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 2 h 26 min
Bit rate : 24 b/s
Count of elements : 974
Stream size : 26.7 KiB (0%)
Title : English-SRT
Language : English
Default : Yes
Forced : No
Text #2
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 2 h 32 min
Bit rate : 14.9 kb/s
Count of elements : 1950
Stream size : 16.3 MiB (0%)
Title : English-PGS
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Muxing mode : zlib
Duration : 2 h 34 min
Bit rate : 18.6 kb/s
Count of elements : 2458
Stream size : 20.5 MiB (0%)
Title : English-SDH-PGS
Language : English
Default : No
Forced : No
Text #4
Format : PGS
Muxing mode : zlib
Duration : 2 h 42 min
Bit rate : 8 520 b/s
Count of elements : 2097
Stream size : 9.91 MiB (0%)
Title : Arabic-PGS
Language : Arabic
Default : No
Forced : No
Text #5
Format : PGS
Muxing mode : zlib
Bit rate : 15.6 kb/s
Count of elements : 2078
Stream size : 18.2 MiB (0%)
Title : Bulgarian-PGS
Language : Bulgarian
Default : No
Forced : No
Text #6
Format : PGS
Muxing mode : zlib
Bit rate : 13.3 kb/s
Count of elements : 2092
Stream size : 15.5 MiB (0%)
Title : Chinese-PGS
Language : Chinese
Default : No
Forced : No
Text #7
Format : PGS
Muxing mode : zlib
Bit rate : 12.4 kb/s
Count of elements : 2090
Stream size : 14.4 MiB (0%)
Title : Chinese-PGS
Language : Chinese
Default : No
Forced : No
Text #8
Format : PGS
Muxing mode : zlib
Bit rate : 12.6 kb/s
Count of elements : 2086
Stream size : 14.7 MiB (0%)
Title : Chinese-PGS
Language : Chinese
Default : No
Forced : No
Text #9
Format : PGS
Muxing mode : zlib
Bit rate : 13.8 kb/s
Count of elements : 2084
Stream size : 16.1 MiB (0%)
Title : Croatian-PGS
Language : Croatian
Default : No
Forced : No
Text #10
Format : PGS
Muxing mode : zlib
Bit rate : 14.0 kb/s
Count of elements : 2074
Title : Czech-PGS
Language : Czech
Default : No
Forced : No
Text #11
Format : PGS
Muxing mode : zlib
Duration : 2 h 41 min
Bit rate : 17.1 kb/s
Count of elements : 2116
Stream size : 19.7 MiB (0%)
Title : Greek-PGS
Language : Greek
Default : No
Forced : No
Text #12
Format : PGS
Muxing mode : zlib
Bit rate : 11.6 kb/s
Count of elements : 2104
Stream size : 13.5 MiB (0%)
Title : Hebrew-PGS
Language : Hebrew
Default : No
Forced : No
Text #13
Format : PGS
Muxing mode : zlib
Bit rate : 14.5 kb/s
Count of elements : 1984
Stream size : 16.9 MiB (0%)
Title : Hungarian-PGS
Language : Hungarian
Default : No
Forced : No
Text #14
Format : PGS
Muxing mode : zlib
Bit rate : 15.4 kb/s
Count of elements : 2036
Stream size : 18.0 MiB (0%)
Title : Icelandic-PGS
Language : Icelandic
Default : No
Forced : No
Text #15
Format : PGS
Muxing mode : zlib
Bit rate : 17.0 kb/s
Stream size : 19.8 MiB (0%)
Title : Indonesian-PGS
Language : Indonesian
Default : No
Forced : No
Text #16
Format : PGS
Muxing mode : zlib
Bit rate : 12.2 kb/s
Stream size : 14.2 MiB (0%)
Title : Korean-PGS
Language : Korean
Default : No
Forced : No
Text #17
Format : PGS
Muxing mode : zlib
Bit rate : 18.2 kb/s
Count of elements : 2126
Stream size : 21.2 MiB (0%)
Title : Malay-PGS
Language : Malay
Default : No
Forced : No
Text #18
Format : PGS
Muxing mode : zlib
Bit rate : 16.0 kb/s
Stream size : 18.6 MiB (0%)
Title : Polish-PGS
Language : Polish
Default : No
Forced : No
Text #19
Format : PGS
Muxing mode : zlib
Title : Portuguese-PGS
Language : Portuguese
Default : No
Forced : No
Text #20
Format : PGS
Muxing mode : zlib
Count of elements : 2102
Default : No
Forced : No
Text #21
Format : PGS
Muxing mode : zlib
Bit rate : 15.2 kb/s
Count of elements : 2080
Stream size : 17.6 MiB (0%)
Title : Romanian-PGS
Language : Romanian
Default : No
Forced : No
Text #22
Format : PGS
Muxing mode : zlib
Bit rate : 14.6 kb/s
Count of elements : 2082
Stream size : 17.0 MiB (0%)
Title : Serbian-PGS
Language : Serbian
Default : No
Forced : No
Text #23
Format : PGS
Muxing mode : zlib
Bit rate : 13.7 kb/s
Stream size : 15.9 MiB (0%)
Title : Slovak-PGS
Language : Slovak
Default : No
Forced : No
Text #24
Format : PGS
Muxing mode : zlib
Count of elements : 1964
Title : Slovenian-PGS
Language : Slovenian
Default : No
Forced : No
Text #25
Format : PGS
Muxing mode : zlib
Stream size : 18.1 MiB (0%)
Title : Spanish-PGS
Language : Spanish
Default : No
Forced : No
Text #26
Format : PGS
Muxing mode : zlib
Bit rate : 14.8 kb/s
Count of elements : 2096
Stream size : 17.2 MiB (0%)
Title : Thai-PGS
Language : Thai
Default : No
Forced : No
Text #27
Format : PGS
Muxing mode : zlib
Bit rate : 15.7 kb/s
Stream size : 18.3 MiB (0%)
Title : Turkish-PGS
Language : Turkish
Default : No
Forced : No
Text #28
Format : PGS
Muxing mode : zlib
Bit rate : 17.6 kb/s
Count of elements : 2146
Title : Vietnamese-PGS
Language : Vietnamese
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:12:36.172 : en:Chapter 2
00:23:29.282 : en:Chapter 3
00:37:00.885 : en:Chapter 4
00:42:50.317 : en:Chapter 5
00:49:24.503 : en:Chapter 6
00:58:35.553 : en:Chapter 7
01:04:10.680 : en:Chapter 8
01:15:47.292 : en:Chapter 9
01:25:12.482 : en:Chapter 10
01:36:15.060 : en:Chapter 11
01:50:55.106 : en:Chapter 12
02:01:36.872 : en:Chapter 13
02:08:40.379 : en:Chapter 14
02:16:42.485 : en:Chapter 15
02:27:46.732 : en:Chapter 16
