Hi, I just did a fresh install and noticed something strange with the mouse icon. It displays as a full screen line instead of the pointer. I noticed changing the display to 1920x1080 will occasionally fix the issue but it seems to revert back frequently. Sometimes the mouse even displays “epg” instead of a pointer. Attached is a pic of the mouse line. Thanks!
- What version are you on?
- Please post config.txt
Hi, I am on version 2016.08-1 - If this isn’t the correct log, let me know and I’ll get the correct one. Thanks
Ul2H1CLu : Pi config
====================== Pi config =================== Ul2H1CLu
gpu_mem_1024=256
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
dtoverlay=lirc-rpi
gpu_mem_256=112
sdtv_aspect=1
dtparam=gpio_in_pin=18
gpu_mem_512=144
dtparam=gpio_out_pin=17
---------------------- Pi config END --------------- Ul2H1CLu
