I have an old Raspberry Pi (I believe it’s a B — 256MB RAM, 2 USB ports) that was running Raspbmc without any problems. I am using a D-Link DWA-160A2 wireless adapter (connected to a powered USB hub). I originally got that adapter because I needed 5GHz capability and there weren’t a ton of options at the time (2013). After updating to OSMC/Kodi, the wireless adapter is not visible, and I the wireless network option is missing. I plugged the adapter into my iMac to make sure that it is working, and it is.
For some reason, I can’t seem to find a list of OSMC-supported/compatible wireless adapters. Does anyone know if/where such a list exists, or if not, why?
Incidentally, I believe that the DWA-160A2 uses Atheros.
If nobody has any ideas, I’m just going to buy a new wireless adapter. I don’t have the 5GHz limitation anymore, so it will be a lot cheaper/easier.
Edit: it’s the 512MB version, though OSMC seems to think that it has 383MB total.
OSMC only shows 383MB because the 512MB of memory is split between the GPU and the CPU.
Post the output of dmesg after booting with the stick inserted that is the basic step to review why the driver is not picked up.
Thanks. I figured something was using the rest of the RAM.
Here’s the dmesg output. I have to split because of length:
4.9.2 (Raspbian 4.9.2-10) ) #1 PREEMPT Sat Jan 2 00:55:57 UTC 2016
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi Model B Rev 2
[ 0.000000] cma: Reserved 8 MiB at 0x16800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 94208
[ 0.000000] free_area_init_node: node 0, pgdat c0baaad4, node_mem_map d64b7000
[ 0.000000] Normal zone: 828 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 94208 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 93380
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=720 bcm2708.boardrev=0xf bcm2708.serial=0x61caf765 smsc95xx.macaddr=B8:27:EB:CA:F7:65 bcm2708_fb.fbswap=1 sdhci-bcm2
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 352100K/376832K available (7899K kernel code, 432K rwdata, 1804K rodata, 1812K init, 726K bss, 16540K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xd7800000 - 0xff000000 ( 632 MB)
lowmem : 0xc0000000 - 0xd7000000 ( 368 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc0982140 (9705 kB)
.init : 0xc0983000 - 0xc0b48000 (1812 kB)
.data : 0xc0b48000 - 0xc0bb4074 ( 433 kB)
.bss : 0xc0bb4074 - 0xc0c69be0 ( 727 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000030] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000072] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000166] bcm2835: system timer (irq = 27)
[ 0.000446] Console: colour dummy device 80x30
[ 0.000661] console [tty0] enabled
[ 0.000686] Calibrating delay loop… 697.95 BogoMIPS (lpj=3489792)
[ 0.060326] pid_max: default: 32768 minimum: 301
[ 0.060684] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060712] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.061735] Initializing cgroup subsys io
[ 0.061796] Initializing cgroup subsys memory
[ 0.061834] Initializing cgroup subsys devices
[ 0.061863] Initializing cgroup subsys freezer
[ 0.061890] Initializing cgroup subsys net_cls
[ 0.061975] CPU: Testing write buffer coherency: ok
[ 0.062049] ftrace: allocating 18842 entries in 56 pages
[ 0.159588] Setting up static identity map for 0x81c0 - 0x821c
[ 0.161919] devtmpfs: initialized
[ 0.168726] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.169379] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.171108] pinctrl core: initialized pinctrl subsystem
[ 0.172032] NET: Registered protocol family 16
[ 0.177084] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.199220] cpuidle: using governor ladder
[ 0.229283] cpuidle: using governor menu
[ 0.235673] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.235700] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.235875] Serial: AMBA PL011 UART driver
[ 0.236270] 20201000.uart: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 0.237087] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.301685] bcm2835-dma 20007000.dma: DMA legacy API manager at f2007000, dmachans=0x1
[ 0.303080] bcm2835-dma 20007000.dma: dma_debug:0
[ 0.303792] SCSI subsystem initialized
[ 0.304114] usbcore: registered new interface driver usbfs
[ 0.304260] usbcore: registered new interface driver hub
[ 0.304494] usbcore: registered new device driver usb
[ 0.309637] raspberrypi-firmware soc:firmware: Attached to firmware from 2015-12-08 14:44
[ 0.336960] clocksource: Switched to clocksource timer
[ 0.389514] FS-Cache: Loaded
[ 0.389917] CacheFiles: Loaded
[ 0.409201] NET: Registered protocol family 2
[ 0.410540] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.410643] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.410743] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.410845] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.410883] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.411237] NET: Registered protocol family 1
[ 0.411914] RPC: Registered named UNIX socket transport module.
[ 0.411942] RPC: Registered udp transport module.
[ 0.411953] RPC: Registered tcp transport module.
[ 0.411964] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.582143] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 0.583588] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.583711] audit: initializing netlink subsys (disabled)
[ 0.583805] audit: type=2000 audit(0.510:1): initialized
[ 0.599943] VFS: Disk quotas dquot_6.6.0
[ 0.600340] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
The remainder of the dump:
[ 0.603027] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.604414] NFS: Registering the id_resolver key type
[ 0.604521] Key type id_resolver registered
[ 0.604539] Key type id_legacy registered
[ 0.609566] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.609969] io scheduler noop registered
[ 0.610595] io scheduler bfq registered (default)
[ 0.610615] BFQ I/O-scheduler version: v7r7
[ 0.613263] BCM2708FB: allocated DMA memory 56c00000
[ 0.613346] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 0.626697] Console: switching to colour frame buffer device 160x45
[ 0.638584] vc-cma: Videocore CMA driver
[ 0.638614] vc-cma: vc_cma_base = 0x00000000
[ 0.638628] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.638640] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.639028] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 0.664012] brd: module loaded
[ 0.676380] loop: module loaded
[ 0.677736] vchiq: vchiq_init_state: slot_zero = 0xd6c80000, is_master = 0
[ 0.679929] Loading iSCSI transport class v2.0-870.
[ 0.681271] usbcore: registered new interface driver smsc95xx
[ 0.681387] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.882254] Core Release: 2.80a
[ 0.882291] Setting default values for core params
[ 0.882321] Finished setting default values for core params
[ 1.082814] Using Buffer DMA mode
[ 1.082847] Periodic Transfer Interrupt Enhancement - disabled
[ 1.082860] Multiprocessor Interrupt Enhancement - disabled
[ 1.082874] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.082894] Dedicated Tx FIFOs mode
[ 1.083413] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xd6c14000 dma = 0x56c14000 len=9024
[ 1.083454] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 1.083489] dwc_otg: Microframe scheduler enabled
[ 1.083570] WARN::hcd_init_fiq:413: FIQ on core 0 at 0xc0567854
[ 1.083592] WARN::hcd_init_fiq:414: FIQ ASM at 0xc0567b30 length 36
[ 1.083625] WARN::hcd_init_fiq:439: MPHI regs_base at 0xd7896000
[ 1.083703] dwc_otg 20980000.usb: DWC OTG Controller
[ 1.083768] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 1.083845] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 1.083909] Init: Port Power? op_state=1
[ 1.083922] Init: Power Port (0)
[ 1.084313] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.084340] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.084360] usb usb1: Product: DWC OTG Controller
[ 1.084377] usb usb1: Manufacturer: Linux 4.3.3-3-osmc dwc_otg_hcd
[ 1.084394] usb usb1: SerialNumber: 20980000.usb
[ 1.085621] hub 1-0:1.0: USB hub found
[ 1.085727] hub 1-0:1.0: 1 port detected
[ 1.086624] dwc_otg: FIQ enabled
[ 1.086645] dwc_otg: NAK holdoff enabled
[ 1.086658] dwc_otg: FIQ split-transaction FSM enabled
[ 1.086722] Module dwc_common_port init
[ 1.087453] usbcore: registered new interface driver usb-storage
[ 1.087915] mousedev: PS/2 mouse device common for all mice
[ 1.088715] usbcore: registered new interface driver usbtouchscreen
[ 1.089246] bcm2835-cpufreq: min=700000 max=850000
[ 1.090304] sdhci: Secure Digital Host Controller Interface driver
[ 1.090323] sdhci: Copyright© Pierre Ossman
[ 1.090839] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.090863] mmc-bcm2835 20300000.mmc: DMA channels allocated
[ 1.127144] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.127688] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.127858] hidraw: raw HID events driver © Jiri Kosina
[ 1.128119] usbcore: registered new interface driver usbhid
[ 1.128134] usbhid: USB HID core driver
[ 1.128828] Initializing XFRM netlink socket
[ 1.128916] NET: Registered protocol family 17
[ 1.129107] Key type dns_resolver registered
[ 1.130439] registered taskstats version 1
[ 1.130714] vc-sm: Videocore shared memory driver
[ 1.130736] [vc_sm_connected_init]: start
[ 1.131797] [vc_sm_connected_init]: end - returning 0
[ 1.143121] Freeing unused kernel memory: 1812K (c0983000 - c0b48000)
[ 1.187780] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.191471] mmc0: new high speed SDHC card at address e624
[ 1.197347] mmcblk0: mmc0:e624 SD08G 7.40 GiB
[ 1.201787] mmcblk0: p1 p2
[ 1.277346] Indeed it is in host mode hprt0 = 00021501
[ 1.517168] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.517367] Indeed it is in host mode hprt0 = 00001101
[ 1.578787] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.605706] fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p2
[ 1.606132] fsck: Filesystem UUID: 1bae4384-ec83-4a15-b143-34abb51f8796
[ 1.606572] fsck: /dev/mmcblk0p2: clean, 24787/469568 files, 208983/1877760 blocks
[ 1.767513] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 1.767545] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.768676] hub 1-1:1.0: USB hub found
[ 1.768841] hub 1-1:1.0: 3 ports detected
[ 2.047136] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.147430] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.147464] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.150575] smsc95xx v1.0.4
[ 2.217311] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-20980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ca:f7:65
[ 2.297066] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 2.397456] usb 1-1.2: New USB device found, idVendor=0409, idProduct=005a
[ 2.397488] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.398530] hub 1-1.2:1.0: USB hub found
[ 2.398681] hub 1-1.2:1.0: 4 ports detected
[ 2.487080] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[ 2.659434] usb 1-1.3: New USB device found, idVendor=0d62, idProduct=2106
[ 2.659467] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.659483] usb 1-1.3: Product: USB Multimedia Keyboard
[ 2.697958] input: USB Multimedia Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:0D62:2106.0001/input/input0
[ 2.707088] usb 1-1.2.4: new high-speed USB device number 6 using dwc_otg
[ 2.758209] hid-generic 0003:0D62:2106.0001: input,hidraw0: USB HID v1.10 Keyboard [USB Multimedia Keyboard] on usb-20980000.usb-1.3/input0
[ 2.799596] input: USB Multimedia Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:0D62:2106.0002/input/input1
[ 2.857491] hid-generic 0003:0D62:2106.0002: input,hidraw1: USB HID v1.10 Device [USB Multimedia Keyboard] on usb-20980000.usb-1.3/input1
[ 2.875317] usb 1-1.2.4: New USB device found, idVendor=07d1, idProduct=3a09
[ 2.875351] usb 1-1.2.4: New USB device strings: Mfr=16, Product=32, SerialNumber=48
[ 2.875368] usb 1-1.2.4: Product: 11n adapter
[ 2.875382] usb 1-1.2.4: Manufacturer: ATHER
[ 2.875394] usb 1-1.2.4: SerialNumber: 12345
[ 3.458781] random: systemd urandom read with 93 bits of entropy available
[ 3.526168] NET: Registered protocol family 10
[ 4.131090] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 4.131579] systemd[1]: Found ordering cycle on basic.target/start
[ 4.131626] systemd[1]: Found dependency on sysinit.target/start
[ 4.131674] systemd[1]: Found dependency on rpcbind.service/start
[ 4.131719] systemd[1]: Found dependency on network-online.target/start
[ 4.131761] systemd[1]: Found dependency on connman-wait-for-network.service/start
[ 4.131798] systemd[1]: Found dependency on basic.target/start
[ 4.131835] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 4.131877] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 4.132502] systemd[1]: Found ordering cycle on basic.target/start
[ 4.132560] systemd[1]: Found dependency on sysinit.target/start
[ 4.132606] systemd[1]: Found dependency on kbd.service/start
[ 4.132651] systemd[1]: Found dependency on remote-fs.target/start
[ 4.132689] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 4.132725] systemd[1]: Found dependency on connman.service/start
[ 4.132763] systemd[1]: Found dependency on basic.target/start
[ 4.132800] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 4.132842] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 4.343686] fuse init (API version 7.23)
[ 4.583445] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.889100] random: nonblocking pool is initialized
[ 5.607426] systemd-udevd[157]: starting version 215
[ 6.173547] lirc_dev: IR Remote Control driver registered, major 244
[ 6.205969] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.267314] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[ 6.272152] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 7.177231] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[ 7.177737] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 7.177758] lirc_rpi: driver registered!
[ 7.404498] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 7.567857] usb 1-1.2.4: reset high-speed USB device number 6 using dwc_otg
[ 7.717398] usbcore: registered new interface driver carl9170
[ 7.719428] usb 1-1.2.4: Direct firmware load for carl9170-1.fw failed with error -2
[ 7.719467] usb 1-1.2.4: firmware not found.
[ 9.699920] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 9.701251] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.806424] systemd-journald[132]: Received request to flush runtime journal from PID 1
[ 10.056629] input: lircd as /devices/virtual/input/input2
[ 80.835237] Console: switching to colour dummy device 80x30
[ 264.072265] Bluetooth: Core ver 2.20
[ 264.072488] NET: Registered protocol family 31
[ 264.072506] Bluetooth: HCI device and connection manager initialized
[ 264.072542] Bluetooth: HCI socket layer initialized
[ 264.072570] Bluetooth: L2CAP socket layer initialized
[ 264.072661] Bluetooth: SCO socket layer initialized
[ 264.124747] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 264.124781] Bluetooth: BNEP filters: protocol multicast
[ 264.124821] Bluetooth: BNEP socket layer initialized
[ 445.314868] Console: switching to colour frame buffer device 160x45
[ 459.170283] Console: switching to colour dummy device 80x30
[ 682.088507] Console: switching to colour frame buffer device 160x45
transfigure:
Are you sure that the stick is original and is getting enough power? The dmesg messages are a bit strange.
And somehow the stick wants the firmware carl9170-1.fw which seems not included in OSMC but the original ar9170.fw which is included in osmc
Some infos here: en:users:drivers:carl9170.fw [Linux Wireless]
Thank you, fzinken. Now that you mention it, I do recall that I had to jump through some hoops to get this adapter to work with the Pi. I must have flashed the rom with that customized firmware. So now, the question is whether I can find the original firmware somewhere and return it to stock. I imagine that another option would be to edit the kernel so that it makes use of the custom firmware.
As for power, I believe that it’s getting enough through the USB hub. It did in the past. If not, I’ll get a different wireless adapter.
Still trying to figure this out. I could not find a way to restore the adapter firmware to factory (or change it at all — I have no idea how I did it in the first place), so I tried installing the carl9170 driver on the pi. I was able to do this, but it still doesn’t work. I tried to use rfkill to find out what was going on, but any use of rfkill results in a segmentation fault. Here’s a clip of the dmesg:
[ 7.847208] usb 1-1.2.4: reset high-speed USB device number 7 using dwc_otg
[ 8.059453] usbcore: registered new interface driver carl9170
[ 8.090896] usb 1-1.2.4: driver API: 1.9.7 2012-12-15 [1-1]
[ 8.090936] usb 1-1.2.4: firmware API: 1.9.6 2012-07-07
[ 8.460062] ath: EEPROM regdomain: 0x807c
[ 8.460122] ath: EEPROM indicates we should expect a country code
[ 8.460134] ath: doing EEPROM country->regdmn map search
[ 8.460145] ath: country maps to regdmn code: 0x3a
[ 8.460155] ath: Country alpha2 being used: CA
[ 8.460163] ath: Regpair used: 0x3a
[ 8.595059] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
[ 8.602874] usb 1-1.2.4: Atheros AR9170 is registered as ‘phy0’
[ 10.573028] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 10.573713] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.763428] systemd-journald[141]: Received request to flush runtime journal from PID 1
[ 12.177677] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.188958] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 12.286204] 8021q: 802.1Q VLAN Support v1.8
[ 13.378524] input: lircd as /devices/virtual/input/input2
Could it be the difference between the version of the driver and the version of the firmware? Should I give up on this adapter?
Edit: I should add that I’m temporarily connecting using ethernet over AC.
Okay, it’s working now. Don’t know what I did.
