OK. To make sure my files weren’t fudged somehow I’ve reinstalled OSMC alpha 4 on the Pi 2.
I was surprised to discover that under /etc/network there wasn’t any interfaces file. I have the router to manually allocate an ip address to the pi wifi (EW-7811n) so perhaps that’s why I can get ssh via wifi with ease. Also, ir raises questions as to whether the interfaces file in /etc/network actually does anything. Allocating a static IP for eth0 doesn’t work, I have to do it manually all the time.
I also notices that iptables command wasn’t installed, had to install it manually. Does the pre-up iptables command also requires some sort of installation?
The ip addr command also had to be manually installed. So it seems that there are a few commands that need manually installation. I may be missing some to get it all to work or perhaps /etc/network/interfaces file doesn’t do anything.
Regarding your outputs, sysctl returns net.ipv4.ip_forward = 1. From the pi, ping 192.168.2.2 and ping 192.168.15.1 both work fine there’s no packet loss. TV has a manual IP set for ethernet so in theory it should work.
netstat -rn output
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
0.0.0.0 192.168.15.1 0.0.0.0 UG 0 0 0 wlan0
192.168.2.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.15.0 0.0.0.0 255.255.255.0 U 0 0 0 wlan0
192.168.15.1 0.0.0.0 255.255.255.255 UH 0 0 0 wlan0
iptables -v -L output
Chain INPUT (policy ACCEPT 366 packets, 36259 bytes)
pkts bytes target prot opt in out source destination
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
0 0 ACCEPT all -- eth0 wlan0 anywhere anywhere
0 0 ACCEPT all -- wlan0 eth0 anywhere anywhere state RELATED,ESTABLISHED
Chain OUTPUT (policy ACCEPT 220 packets, 25304 bytes)
iptables -t nat -v -L output
Chain PREROUTING (policy ACCEPT 9 packets, 2048 bytes)
Chain INPUT (policy ACCEPT 9 packets, 2048 bytes)
Chain OUTPUT (policy ACCEPT 50 packets, 4245 bytes)
Chain POSTROUTING (policy ACCEPT 9 packets, 524 bytes)
110 9004 SNAT all -- any wlan0 anywhere anywhere to:192.168.15.6
0 0 SNAT all -- any wlan0 anywhere anywhere to:192.168.15.6
The eth0 tcpdump on the pi and ping from laptop returns
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
^C
0 packets captured
0 packets received by filter
0 packets dropped by kernel
However, other times it returned
^C20:15:58.071481 IP Brunos-MacBook-Pro.local > osmc.local: ICMP host 192.168.2.11 unreachable, length 36
1 packet captured
2 packets received by filter
1 packet dropped by kernel
The wlan0 tcpdump returns
listening on wlan0, link-type EN10MB (Ethernet), capture size 262144 bytes
^C
0 packets captured
1 packet dropped by interface
On all occasions I have to halt the tcpdump on the pi with ctrl+C.
So, overall perhaps interfaces file doesn’t do anything. I have to setup eth0 IP address and iptables manually after rebooting. Somehow the routing is perhaps controlled by another file/command which I’m not sure about or maybe I’m missing some commands which are not included in the default OSMC installation.
