plugin opensubtitles stopped working. when i power on my osmc, first series/movie i can watch with subtitles, but when i want watch 2nd episode, the plugin show me error while downloading…
after reboot it works again, but still by 1st movie or episode.
I don’t think you can relate an issue with OpenSubtitles addon to OSMC.
OpenSubtitles is sketchy, it regularly does not work or throws an error, usually due to server or site issues on opensubtitles.org. You should always install multiple subtitle addons to fall back on, in my case Subscene and Subscenter (randomly chosen a while back).
The chance all three will go offline at a certain moment is extremely small.
If you think there is an issue with the addon, you should post it in the correct forum (KODI addons forum ofcourse). Definitely not here.
Device: RaspPi B +
Installation media: SDcard
Connection: Wired,
Power Supply Type: adapter
Power specs: 2A
Peripherals: no hub
Storage Device (incl. Network Sharing Protocol): playing movies from NAT through Network
OSMC version: “2015.08-1”
XBMC version: 21:37:15 19.258410 T:3023708720 NOTICE: Starting Kodi (15.1). Platform: Linux ARM 32-bit
21:37:15 19.258587 T:3023708720 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
Codecs: mpeg2
Audio/Video Output: HDMI
Overclocked: yes, to 950
Config.txt Extras:
LINK to uploaded logs in pastebin http://paste.osmc.io/uziqicovut
Buggy addon, or the addon is having trouble communicating with the server that it connects to - either way you’d need to follow that up with the addon author.
