OpenVPN: An error has occurred whilst trying to connect
I am using OSMC on Raspeberry Pi.
I have installed openvpn via the Brian Hornsby method. I am not a coder and the istallation took a LONG time and was very frustrating.
Connection seems to finally work OK via the terminal window.
Last login: Wed Dec 7 13:48:28 on ttys000
espagnol:~ gerardcollon$ ssh osmc@192.168.1.11
osmc@192.168.1.11’s password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Dec 6 17:41:17 2016 from espagnol.home
osmc@osmc:~$ sudo openvpn /home/osmc/vpn-config/UKLondon.ovpn
Wed Dec 7 13:49:40 2016 OpenVPN 2.3.4 arm-unknown-linux-gnueabihf [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Nov 19 2015
Wed Dec 7 13:49:40 2016 library versions: OpenSSL 1.0.1t 3 May 2016, LZO 2.08
Wed Dec 7 13:49:40 2016 WARNING: file ‘/home/osmc/vpn-config/pass.txt’ is group or others accessible
Wed Dec 7 13:49:40 2016 UDPv4 link local: [undef]
Wed Dec 7 13:49:40 2016 UDPv4 link remote: [AF_INET]104.238.169.28:1194
Wed Dec 7 13:49:40 2016 WARNING: this configuration may cache passwords in memory – use the auth-nocache option to prevent this
Wed Dec 7 13:49:41 2016 [9e912882b6157cdbacfb575358f3ea6f] Peer Connection Initiated with [AF_INET]104.238.169.28:1194
Wed Dec 7 13:49:43 2016 TUN/TAP device tun0 opened
Wed Dec 7 13:49:43 2016 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Wed Dec 7 13:49:43 2016 /sbin/ip link set dev tun0 up mtu 1500
Wed Dec 7 13:49:43 2016 /sbin/ip addr add dev tun0 local 10.8.10.6 peer 10.8.10.5
Wed Dec 7 13:49:43 2016 Initialization Sequence Completed
I am stuck at the OSMC level:
‘An error has occured whilst trying to connect OpenVpn
Unable to connect to OpenVPN management interface’
Connecting to the internet using an Orange Telecom proprietary modem in France. Very good download speeds of around 40mb
As far as I know I have configured everythign according to instruction.
Any help gratefully received.
Where are you seeing this?
Clearly “at the OSMC level” this is working as it is working on the command line and OSMC is the operating system. Are you trying to connect from within kodi? Are you using an add-on?
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Our wiki contains detailed steps for providing the relevant info we need to help you.
Moved to a new topic as this was appended to a post over a year old and it is unlikely to be related.
