HI,
Whether a clean install or an upgrade, openvpn does not seem to be doing DNS anymore.
It was fine the other day when I was using 17.5 and older, now nothing. The vpn connects fine, but no DNS is being done.
Any help?
Thanks,
Don
HI,
Any help?
Thanks,
Don
You probably need to have a look through this thread.
Guess your ISP blocks external DNS requests.
Check this
Thanks, for the replies.
I solved my dilemma by simply changing the DNS addresses that my router gives out from DHCP.
I used 8.8.8.8 and 4.2.2.2
Problem solved! Everything works like it used to, even Indigo’s system information shows my new external IP and the DNS I assigned.
Might be an easier solution, for people who are not Linux savvy.
Thanks again,
Don
I wanted to say that, while I appreciate the notoriety and being held up as an example of successful problem solving, my issue(s) was not necessarily due to the DNS server (Comcast) I was using nor to any VPN leakage (at least, as near as I could tell).
My issue seemed to be more of a result of a prior update that crashed my RPI 3/OSMC system (possibly related to power supply issues). I reset my system, left the DNA server addresses intact and re-enabled vpn. And the system worked fine after that. However, I have since moved over to “open source” DNS servers just in the off-chance they were a source.
Again, thanks for my 15 secs of fame
but don’t rely on my solution to be the answer to most or all of the issues that seem similar to mine.
Thanks and cheers…
