I would like to share a script that I use to make sure that my OpenVPN client connection keeps running in the background. I just could not get it to work with the built in options.
This guide includes installing some tools with apt-get and changing system files and is intended for advanced linux users only. Also this is just my very own approach to connect to VPN since this script avoids any system.d services and might be incompatible with certain configurations (connman, which is used by OSMC, might have problems with resolvconf if using the dnsproxy option as I was told).
My system that works fine with the script is the following:
- Raspberry Pi 3 with OSMC (2017.03-1)
- Only one network interface activated (onboard LAN - eth0), but also tested with onboard WiFi (wlan0)
- OpenVPN runs as a client
- VPN-Provider is PIA
- SSH enabled and ports opened for remote access via my script
Also tested it on Raspbian and Debian jessie (x86) in VirtualBox.
Before installing my files you should try if the “keepalive” option in the openvpn configuration works for you. For me it was not reliably reconnecting or restarted the openvpn service too often.
What the script does is simple: it pings 5 manually defined addresses and kills and restarts the OpenVPN process after the last address has failed.
To make that simpler it runs openvpn directly avoiding any additional services.
Also the script allows to open ports bypassing the VPN connection. All (incoming) traffic through these ports uses your real IP address then. (Found here)
This should be necessary if you want to use SSH remotely or host a web server or similar services.
There is an option to enable the port knocking daemon knockd too.
These options can easily be changed through the config file
/etc/default/openvpn-reconnect
All output of the script can be followed through its own log file. I added this just for fun but it is useful to find out how often and why the VPN connection restarts.
Preparation:
To avoid IP/DNS leaks or failure of the script you should follow these steps carefully:
1. Set your IP address, gateway and DNS manually or let your router give you a permanent IP. Write them down for later.
If you want to be most secure change your dns server to 127.0.0.1 or sth. non existent.
These settings can be done in kodi using the osmc addon. OSMC uses the network manager connman - others should also work with the script.
The used network manager must be changed in my config file.
2. If you have more than one interface (eth0 and wlan0) enabled at the same time it may be necessary to change the following for the script/openvpn to work (but better disable the unneeded device):
Make sure that you list the interface intended for Internet/VPN first in /etc/connman.conf:
PreferredTechnologies=wifi,ethernet
Also edit the OpenVPN configuration file and tell openvpn to only listen to one interface:
/etc/openvpn/yourconfig.ovpn:
#nobind
local 192.168.178.201
The next steps require a shell or ssh session (to exit to a shell from Kodi: Power - Leave - hit ESC as soon as you see the OSMC logo - wait till you can login (user: osmc password: osmc) - do so and quickly type: sudo service mediacenter stop):
3. Important: if installed remove any applications that change /etc/resolv.conf or edit the corresponding config files.
The following should work fine if no such applications are installed (just tested on freshly installed OSMC):
Create /etc/dhcp/dhclient-enter-hooks.d/nodnsupdate:
sudo nano /etc/dhcp/dhclient-enter-hooks.d/nodnsupdate
With:
#!/bin/sh
make_resolv_conf() {
Make it executable:
sudo chmod +x /etc/dhcp/dhclient-enter-hooks.d/nodnsupdate
4. Install the necessary tools:
sudo apt-get install openvpn resolvconf nano curl wget knockd iptables
If you want to use the knockd daemon edit
/etc/knockd.conf:
[options]
UseSyslog
LogFile = /var/log/knockd.log
[openCloseSSH]
sequence = 9000,7000,8000
seq_timeout = 5
start_command = iptables -t mangle -A PREROUTING -s %IP% -p tcp --dport 22 -j MARK --set-mark 2
cmd_timeout = 30
stop_command = iptables -t mangle -A PREROUTING -s %IP% -p tcp --dport 22 -j MARK --set-mark 0/2
tcpflags = syn
Change the port sequence and open these ports in your router.
5. activate resolvconf
sudo dpkg-reconfigure resolvconf
say yes/ok twice
6. reboot (seems necessary)
Your network manager should be running normally - now check your /etc/resolv.conf
cat /etc/resolv.conf
it must only contain a single line except the comments which is your manually set DNS server.
7. Configure OpenVPN
get the login information from your VPN provider. If you did not set a valid DNS server like suggested above you will need the IP address of the vpn server/country you want to connect to because name resolving is then deactivated with non running VPN. My provider (PIA VPN) offers zip files with examples in many variants:
I took the ip tcp variant
You can surely use them as templates for your own provider but better visit it’s web site.
Also get the ssl cert files and put everything in /etc/openvpn (no sub folders!).
You will just need to add a few lines to the configuration file so it looks like (udp might need a different port than 443 - possibly 1194):
client
dev tun
proto tcp
remote IP.IP.IP.IP 443 # change
resolv-retry infinite
nobind
persist-key
persist-tun
ca /etc/openvpn/ca.crt
tls-client
remote-cert-tls server
auth-user-pass /etc/openvpn/pass.txt
comp-lzo
verb 1
reneg-sec 0
crl-verify /etc/openvpn/crl.pem
management localhost 1337
log-append /var/log/openvpn.log
script-security 2
up /etc/openvpn/update-resolv-conf
down /etc/openvpn/update-resolv-conf
8. create the vpn password file:
sudo nano /etc/openvpn/pass.txt
Fill in like this:
username
password
Installation of the scripts:
1. Create the script files
The main script:
sudo nano /usr/local/bin/openvpn-reconnect.sh
#!/bin/bash
. /etc/default/openvpn-reconnect
echo >> $LOGFILE
echo `date "$DATEFORMAT"` "INFO: Script Started! Starting tests...">> $LOGFILE
messages () {
MSG_TESTOK1="NOTE: Internet is reachable at 1st try. Using interface $IFACE"
MSG_TESTOK2="NOTE: Internet is reachable at 2nd try. Using interface $IFACE"
MSG_TESTOK3="NOTE: Internet is reachable at 3rd try. Using interface $IFACE"
MSG_TESTOK4="NOTE: Internet is reachable at 4th try. Using interface $IFACE"
MSG_TESTOK5="NOTE: Internet is reachable at 5th try. Using interface $IFACE"
MSG_TESTNOTOK1="WARNING: Could not reach IP #1: $TESTADDR1"
MSG_TESTNOTOK2="WARNING: Could not reach IP #2: $TESTADDR2"
MSG_TESTNOTOK3="WARNING: Could not reach IP #3: $TESTADDR3"
MSG_TESTNOTOK4="WARNING: Could not reach IP #4: $TESTADDR4"
MSG_TESTNOTOK5="ERROR: Could not reach IP #5: $TESTADDR5"
MSG_NOTONLINE="NOTE: Internet not reachable, restarting OpenVPN..."
MSG_VPNNOTACT="WARNING: OpenVPN Service is not running! Restarting OpenVPN..."
MSG_DNSNOTACT="WARNING: VPN-DNS-Server is not active! Restarting OpenVPN..."
MSG_ROUTERSEEN="ERROR: Router-IP seen in resolv.conf! Clearing resolv.conf for safety."
MSG_NOROUTEFOUND="ERROR: Could not get default route for $IFACE, check your internet connection!"
MSG_NETMANRESTART="WARNING: Restarting $NETWORKMAN..."
MSG_IPROUTETRY="NOTE: Trying to recover the routing table for interface $IFACE..."
MSG_IPROUTEOK="NOTE: Recreated $IPROUTESHOW with original routing table..."
MSG_SUCCESS="SUCCESS: All fine! VPN is active."
routetest () {
if [ "`cat $IPROUTESHOW 2> /dev/null | grep default | grep $IFACE`" == "" ]; then
echo `date "$DATEFORMAT"` "$MSG_NETMANRESTART" >> $LOGFILE
pkill -x openvpn
service $NETWORKMAN restart
if [ "$NETWORKMAN" == "connman" ]; then
service connman-wait-for-network restart
fi
echo `date "$DATEFORMAT"` "$MSG_IPROUTETRY" >> $LOGFILE
ROUTEOK=2
for ((i=1; i<=10; i++)); do
ip route show | grep default | grep $ROUTERIP > /dev/null
if [ "$?" == "0" ]; then
ROUTEOK=1
break
else
sleep 2
fi
if [ "$i" == "10" ]; then
ROUTEOK=0
echo `date "$DATEFORMAT"` "$MSG_NOROUTEFOUND" >> $LOGFILE
return 1
fi
done
if [ "$ROUTEOK" == "1" ]; then
sleep 5
ip route show > $IPROUTESHOW
echo `date "$DATEFORMAT"` "$MSG_IPROUTEOK" >> $LOGFILE
return 0
fi
fi
onlinetestcmd () {
ping -c1 -W$TESTTIMEOUT $1 > /dev/null 2>&1
if [ $? -eq 0 ]; then
return 0
else
return 1
fi
#onlinetestcmd () {
#case "$(curl -s --max-time $TESTTIMEOUT -I $1 | sed 's/^[^ ]* *\([0-9]\).*/\1/; 1q')" in
# [23])
# return 0;;
# return 1;;
#esac
onlinetest () {
onlinetestcmd $TESTADDR1
! [ "`tail -n1 $LOGFILE | grep "$MSG_SUCCESS"`" ] && \
! [ "`tail -n1 $LOGFILE | grep "$MSG_VPNNOTACT"`" ] && \
! [ "`tail -n1 $LOGFILE | grep "Internet is reachable"`" ] && \
echo `date "$DATEFORMAT"` "$MSG_TESTOK1" >> $LOGFILE
return 0
else
echo `date "$DATEFORMAT"` "$MSG_TESTNOTOK1" >> $LOGFILE
onlinetestcmd $TESTADDR2
echo `date "$DATEFORMAT"` "$MSG_TESTOK2" >> $LOGFILE
return 0
else
echo `date "$DATEFORMAT"` "$MSG_TESTNOTOK2" >> $LOGFILE
onlinetestcmd $TESTADDR3
echo `date "$DATEFORMAT"` "$MSG_TESTOK3" >> $LOGFILE
return 0
else
echo `date "$DATEFORMAT"` "$MSG_TESTNOTOK3" >> $LOGFILE
onlinetestcmd $TESTADDR4
echo `date "$DATEFORMAT"` "$MSG_TESTOK4" >> $LOGFILE
return 0
else
echo `date "$DATEFORMAT"` "$MSG_TESTNOTOK4" >> $LOGFILE
onlinetestcmd $TESTADDR5
echo `date "$DATEFORMAT"` "$MSG_TESTOK5" >> $LOGFILE
return 0
else
echo `date "$DATEFORMAT"` "$MSG_TESTNOTOK5" >> $LOGFILE
! [ "`tail -n1 $LOGFILE | grep "$MSG_NOTONLINE"`" ] && \
echo `date "$DATEFORMAT"` "$MSG_NOTONLINE" >> $LOGFILE
pkill -x openvpn
#echo `date "$DATEFORMAT"` "$MSG_NETMANRESTART" >> $LOGFILE
#service $NETWORKMAN restart
sleep 1
return 1
fi
fi
fi
fi
fi
vpntest () {
if [ "`pgrep -x openvpn`" != "" ]; then
if [ "`cat $RESOLVCONF | grep $VPNDNSIP`" ]; then
if ! [ "`cat $RESOLVCONF | grep $ROUTERIP`" ]; then
echo `date "$DATEFORMAT"` "$MSG_SUCCESS" >> $LOGFILE
return 0
else
echo `date "$DATEFORMAT"` "$MSG_ROUTERSEEN" >> $LOGFILE
echo "" > $RESOLVCONF
return 1
fi
else
echo `date "$DATEFORMAT"` "$MSG_DNSNOTACT" >> $LOGFILE
pkill -x openvpn
sleep 1
$CMD
return 1
fi
else
echo `date "$DATEFORMAT"` "$MSG_VPNNOTACT" >> $LOGFILE
pkill -x openvpn
sleep 1
$CMD
return 1
fi
portknocker () {
if [ "$ENABLE_KNOCKD" == "1" ]; then
if [ "`ps ax | grep knockd | grep $IFACE`" == "" ]; then
pkill -x knockd
knockd -d -Dv -i $IFACE >/dev/null 2>&1
fi
fi
main () {
while true; do
messages
routetest && \
onlinetest && \
ln -sfn /etc/resolvconf/run/resolv.conf /etc/resolv.conf && \
vpntest && \
portknocker
sleep $DELAY
done
main
The Helper script to keep it running:
sudo nano /usr/local/bin/openvpn-reconnect-watchdog.sh
#!/bin/bash
while true; do
if [ "`ps ax | grep "/bin/bash /usr/local/bin/openvpn-reconnect.sh" | grep -v grep`" == "" ]; then
openvpn-reconnect.sh > /dev/null 2>&1 &
fi
sleep 3
done
Shortcut to start the script:
sudo nano /usr/local/bin/ostart
#!/bin/sh
ostop
sudo openvpn-reconnect-watchdog.sh > /dev/null 2>&1 &
Shortcut to stop the script and openvpn:
sudo nano /usr/local/bin/ostop
#!/bin/sh
for i in `pgrep -f "/bin/bash /usr/local/bin/openvpn-reconnect-watchdog.sh"`; do sudo kill $i; done
for i in `pgrep -f "/bin/bash /usr/local/bin/openvpn-reconnect.sh"`; do sudo kill $i; KILLED=1; done && \
[ "$KILLED" ] && echo `date +%Y-%m-%d\ %H:%M:%S` INFO:" "Script stopped by user. | sudo tee -a $LOGFILE > /dev/null
sudo pkill -x knockd
sudo pkill -x openvpn
The configuration file:
sudo nano /etc/default/openvpn-reconnect
### Configuration file for openvpn-reconnect.sh ###
# OpenVPN configuration to be used.
VPNCONFIG=/etc/openvpn/custom.conf
# OpenVPN command to run after performing online checks
CMD="openvpn --config $VPNCONFIG --daemon"
# The interface that connects to the internet
#IFACE=eth0
IFACE=wlan0
# Some user specific IPs
ROUTERIP=192.168.178.1
NORMALDNSIP=127.0.0.1
#NORMALDNSIP=192.168.178.1
VPNDNSIP=209.222.18.222
TESTADDR1=5.153.231.4
TESTADDR2=151.101.193.5
TESTADDR3=162.255.119.237
TESTADDR4=8.8.8.8
TESTADDR5=8.8.4.4
NETWORKMAN="connman"
# Time between tests in seconds.
DELAY=10
TESTTIMEOUT=10
# If using tools modifying resolv.conf like dnsmasq, set this accordingly
#RESOLVCONF=/var/run/dnsmasq/resolv.conf
RESOLVCONF=/etc/resolv.conf
# You can use "owatch" to monitor the logs
LOGFILE=/var/log/openvpn-reconnect.log
# Format for the date and time in the logfile
DATEFORMAT="+%Y-%m-%d %H:%M:%S"
# Enable port bypassing
ENABLE_BYPASSING=0
# Ports to be opened (bypasses the VPN connection):
# All traffic through these ports uses the original route of your interface _before_ OpenVPN was running.
# You will want this for web servers and other services that need a unique public IP address.
# Needs modified "update-resolv-conf" in /etc/openvpn
# Needs "vpn-bypass-start" and "vpn-bypass-stop" in /etc/openvpn
TCP_PORTS=""
UDP_PORTS=""
# Port knocker daemon installed? Must configure /etc/knockd.conf:
# You will need to set the following in knockd.conf to work with OpenVPN...
# Of course delete the corresponding port in the variable TCP_PORTS if you use port knocking.
# /etc/knockd.conf: (Example for SSH standard port 22)
# start_command = iptables -t mangle -A PREROUTING -s %IP% -p tcp --dport 22 -j MARK --set-mark 2
# cmd_timeout = 10
# stop_command = iptables -t mangle -A PREROUTING -s %IP% -p tcp --dport 22 -j MARK --set-mark 0/2
ENABLE_KNOCKD=0
# This is the backup of the original pre-VPN route used for port opening
# Will be created dynamically at boot and on interface name changes
IPROUTESHOW=/tmp/openvpn-reconnect.tmp
The up and down scripts for openvpn:
sudo nano /etc/openvpn/update-resolv-conf
#!/bin/bash
# Parses DHCP options from openvpn to update resolv.conf
# To use set as 'up' and 'down' script in your openvpn *.conf:
# up /etc/openvpn/update-resolv-conf
# down /etc/openvpn/update-resolv-conf
# Used snippets of resolvconf script by Thomas Hood and Chris Hanson.
# Licensed under the GNU GPL. See /usr/share/common-licenses/GPL.
# Example envs set from openvpn:
# foreign_option_1='dhcp-option DNS 193.43.27.132'
# foreign_option_2='dhcp-option DNS 193.43.27.133'
# foreign_option_3='dhcp-option DOMAIN be.bnc.ch'
[ -x /sbin/resolvconf ] || exit 0
[ "$script_type" ] || exit 0
[ "$dev" ] || exit 0
split_into_parts()
part1="$1"
part2="$2"
part3="$3"
case "$script_type" in
up)
NMSRVRS=""
SRCHS=""
for optionvarname in ${!foreign_option_*} ; do
option="${!optionvarname}"
echo "$option"
split_into_parts $option
if [ "$part1" = "dhcp-option" ] ; then
if [ "$part2" = "DNS" ] ; then
NMSRVRS="${NMSRVRS:+$NMSRVRS }$part3"
elif [ "$part2" = "DOMAIN" ] ; then
SRCHS="${SRCHS:+$SRCHS }$part3"
fi
fi
done
R=""
[ "$SRCHS" ] && R="search $SRCHS
for NS in $NMSRVRS ; do
R="${R}nameserver $NS
done
echo -n "$R" | /sbin/resolvconf -a "${dev}.openvpn"
if [ "$ENABLE_BYPASSING" == "1" ] || [ "$ENABLE_KNOCKD" == "1" ]; then
/etc/openvpn/vpn-bypass-start
fi
down)
/sbin/resolvconf -d "${dev}.openvpn"
/etc/openvpn/vpn-bypass-stop
echo nameserver $NORMALDNSIP > $RESOLVCONF
esac
sudo nano /etc/openvpn/vpn-bypass-start
#!/bin/bash
if [ "$ENABLE_BYPASSING" == "1" ]; then
[ "`cat $VPNCONFIG | grep tun`" ] && VPNMODE=tun0
[ "`cat $VPNCONFIG | grep tap`" ] && VPNMODE=tap0
export LC_ALL=C
#---SET KERNEL OPTIONS
sysctl -w net.ipv4.conf.$IFACE.rp_filter=0 1>/dev/null
sysctl -w net.ipv4.conf.$VPNMODE.rp_filter=0 1>/dev/null
sysctl -w net.ipv4.conf.all.rp_filter=0 1>/dev/null
sysctl -w net.ipv4.conf.default.rp_filter=0 1>/dev/null
sysctl -w net.ipv4.conf.lo.rp_filter=0 1>/dev/null
sysctl -w net.ipv4.ip_forward=1 1>/dev/null
sysctl -w net.ipv4.conf.all.forwarding=1 1>/dev/null
sysctl -w net.ipv4.conf.default.forwarding=1 1>/dev/null
sysctl -w net.ipv4.conf.$IFACE.forwarding=1 1>/dev/null
sysctl -w net.ipv4.conf.lo.forwarding=1 1>/dev/null
sysctl -w net.ipv4.conf.$VPNMODE.forwarding=1 1>/dev/null
sysctl -w net.ipv4.tcp_fwmark_accept=1 1>/dev/null
#sysctl -w net.ipv6.conf.all.forwarding=1 1>/dev/null
#sysctl -w net.ipv6.conf.default.forwarding=1 1>/dev/null
#sysctl -w net.ipv6.conf.$IFACE.forwarding=1 1>/dev/null
#sysctl -w net.ipv6.conf.lo.forwarding=1 1>/dev/null
#sysctl -w net.ipv6.conf.tun0.forwarding=1 1>/dev/null
#---CLEAR ALL FIREWALL RULES
iptables -F
iptables -t mangle -F
iptables -t nat -F
#ip route flush default dev $IFACE
#---FLSUH EXISTING TABLE 101 + cache
ip route flush table 101
ip route flush cache
#---DEL IF EXISTS AND ADD RULE
ip rule del fwmark 2 table 101 > /dev/null 2>&1
ip rule add fwmark 2 table 101
for i in "`cat $IPROUTESHOW | sed 's/^/ip route add table 101 /'`"; do bash -c "`echo "$i"`"; done
# SETTING MASQUERADE FOR OUTPUT
#iptables --table nat --append POSTROUTING -o $IFACE -j MASQUERADE
sed -i '/101 vpnbypass/d' /etc/iproute2/rt_tables
! [ "`grep "101 vpnbypass" /etc/iproute2/rt_tables`" ] && \
echo "101 vpnbypass" | /usr/bin/tee -a /etc/iproute2/rt_tables >/dev/null
# OPEN PORTS THROUGH TABLE 101
for i in $TCP_PORTS; do iptables -t mangle -A PREROUTING -p tcp --dport $i -j MARK --set-mark 2; done
for i in $UDP_PORTS; do iptables -t mangle -A PREROUTING -p udp --dport $i -j MARK --set-mark 2; done
echo Opened ports for bypassing VPN:
oports
fi
fi
sudo nano /etc/openvpn/vpn-bypass-stop
#!/bin/sh
# ---CLEAR ALL FIREWALL RULES
iptables -F
iptables -t nat -F
# ---FLSUH EXISTING TABLE 101 + cache
#--- DEL IF EXISTS AND ADD RULE
Script to show manually opened ports:
sudo nano /usr/local/bin/oports
#!/bin/bash
sudo /sbin/iptables -t mangle -L | \
grep MARK | grep 0x2 | awk '{ print $6 " " $7 }' | sed s/dpt://
Extra: A “Whats my IP?” shell script:
sudo nano /usr/local/bin/whatsmyip
#!/bin/bash
MYIP=`wget ipinfo.io/ip -qO -`
INFOS=`curl ipinfo.io/$MYIP 2>/dev/null`
echo -e "$INFOS\n"
Extra: A “Whats My IP?” Shortcut as a notification in Kodi:
To add it to the OSMC skins home screen: go to the Skin settings and add a custom shortcut with the command:
System.Exec(“whatsmyip-kodi”) -
For other skins use a launcher addon like advanced launcher and just write “whatsmyip-kodi” as command
sudo nano /usr/local/bin/whatsmyip-kodi
#!/bin/bash
whatsmyip > /tmp/whatsmyip.tmp
IP=`cat /tmp/whatsmyip.tmp | grep \"ip\": | awk '{ print $2 }' | sed 's/"//g; s/,//g'`
COUNTRY=`cat /tmp/whatsmyip.tmp | grep \"country\": | awk '{ print $2 }' | sed 's/"//g; s/,//g'`
ORG=`cat /tmp/whatsmyip.tmp | grep \"org\": | awk '{ print $3" "$4" "$5" "$6 }' | sed 's/"//g; s/,//g'`
SUM="$(echo $IP - $COUNTRY - $ORG)"
echo $IP
echo $COUNTRY
echo $ORG
echo $SUM
xbmc-send -a "Notification(Whats My IP?,$SUM)"
rm /tmp/whatsmyip.tmp
Set permissions:
sudo chmod +x /usr/local/bin/*
sudo chmod +x /usr/etc/openvpn/vpn-bypass-*
sudo chmod +x /usr/etc/openvpn/update-resolv-conf
2. disable the openvpn service!
sudo service openvpn stop
sudo systemctl disable openvpn
sudo update-rc.d openvpn remove
3. edit the configuration
please read carefully. Some things you can just leave like they are.
You must set the IP addresses to fit your settings like done in step 1 and VPN providers 1st or 2nd DNS IP address (google). See the descriptions in the config.
The test servers for ping you can leave or choose your own.
4. test the script
sudo openvpn-reconnect.sh &
kill later with “ostop”
Look for any errors. Try to solve them by double checking for mistakes in the configurations. Happened to me a lot.
If no error occurs the script itself runs fine. Now take a look at the logs:
cat /var/log/openvpn-reconnect.log
The optimal sequence looks like this:
2017-04-11 14:48:28 INFO: Script Started! Starting tests...
2017-04-11 14:48:28 WARNING: Restarting connman...
2017-04-11 14:48:31 NOTE: Trying to recover the routing table for interface wlan0...
2017-04-11 14:48:38 NOTE: Recreated /tmp/openvpn-reconnect.tmp with original routing table...
2017-04-11 14:48:38 NOTE: Internet is reachable at 1st try. Using interface wlan0
2017-04-11 14:48:39 WARNING: OpenVPN Service is not running! Restarting OpenVPN...
2017-04-11 14:49:02 SUCCESS: All fine! VPN is active.
Exit with Ctrl+C
5. If it works for you you will want to have the script running at boot time. Originally there was a nice init.d script but I found it much easier to just add a few lines to rc.local where the script gets started by a helper script which keeps it running:
/etc/rc.local:
exit 0
