Probably a silly question but please bear with me! I just wondered if it would cause any issues having the vero on its side? I’m thinking that as long as I ensure adequate circulation, it should be OK?
Yes should be fine
Won’t be a problem as long as it’s not stuffed between hot equipment (like an AVR).
fwiw, I use mine up side down ![]()
