Hi all, I’m not sure if this is a TV issue or OSMC issue - I have done some testing and found the following:
When playing a multi channel movie (2.1, 3.0, 3.1, 5.1 - doesn’t matter, anything above 2.0) on my Bauhn (ALDI) TV, the file opens and plays for a few seconds then quickly slows to a few fps then stops. There is no audio at all however the files appears to be still playing (elapsed time is increasing).
I have tried two different model Pis, a different HDMI cable and the same happens every time. If I change OSMC audio settings to 2.0 output and play a 5.1 file, it works fine. If I change OSMC audio settings to 2.1+ output and play a 2.0 file, it works fine. AAC/Dolby Digital makkes no difference.
Changing passthrough settins does not appear to make any difference.
Has anyone seen this before?
/Pred.
reproduce the issue
Hi thanks for the reply!
The log url is: https://paste.osmc.tv/uquborudit
I think it may be something to do with the TV’s sound capabilities not getting through. I would try rebooting the RPi with the TV on and see if that makes a difference. If not, maybe try a different input on your TV.
Hi all still have this problem. I’m convinced it’s the tv that is the culprit but not sure why (or how) this is the case. The latest osmc update did not make any change.
I might try using my receiver between the pi and the tv but will need to set up my old flirc or something as the amp does not work with CEC.
