Hi guys,
after i upgrated my raspberry 2 with “apt-get upgrade”, i have a crash-loop at boot, with sad face !
This is my log: http://paste.osmc.io/elucobemuj
thaks!
Hi guys,
thaks!
I suspect the log file you’ve provided is from a previous session, because it doesn’t show any problems - just a normal start up then a user initiated shutdown.
The most likely reason for a sad face and no (up to date) log file after an update is running right out of disk space. Check your free disk space with:
df -h
And post it here. Also post the output of:
sudo journalctl | paste-log
yeah, you are right for old log.
osmc@osmc:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 59G 34G 22G 62% /
devtmpfs 364M 0 364M 0% /dev
tmpfs 368M 0 368M 0% /dev/shm
tmpfs 368M 5.0M 363M 2% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 368M 0 368M 0% /sys/fs/cgroup
/dev/mmcblk0p1 240M 22M 218M 10% /boot
tmpfs 74M 0 74M 0% /run/user/1000
I have 22GB of free space, so i think that isn’t a problem of space…
osmc@osmc:~$ sudo journalctl | paste-log
mktemp: failed to create file via template '/tmp/tmp.XXXXXXXXXX': Read-only file system
-bash: $tmp: ambiguous redirect
http://paste.osmc.io/bitaqejotu
I think i have some problem with permission…
You have file system corruption which is causing your filesystem to mount read only. Boot with shift held down on a keyboard to run a filesystem scan which should repair it.
Prior to this problem have you had any unexpected freezes or have you been pulling the power plug without shutting down properly ?
Also what model of SD card are you using ? There were compatibility issues with a few models of SD card on the Pi 2 prior to RC3 so there might have been some pre-existing filesystem corruption due to that.
do it, but doesn’t work.
Yes, sometime i have pulling the power without shutting down the system.
My SD card is: SanDisk SDSDQL-064G-G35 Ultra MicroSDXC UHS-I, 64 GB, C10
What do you mean it doesn’t work ? A bit more detail please…
Do you mean that you don’t get a text screen running fsck ? Or that it runs but you still have problems when you reboot ?
You could try running it via SSH:
/sbin/fsck /
Then reboot with the reboot command.
Don’t do that then. You’ll get away with it most of the time but eventually you’ll cause the problem you’ve just seen.
After that i tried with “/sbin/fsck /” the system is booted correctly without sad-face, after 3 second the system is crashing with sad-face and after automatic reboot the system is booted correctly without sad-face! wow
This is the log:
http://paste.osmc.io/tukimiwosa
Don't do that then. You'll get away with it most of the time but eventually you'll cause the problem you've just seen.
Yes, you are right ! my fault
There are some tests that i need to do for to check some error in my system configuration? for precaution…
So kodi crashed again once after the fsck but is now working ok ?
exactly!
