I just got my new RPi3 and installed latest version of OSMC on it.
Configuration change ive made:
Switch on OMXPlayer for HWaccelleration, otherwise no video and very choppy audio, assume this is normal change everybody does?
Disable CEC as it interferes with my receiver
However, when playing a video (for instance an x264 mkv), i can’t control Kodi anymore, keyboard doesn’t do anything, it seems to switch off completely as caps/numlock lights also no not respond. Also my Yatse remote control app seems to think that the server is down and no remote control command is possible. While before starting the video everything works fine.
I’ve tried to change the power source from a phone charger to a new dedicated raspberry pi power source which i’ve ordered with the RPi3, but situation remains the same.
Before
13:45:59 30.322306 T:1957511728 NOTICE: DVDPlayer: Opening: smb://MEDIASERVER/Media/tvshows/file.mkv
Everything is fine
After that you see
13:47:14 105.712860 T:1707078640 NOTICE: ES: Client from 192.168.1.128 timed out
Which is probably my phone with yatse on it, but the usb keyboard also shuts down…
