Same here. Doesn’t seem to work.
You probably need to wait a bit longer for the mirrors to sync.
The drivers will be in the kernel package, rbp2-image-4.14.xx.x-osmc.
ok. Will retry later.
It can take an hour for the mirror to synchronise…
Works now. Great!
wlan0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 192.168.178.47 netmask 255.255.255.0 broadcast 192.168.178.255
ether 74:da:38:e8:2d:cb txqueuelen 1000 (Ethernet)
RX packets 312 bytes 80438 (78.5 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 334 bytes 71205 (69.5 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
wlan1: flags=-28669<UP,BROADCAST,MULTICAST,DYNAMIC> mtu 1500
ether b8:27:eb:85:c6:a0 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
osmc@osmc:~$ lsmod |grep 8812
rtl8812au 1396736 0
Thanks for confirming.
No sweat, thnx for the quick fix!
It works again!!!
Thanks a lot!!!
You’re very welcome, thanks for confirming this is now resolved.
