Yes I udpated yesterday… 15 mins before I started this thread. I do not see any rainbow screen… nothing at all. when I power the Pi, green LED blinks twice, red stays solid.
here is the directory structure of fat partition:
Volume in drive F has no label.
Volume Serial Number is 43D2-C0F8
Directory of F:\
06/07/2015 10:36 PM 95 preseed.cfg
09/23/2015 06:05 AM 3,810,376 start_x.elf
10/13/2015 01:15 PM 1,941,213 System.map-4.2.3-3-osmc
10/13/2015 02:00 PM 10,454 bcm2708-rpi-b-plus.dtb
10/13/2015 02:00 PM 10,175 bcm2708-rpi-b.dtb
09/23/2015 06:05 AM 9,597 fixup_x.dat
10/13/2015 11:26 AM 107,476 config-4.2.3-3-osmc
10/13/2015 05:32 PM <DIR> overlays
09/23/2015 06:05 AM 17,900 bootcode.bin
10/13/2015 05:32 PM 5,710,088 kernel.img
06/17/2015 07:10 PM 303 config.txt
01/01/1980 12:00 AM 63 cmdline.txt
01/01/1980 12:00 AM 2,246 install.log
10/13/2015 05:32 PM <DIR> dtb-4.2.3-3-osmc
10/13/2015 01:15 PM 5,710,048 vmlinuz-4.2.3-3-osmc
09/23/2015 06:05 AM 1,447 LICENCE.broadcom
14 File(s) 17,331,481 bytes
2 Dir(s) 233,436,160 bytes free
Is this a model older revision model B that uses the regular (larger) size SDcard? Are you certain it’s making good contact with all contacts in the reader slot?
didn’t help. I even copied the card to img file, then restored the img to a new SD card. still the same issue.
can I copy the fat partition from another PI?
Thanks. I just flashed fresh image from osmc installer on a new SD card, will update using dist-upgrade then copy the fat partition to the busted osmc SD card.
