mrtnn
29 June 2020 11:28
#1
Hi! Addons installation fails since this morning.
log says
2020-06-29 12:52:03.885 T:4065644544 DEBUG: Repository add-on repository.xbmc.org uses plain HTTP for add-on downloads in path http://download.osmc.tv/kodi/addons/leia - this is insecure and will make your Kodi installation vulnerable to attacks if enabled!
gmc
29 June 2020 11:34
#2
This is just a warning that the repo is not HTTPS and is not an error.
Can you please post full debug logs.
mrtnn
29 June 2020 11:45
#3
gmc
29 June 2020 13:16
#4
You are getting loads of timeouts to the download sites. Did you have any internet outages? (Possibly one of the osmc mirrors was done?)
CurlFile::Stat - Failed: Timeout was reached(28) for http://ftp.acc.umu.se/mirror/osmc.tv/osmc/download/kodi/addons/leia/metadata.common.imdb.com/metadata.common.imdb.com-3.1.5.zip
ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for http://download.osmc.tv/kodi/addons/leia/plugin.audio.dr.dk.netradio/icon.png
Maybe try again in a bit and see if you still have the same issue.
If you ssh to the device are you able to ping:
ping 8.8.8.8
ping download.osmc.tv
mrtnn
29 June 2020 13:52
#5
looks like it’s back to normal, ping is alright. Thanks for the fast support
