One thing I notice across some of the menus is the highlighted text when navigating could be a heavier weighted bold. Sometimes it’s hard to distinguish the selection. Notice it more so on the menus that are all white and gray-white.
When using the OSD when playing a movie and selecting audio options. Make a change and select “Set as default for all videos” the NO and YES prompt is too high and obscures part of the message
As an example if you navigate to the MY OSMC settings ->Settings-osmcsetting.updates the highlighted text looks very close to the same font weight and color as the unhighlighted text. maybe it’s just my old eyes, but a heavier weighted font may be better.
Is anyone had issues when scanning movies in out of 773 only 103 scan and then it stops and I have even if I re try to update it stops my data Base is fine as worked fine on alpha 2 and rasbmc
Honestly though, not to cause any offense but, as a noob, running an Alpha build might not be wise if what you are looking for is a stable system. This is not ready for public consumption as a daily driver. Also, until it reaches final release and the upgrade path is solidified, you will likely have to do complete re-installs to get updated/added features/functions/versions.
i am aware that its not a finished build and my daily use is rasbmc on another Rpi
but as a noob i still want to be able to help and give any input but if its not needed then i will just await the final build
I am having the same problem. Tried with a number of different USBs, with no success. Always the “Install failed: can’t mount root.” error… I’m trying now using just the SD.
Finally got some time to run the SD only install… Everything looks pretty good so far, UI is pretty quick and responsive and the Super OC seems stable. One thing I did notice was the video calibration screen needs some attention. Arrow for the Bottom Right has text reading Top Left and vice versa and the Square box and subtitle bar are present for both but once the text reads “Adjust the rectangle so it is perfectly square” the box disappears so some kinks to work on there.
@sam_nazarko - I made it to the shop and now have a USB to TTL Debug/Console cable if you’d like to get some more diagnostic info on the failing USB install… since I am not the only one having this problem (thanks and my apologies @hernanp).
@sam_nazarko Can you confirm that Wifi should in this version? A quick try this morning before I went to work showed that my Pi was not connected to the network.
In Alpha 2 I tried to compiled the kernel for use my usb device (dvt realtek 2832u chip) but was impossible for me, is possible that this usb device works in this new version? Can I compile a new kernel with this support?,
Jan 20 19:24:10 osmc preseed[513]: Second technology.Scan() failed.
Jan 20 19:24:20 osmc preseed[513]: Mapping SSID to service
Jan 20 19:24:20 osmc preseed[513]: Unable to find wireless network Carthago8_nomap```
We'll look at this.
