This is my dmesg result @sam_nazarko. I have another Wifi adapter that doesn’t work either, I will see what it outputs tonight for the same command.
osmc@osmc:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.3-osmc (root@compiler2) (gcc version 4.9.1 (Raspbian 4.9.1-19) ) #1 PREEMPT Sat Jan 17 04:24:47 UTC 2015
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: Reserved 8 MiB at 0x08800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 36864
[ 0.000000] free_area_init_node: node 0, pgdat c098ed1c, node_mem_map c86d4000
[ 0.000000] Normal zone: 288 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 36864 pages, LIFO batch:7
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 36576
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1024 bcm2708_fb.fbheight=768 bcm2708.boardrev=0x2 bcm2708.serial=0x7e36e7ff smsc95xx.macaddr=B8:27:EB:36:E7:FF bcm2708_fb.fbswap=1 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0xec00000 vc_mem.mem_size=0x10000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 127300K/147456K available (7277K kernel code, 356K rwdata, 1828K rodata, 324K init, 726K bss, 20156K reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
vmalloc : 0xc9800000 - 0xff000000 ( 856 MB)
lowmem : 0xc0000000 - 0xc9000000 ( 144 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc08ec684 (9106 kB)
.init : 0xc08ed000 - 0xc093e000 ( 324 kB)
.data : 0xc093e000 - 0xc099732c ( 357 kB)
.bss : 0xc099732c - 0xc0a4cba8 ( 727 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:522
[ 0.000024] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483648000ns
[ 0.000071] Switching to timer-based delay loop, resolution 1000ns
[ 0.000338] Console: colour dummy device 80x30
[ 0.000541] console [tty0] enabled
[ 0.000565] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.000589] pid_max: default: 32768 minimum: 301
[ 0.000943] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000969] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001915] Initializing cgroup subsys memory
[ 0.001966] Initializing cgroup subsys devices
[ 0.001994] Initializing cgroup subsys freezer
[ 0.002020] Initializing cgroup subsys net_cls
[ 0.002042] Initializing cgroup subsys blkio
[ 0.002131] CPU: Testing write buffer coherency: ok
[ 0.002211] ftrace: allocating 17796 entries in 53 pages
[ 0.094591] Setting up static identity map for 0x6b7f28 - 0x6b7f84
[ 0.097298] devtmpfs: initialized
[ 0.113853] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.117045] pinctrl core: initialized pinctrl subsystem
[ 0.117900] NET: Registered protocol family 16
[ 0.122864] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.144286] cpuidle: using governor ladder
[ 0.174336] cpuidle: using governor menu
[ 0.174558] bcm2708.uart_clock = 3000000
[ 0.174607] of_platform_populate failed: -22
[ 0.177624] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.177647] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.177684] mailbox: Broadcom VideoCore Mailbox driver
[ 0.177809] bcm2708_vcio: mailbox at f200b880
[ 0.177941] bcm_power: Broadcom power driver
[ 0.177963] bcm_power_open() -> 0
[ 0.177975] bcm_power_request(0, 8)
[ 0.678699] bcm_mailbox_read -> 00000080, 0
[ 0.678721] bcm_power_request -> 0
[ 0.678878] Serial: AMBA PL011 UART driver
[ 0.679084] uart-pl011 dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.737619] SCSI subsystem initialized
[ 0.737923] usbcore: registered new interface driver usbfs
[ 0.738049] usbcore: registered new interface driver hub
[ 0.738212] usbcore: registered new device driver usb
[ 0.739969] Switched to clocksource stc
[ 0.765469] FS-Cache: Loaded
[ 0.765854] CacheFiles: Loaded
[ 0.781234] NET: Registered protocol family 2
[ 0.782547] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.782616] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.782674] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.782757] TCP: reno registered
[ 0.782786] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.782820] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.783174] NET: Registered protocol family 1
[ 0.783820] RPC: Registered named UNIX socket transport module.
[ 0.783851] RPC: Registered udp transport module.
[ 0.783862] RPC: Registered tcp transport module.
[ 0.783873] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.784453] bcm2708_dma: DMA manager at f2007000
[ 0.784619] bcm2708_gpio: bcm2708_gpio_probe c094cd30
[ 0.785190] vc-mem: phys_addr:0x00000000 mem_base=0x0ec00000 mem_size:0x10000000(256 MiB)
[ 0.786757] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.786893] audit: initializing netlink subsys (disabled)
[ 0.786992] audit: type=2000 audit(0.720:1): initialized
[ 0.802173] VFS: Disk quotas dquot_6.5.2
[ 0.802554] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.805187] FS-Cache: Netfs 'nfs' registered for caching
[ 0.806869] NFS: Registering the id_resolver key type
[ 0.807009] Key type id_resolver registered
[ 0.807029] Key type id_legacy registered
[ 0.808337] msgmni has been set to 264
[ 0.811688] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.812104] io scheduler noop registered
[ 0.812801] io scheduler bfq registered (default)
[ 0.812820] BFQ I/O-scheduler version: v7r7
[ 0.814358] BCM2708FB: allocated DMA memory 48c00000
[ 0.814428] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 0.826550] Console: switching to colour frame buffer device 128x48
[ 0.836420] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 0.836854] uart-pl011 dev:f1: no DMA platform data
[ 0.837544] vc-cma: Videocore CMA driver
[ 0.837567] vc-cma: vc_cma_base = 0x00000000
[ 0.837580] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.837590] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.850790] brd: module loaded
[ 0.857461] loop: module loaded
[ 0.857908] vchiq: vchiq_init_state: slot_zero = 0xc8800000, is_master = 0
[ 0.859088] Loading iSCSI transport class v2.0-870.
[ 0.860666] usbcore: registered new interface driver smsc95xx
[ 0.860797] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.061283] Core Release: 2.80a
[ 1.061323] Setting default values for core params
[ 1.061350] Finished setting default values for core params
[ 1.261526] Using Buffer DMA mode
[ 1.261554] Periodic Transfer Interrupt Enhancement - disabled
[ 1.261567] Multiprocessor Interrupt Enhancement - disabled
[ 1.261581] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.261598] Dedicated Tx FIFOs mode
[ 1.262001] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xc8c14000 dma = 0x48c14000 len=9024
[ 1.262038] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 1.262068] dwc_otg: Microframe scheduler enabled
[ 1.262131] WARN::hcd_init:473: FIQ at 0xc04fb918
[ 1.262152] WARN::hcd_init:474: FIQ ASM at 0xc04fbbf4 length 36
[ 1.262183] WARN::hcd_init:500: MPHI regs_base at 0xc9806000
[ 1.262217] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.262283] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.262349] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.262390] Init: Port Power? op_state=1
[ 1.262401] Init: Power Port (0)
[ 1.262790] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.262816] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.262834] usb usb1: Product: DWC OTG Controller
[ 1.262849] usb usb1: Manufacturer: Linux 3.18.3-osmc dwc_otg_hcd
[ 1.262864] usb usb1: SerialNumber: bcm2708_usb
[ 1.263967] hub 1-0:1.0: USB hub found
[ 1.264069] hub 1-0:1.0: 1 port detected
[ 1.264739] dwc_otg: FIQ enabled
[ 1.264761] dwc_otg: NAK holdoff enabled
[ 1.264774] dwc_otg: FIQ split-transaction FSM enabled
[ 1.264832] Module dwc_common_port init
[ 1.265361] usbcore: registered new interface driver usb-storage
[ 1.265747] mousedev: PS/2 mouse device common for all mice
[ 1.267059] bcm2835-cpufreq: min=700000 max=850000
[ 1.267421] sdhci: Secure Digital Host Controller Interface driver
[ 1.267439] sdhci: Copyright(c) Pierre Ossman
[ 1.267659] DMA channels allocated for the MMC driver
[ 1.300030] Load BCM2835 MMC driver
[ 1.300404] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.300879] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.301097] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.301417] usbcore: registered new interface driver usbhid
[ 1.301436] usbhid: USB HID core driver
[ 1.301827] TCP: cubic registered
[ 1.301858] Initializing XFRM netlink socket
[ 1.301911] NET: Registered protocol family 17
[ 1.302117] Key type dns_resolver registered
[ 1.303527] registered taskstats version 1
[ 1.303824] vc-sm: Videocore shared memory driver
[ 1.303850] [vc_sm_connected_init]: start
[ 1.312547] [vc_sm_connected_init]: end - returning 0
[ 1.320285] Waiting for root device /dev/mmcblk0p2...
[ 1.370926] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.374767] mmc0: new high speed SDHC card at address e624
[ 1.375565] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[ 1.378547] mmcblk0: p1 p2
[ 1.460278] Indeed it is in host mode hprt0 = 00021501
[ 1.650207] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.650423] Indeed it is in host mode hprt0 = 00001101
[ 1.850512] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 1.850566] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.851909] hub 1-1:1.0: USB hub found
[ 1.852087] hub 1-1:1.0: 3 ports detected
[ 2.130141] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.230466] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.230499] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.233620] smsc95xx v1.0.4
[ 2.294483] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:36:e7:ff
[ 2.370183] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 2.473725] usb 1-1.2: New USB device found, idVendor=0c10, idProduct=0000
[ 2.473758] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.570147] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[ 2.699102] usb 1-1.3: New USB device found, idVendor=0510, idProduct=1004
[ 2.699136] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.699155] usb 1-1.3: Product: SEJIN USB Mini Trackball Keyboard
[ 2.699170] usb 1-1.3: Manufacturer: SEJIN
[ 2.727240] input: SEJIN SEJIN USB Mini Trackball Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:0510:1004.0001/input/input0
[ 2.728199] hid-generic 0003:0510:1004.0001: input,hidraw0: USB HID v1.10 Keyboard [SEJIN SEJIN USB Mini Trackball Keyboard] on usb-bcm2708_usb-1.3/input0
[ 2.748809] input: SEJIN SEJIN USB Mini Trackball Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:0510:1004.0002/input/input1
[ 2.750225] hid-generic 0003:0510:1004.0002: input,hidraw1: USB HID v1.10 Mouse [SEJIN SEJIN USB Mini Trackball Keyboard] on usb-bcm2708_usb-1.3/input1
[ 2.754537] EXT4-fs (mmcblk0p2): recovery complete
[ 2.757008] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.757108] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.764096] devtmpfs: mounted
[ 2.765210] Freeing unused kernel memory: 324K (c08ed000 - c093e000)
[ 3.108710] random: systemd urandom read with 83 bits of entropy available
[ 3.187177] NET: Registered protocol family 10
[ 3.923505] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 4.317117] fuse init (API version 7.23)
[ 5.160462] systemd-udevd[86]: starting version 215
[ 6.033943] random: nonblocking pool is initialized
[ 6.273136] bcm2708_i2c_init_pinmode(0,0)
[ 6.273170] bcm2708_i2c_init_pinmode(0,1)
[ 6.273492] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100000)
[ 6.300263] bcm2708_i2c_init_pinmode(1,2)
[ 6.300300] bcm2708_i2c_init_pinmode(1,3)
[ 6.301143] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100000)
[ 6.350471] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 6.352875] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 6.962978] Bluetooth: Core ver 2.19
[ 6.963147] NET: Registered protocol family 31
[ 6.963167] Bluetooth: HCI device and connection manager initialized
[ 6.963224] Bluetooth: HCI socket layer initialized
[ 6.963254] Bluetooth: L2CAP socket layer initialized
[ 6.963363] Bluetooth: SCO socket layer initialized
[ 7.003664] usbcore: registered new interface driver btusb
[ 7.021964] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 9.317501] pcm512x: probe of 1-004d failed with error -5
[ 9.318156] pcm512x: probe of 1-004c failed with error -5
[ 9.348728] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 10.048319] systemd-journald[69]: Received request to flush runtime journal from PID 1
[ 11.740768] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 14.020309] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.020341] Bluetooth: BNEP filters: protocol multicast
[ 14.020392] Bluetooth: BNEP socket layer initialized
[ 14.452908] Adding 131068k swap on /swap. Priority:-1 extents:1 across:131068k SSFS
[ 14.796358] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 14.797376] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.320105] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 16.343151] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 27.222920] Console: switching to colour dummy device 80x30
