since some days, my OSMC on my Raspberry Pi3B+ always ask me the stereoscopic mode when i play a video on a device or an IPTV video (when i play all type of videos in short).
In Settings/System/Video i have just disabled the stereoscopic mode but it always ask it and i don’t know why.
Can you help me?
Thanks in advance
Christian
reproduce the issue
upload the log set (all configs and logs!) either using the
this evening while i was following yor steps to send you the debug logs, i found this option:
Settings → Player → Video and i set the “3D Stereoscopic” from “Ask” to “Ignore”(see the photo)
Then, i tried to play some videos and now it seems it doesn’t ask for the 3D Stereoscopic settings, maybe it is the solution; i don’t know why suddenly it started to ask me this setting.
I will test it for some days and then if the problem isn’t solved i will follow your steps, in the other case we can consider this problem solved.
Thank you a lot
Christian
