./hyperiond -v
[hyperiond MAIN] <INFO> Selected configuration file: /root/.hyperion/config/hyperion_main.json
[hyperiond LOGGER] <WARNING> Logger settings overridden by command line argument
[hyperiond Core] <INFO> ColorAdjustment 'default' => [0; 159]
[hyperiond ComponentRegister] <INFO> Json/Proto forwarder: off
[hyperiond LedDevice] <INFO> LedDevice 'adalight' configured.
[hyperiond LedDevice] <INFO> Opening UART: /dev/ttyACM0
[hyperiond Core] <INFO> Creating linear smoothing
[hyperiond Smoothing] <INFO> smoothing cfg 0: interval: -1420738684 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 1: pause
[hyperiond ComponentRegister] <INFO> Smoothing: activated
[hyperiond ComponentRegister] <INFO> LED device: activated
[hyperiond Smoothing] <INFO> smoothing cfg 2: interval: -1420567704 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 3: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 4: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 5: interval: -1420552964 ms, settlingTime: 50 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 6: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 7: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 8: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 9: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 10: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 11: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 12: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 13: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 14: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 15: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 16: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 17: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 18: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 19: interval: -1420536804 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 20: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 21: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 22: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 23: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 24: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 25: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 26: interval: -1420528268 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 27: interval: -1420528572 ms, settlingTime: 50 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 28: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 29: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 30: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 31: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 32: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 33: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 34: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 35: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 36: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> smoothing cfg 37: interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond EFFECTENGINE] <INFO> 35 effects loaded from directory :/effects/
[hyperiond EFFECTENGINE] <INFO> 19 effect schemas loaded from directory :/effects/schema/
[hyperiond EFFECTENGINE] <INFO> 0 effects loaded from directory /root/.hyperion/custom-effects
[hyperiond MAIN] <INFO> Hyperion initialized
[hyperiond MAIN] <INFO> Json server created and started on port 19444
QObject::connect: No such slot ProtoServer::setVideoMode(VideoMode)
[hyperiond MAIN] <INFO> Proto server created and started on port 19445
[hyperiond ComponentRegister] <INFO> Boblight server: off
[hyperiond Core] <INFO> Register new input source named 'UDPLISTENER' for priority channel '200'
[hyperiond ComponentRegister] <INFO> UDP listener: off
[hyperiond ComponentRegister] <INFO> Blackborder detector: off
[hyperiond V4L2:auto] <INFO> Signal threshold set to: {12, 12, 12}
[hyperiond V4L2:auto] <INFO> Signal detection area set to: 0.250000,0.250000 x 0.750000,0.750000
[hyperiond ComponentRegister] <INFO> V4L capture device: off
[hyperiond MAIN] <INFO> set screen capture device to 'amlogic'
[hyperiond FRAMEBUFFERGRABBER] <INFO> Display opened with resolution: 1920x1080@32bit
[hyperiond Core] <INFO> Register new input source named 'AmLogic' for priority channel '250'
[hyperiond MAIN] <INFO> AMLOGIC grabber created and started
[hyperiond ComponentRegister] <INFO> Framegrabber: activated
[hyperiond MAIN] <INFO> Hyperion started
[hyperiond EFFECTENGINE] <INFO> run effect Rainbow swirl fast on channel 0
[hyperiond Core] <INFO> Register new input source named 'Rainbow swirl fast' for priority channel '0'
[hyperiond MAIN] <INFO> Inital foreground effect 'Rainbow swirl fast' started
[hyperiond EFFECTENGINE] <INFO> run effect Warm mood blobs on channel 254
[hyperiond Core] <INFO> Register new input source named 'Warm mood blobs' for priority channel '254'
[hyperiond MAIN] <INFO> Inital background effect 'Warm mood blobs' started
[hyperiond WEBSERVER] <ERROR> document_root '/home/osmc/.hyperion/webconfig' is invalid, set to default ':/webconfig'
[hyperiond WEBSERVER] <INFO> started on port 8090 name 'Hyperion WebConfig'
[hyperiond AMLOGICGRABBER] <INFO> FB mode
"Unexpected reply signature: got \"\", expected \"a{sv}\""
[hyperiond Smoothing] <INFO> set smoothing cfg: 25, interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond Smoothing] <INFO> set smoothing cfg: 0, interval: 0 ms, settlingTime: 40 ms, updateDelay: 0 frames
[hyperiond EFFECTENGINE] <INFO> effect finished
[hyperiond Core] <INFO> Unregister input source named 'Rainbow swirl fast' from priority register
Does this mean it works now? I have no lights to test with.
To test this update:
- Login via the command line
- Edit the file
/etc/apt/sources.list
- Add the following line:
- Run the following commands to update:
- Your system should have have received the update.
