Thanks @hissingshark for ur work. I tested today ur installer to build hyperion with custom commits and everything went easily as i expect
Tested on Buster and 4.9 kernel
I was just thinking about updating the Hyperion release but wasn’t unsure about the right procedure…
I recloned the repo, should I deinstall and then reinstall or can I go straight to “install from binaries”
I suppose when I deinstall I’ll loose my config?
Edit: nevermind - gave myself the answer … just reinstalled with option one - everything works
Hello. I just installed hyperion.ng on a fresh system (Vero 4k +) but lightberry is not working. I cannot login to the hyperion 8090 panel. Before the last update osmc everything was fine. Anyone help ??
Ok, I’m a noob, so I’ll write what I did:
Vero 4k + is reset (OSMC 2020.10-1)
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install git
git clone GitHub - hissingshark/hyperion-vero4k: Automated build and default install of Hyperion.ng on the Vero4K (OSMC)
cd hyperion-vero4k
sudo ./install.sh
Should it be like that? No error pops up, but the LEDs are off. Access to the <my.ip: 8090> page is not available.
Please help. I do not know what to do ![]()
The output of the
journalctl -u hyperion command
osmc@osmc:~$ journalctl -u hyperion
-- Logs begin at Wed 2020-11-11 22:00:21 CET, end at Wed 2020-11-11 22:01:58 CET
lis 11 22:00:25 osmc systemd[1]: Starting Hyperion ambient light systemd service
lis 11 22:00:25 osmc sudo[393]: osmc : TTY=unknown ; PWD=/usr/share/hyperion
lis 11 22:00:25 osmc sudo[393]: pam_unix(sudo:session): session opened for user
lis 11 22:00:25 osmc sudo[393]: pam_unix(sudo:session): session closed for user
lis 11 22:00:25 osmc sudo[475]: osmc : TTY=unknown ; PWD=/usr/share/hyperion
lis 11 22:00:25 osmc sudo[475]: pam_unix(sudo:session): session opened for user
lis 11 22:00:25 osmc sudo[475]: pam_unix(sudo:session): session closed for user
lis 11 22:00:25 osmc systemd[1]: Started Hyperion ambient light systemd service
lis 11 22:00:25 osmc systemd[1]: hyperion.service: Main process exited, code=exi
lis 11 22:00:25 osmc sudo[573]: osmc : TTY=unknown ; PWD=/usr/share/hyperion
lis 11 22:00:25 osmc sudo[573]: pam_unix(sudo:session): session opened for user
lis 11 22:00:25 osmc sudo[573]: pam_unix(sudo:session): session closed for user
lis 11 22:00:25 osmc sudo[605]: osmc : TTY=unknown ; PWD=/usr/share/hyperion
lis 11 22:00:25 osmc sudo[605]: pam_unix(sudo:session): session opened for user
lis 11 22:00:25 osmc sudo[605]: pam_unix(sudo:session): session closed for user
lis 11 22:00:26 osmc systemd[1]: hyperion.service: Failed with result 'exit-code
lis 11 22:00:28 osmc systemd[1]: hyperion.service: Service RestartSec=2s expired
lis 11 22:00:28 osmc systemd[1]: hyperion.service: Scheduled restart job, restar
lis 11 22:00:28 osmc systemd[1]: Stopped Hyperion ambient light systemd service
lis 11 22:00:28 osmc systemd[1]: Starting Hyperion ambient light systemd service
lis 11 22:00:28 osmc sudo[924]: osmc : TTY=unknown ; PWD=/usr/share/hyperion
lis 11 22:00:28 osmc sudo[924]: pam_unix(sudo:session): session opened for user
lines 1-23...skipping...
-- Logs begin at Wed 2020-11-11 22:00:21 CET, end at Wed 2020-11-11 22:01:58 CET. --
lis 11 22:00:25 osmc systemd[1]: Starting Hyperion ambient light systemd service for user osmc...
lis 11 22:00:25 osmc sudo[393]: osmc : TTY=unknown ; PWD=/usr/share/hyperion/bin ; USER=root ; COMMAND=/usr/bin/chmod 0666 /sys/module/amvdec_h265/parameters/double_write_mode
lis 11 22:00:25 osmc sudo[393]: pam_unix(sudo:session): session opened for user root by (uid=0)
lis 11 22:00:25 osmc sudo[393]: pam_unix(sudo:session): session closed for user root
lis 11 22:00:25 osmc sudo[475]: osmc : TTY=unknown ; PWD=/usr/share/hyperion/bin ; USER=root ; COMMAND=/usr/bin/chmod 0666 /sys/module/amvdec_vp9/parameters/double_write_mode
lis 11 22:00:25 osmc sudo[475]: pam_unix(sudo:session): session opened for user root by (uid=0)
lis 11 22:00:25 osmc sudo[475]: pam_unix(sudo:session): session closed for user root
lis 11 22:00:25 osmc systemd[1]: Started Hyperion ambient light systemd service for user osmc.
lis 11 22:00:25 osmc systemd[1]: hyperion.service: Main process exited, code=exited, status=127/n/a
lis 11 22:00:25 osmc sudo[573]: osmc : TTY=unknown ; PWD=/usr/share/hyperion/bin ; USER=root ; COMMAND=/usr/bin/chmod 0666 /sys/module/amvdec_h265/parameters/double_write_mode
lis 11 22:00:25 osmc sudo[573]: pam_unix(sudo:session): session opened for user root by (uid=0)
lis 11 22:00:25 osmc sudo[573]: pam_unix(sudo:session): session closed for user root
lis 11 22:00:25 osmc sudo[605]: osmc : TTY=unknown ; PWD=/usr/share/hyperion/bin ; USER=root ; COMMAND=/usr/bin/chmod 0666 /sys/module/amvdec_vp9/parameters/double_write_mode
lis 11 22:00:25 osmc sudo[605]: pam_unix(sudo:session): session opened for user root by (uid=0)
lis 11 22:00:25 osmc sudo[605]: pam_unix(sudo:session): session closed for user root
lis 11 22:00:26 osmc systemd[1]: hyperion.service: Failed with result 'exit-code'.
lis 11 22:00:28 osmc systemd[1]: hyperion.service: Service RestartSec=2s expired, scheduling restart.
lis 11 22:00:28 osmc systemd[1]: hyperion.service: Scheduled restart job, restart counter is at 1.
lis 11 22:00:28 osmc systemd[1]: Stopped Hyperion ambient light systemd service for user osmc.
lis 11 22:00:28 osmc systemd[1]: Starting Hyperion ambient light systemd service for user osmc...
lis 11 22:00:28 osmc sudo[924]: osmc : TTY=unknown ; PWD=/usr/share/hyperion/bin ; USER=root ; COMMAND=/usr/bin/chmod 0666 /sys/module/amvdec_h265/parameters/double_write_mode
lis 11 22:00:28 osmc sudo[924]: pam_unix(sudo:session): session opened for user root by (uid=0)
lis 11 22:00:28 osmc sudo[924]: pam_unix(sudo:session): session closed for user root
lis 11 22:00:28 osmc sudo[940]: osmc : TTY=unknown ; PWD=/usr/share/hyperion/bin ; USER=root ; COMMAND=/usr/bin/chmod 0666 /sys/module/amvdec_vp9/parameters/double_write_mode
lis 11 22:00:28 osmc sudo[940]: pam_unix(sudo:session): session opened for user root by (uid=0)
lis 11 22:00:28 osmc sudo[940]: pam_unix(sudo:session): session closed for user root
lis 11 22:00:28 osmc systemd[1]: Started Hyperion ambient light systemd service for user osmc.
lis 11 22:00:28 osmc systemd[1]: hyperion.service: Main process exited, code=exited, status=127/n/a
lis 11 22:00:28 osmc sudo[966]: osmc : TTY=unknown ; PWD=/usr/share/hyperion/bin ; USER=root ; COMMAND=/usr/bin/chmod 0666 /sys/module/amvdec_h265/parameters/double_write_mode
lis 11 22:00:28 osmc sudo[966]: pam_unix(sudo:session): session opened for user root by (uid=0)
lis 11 22:00:28 osmc sudo[966]: pam_unix(sudo:session): session closed for user root
lis 11 22:00:28 osmc sudo[983]: osmc : TTY=unknown ; PWD=/usr/share/hyperion/bin ; USER=root ; COMMAND=/usr/bin/chmod 0666 /sys/module/amvdec_vp9/parameters/double_write_mode
lis 11 22:00:28 osmc sudo[983]: pam_unix(sudo:session): session opened for user root by (uid=0)
lis 11 22:00:28 osmc sudo[983]: pam_unix(sudo:session): session closed for user root
lis 11 22:00:28 osmc systemd[1]: hyperion.service: Failed with result 'exit-code'.
lis 11 22:00:31 osmc systemd[1]: hyperion.service: Service RestartSec=2s expired, scheduling restart.
lis 11 22:00:31 osmc systemd[1]: hyperion.service: Scheduled restart job, restart counter is at 2.
lis 11 22:00:31 osmc systemd[1]: Stopped Hyperion ambient light systemd service for user osmc.
lis 11 22:00:31 osmc systemd[1]: Starting Hyperion ambient light systemd service for user osmc...
lis 11 22:00:31 osmc sudo[1010]: osmc : TTY=unknown ; PWD=/usr/share/hyperion/bin ; USER=root ; COMMAND=/usr/bin/chmod 0666 /sys/module/amvdec_h265/parameters/double_write_mode
lis 11 22:00:31 osmc sudo[1010]: pam_unix(sudo:session): session opened for user root by (uid=0)
lis 11 22:00:31 osmc sudo[1010]: pam_unix(sudo:session): session closed for user root
lis 11 22:00:31 osmc sudo[1026]: osmc : TTY=unknown ; PWD=/usr/share/hyperion/bin ; USER=root ; COMMAND=/usr/bin/chmod 0666 /sys/module/amvdec_vp9/parameters/double_write_mode
lis 11 22:00:31 osmc sudo[1026]: pam_unix(sudo:session): session opened for user root by (uid=0)
lis 11 22:00:31 osmc sudo[1026]: pam_unix(sudo:session): session closed for user root
lis 11 22:00:31 osmc systemd[1]: Started Hyperion ambient light systemd service for user osmc.
lis 11 22:00:31 osmc systemd[1]: hyperion.service: Main process exited, code=exited, status=127/n/a
lis 11 22:00:31 osmc sudo[1046]: osmc : TTY=unknown ; PWD=/usr/share/hyperion/bin ; USER=root ; COMMAND=/usr/bin/chmod 0666 /sys/module/amvdec_h265/parameters/double_write_mode
lis 11 22:00:31 osmc sudo[1046]: pam_unix(sudo:session): session opened for user root by (uid=0)
lis 11 22:00:31 osmc sudo[1046]: pam_unix(sudo:session): session closed for user root
lis 11 22:00:31 osmc sudo[1063]: osmc : TTY=unknown ; PWD=/usr/share/hyperion/bin ; USER=root ; COMMAND=/usr/bin/chmod 0666 /sys/module/amvdec_vp9/parameters/double_write_mode
lis 11 22:00:31 osmc sudo[1063]: pam_unix(sudo:session): session opened for user root by (uid=0)
lis 11 22:00:31 osmc sudo[1063]: pam_unix(sudo:session): session closed for user root
lis 11 22:00:31 osmc systemd[1]: hyperion.service: Failed with result 'exit-code'.
lis 11 22:00:33 osmc systemd[1]: hyperion.service: Service RestartSec=2s expired, scheduling restart.
lis 11 22:00:33 osmc systemd[1]: hyperion.service: Scheduled restart job, restart counter is at 3.
lis 11 22:00:33 osmc systemd[1]: Stopped Hyperion ambient light systemd service for user osmc.
lines 1-58
You might try running the binary directly to see if there’s any clue as to why the service is failing to start:
hyperiond --debug
If there are no errors there, you might try the checking the existence of the binaries:
cd /usr/share/hyperion/bin; ls -al
And any missing dependancies:
ldd *
osmc@osmc:~$ hyperiond --debug
hyperiond: error while loading shared libraries: libpcre16.so.3: cannot open shared object file: No such file or directory
osmc@osmc:~$ cd /usr/share/hyperion/bin; ls -al
razem 18056
drwxr-xr-x 2 root root 4096 lis 11 18:05 .
drwxr-xr-x 4 root root 4096 lis 11 18:05 …
-rwxr-xr-x 1 root root 817 lis 11 18:05 drmctl.sh
-rwxr-xr-x 1 root root 1824276 lis 11 18:05 flatc
-rwxr-xr-x 1 root root 16952 lis 11 18:05 flathash
-rwxr-xr-x 1 root root 2243084 lis 11 18:05 hyperion-aml
-rwxr-xr-x 1 root root 5948604 lis 11 18:05 hyperiond
-rwxr-xr-x 1 root root 2237384 lis 11 18:05 hyperion-framebuffer
-rwxr-xr-x 1 root root 2286720 lis 11 18:05 hyperion-remote
-rwxr-xr-x 1 root root 2332336 lis 11 18:05 hyperion-v4l2
-rwxr-xr-x 1 root root 1568244 lis 11 18:05 protoc
<osmc@osmc:/usr/share/hyperion/bin$ ldd *
drmctl.sh:
nie jest dynamicznym programem wykonywalnym
flatc:
libstdc++.so.6 => /lib/arm-linux-gnueabihf/libstdc++.so.6 (0xf7003000)
libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xf6f88000)
libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xf6f5f000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xf6e65000)
/lib/ld-linux-armhf.so.3 (0xaae31000)
flathash:
libstdc++.so.6 => /lib/arm-linux-gnueabihf/libstdc++.so.6 (0xf7021000)
libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xf6fa6000)
libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xf6f7d000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xf6e83000)
/lib/ld-linux-armhf.so.3 (0xaaff3000)
hyperion-aml:
libpcre16.so.3 => not found
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xf70e6000)
libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xf70c2000)
libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xf709d000)
libQt5SerialPort.so.5 => /lib/arm-linux-gnueabihf/libQt5SerialPort.so.5 (0xf707c000)
libQt5Sql.so.5 => /lib/arm-linux-gnueabihf/libQt5Sql.so.5 (0xf703a000)
libQt5Gui.so.5 => /lib/arm-linux-gnueabihf/libQt5Gui.so.5 (0xf6cc8000)
libQt5Network.so.5 => /lib/arm-linux-gnueabihf/libQt5Network.so.5 (0xf6b9d000)
libQt5Core.so.5 => /lib/arm-linux-gnueabihf/libQt5Core.so.5 (0xf6808000)
libpython3.7m.so.1.0 => /lib/arm-linux-gnueabihf/libpython3.7m.so.1.0 (0xf6484000)
libstdc++.so.6 => /lib/arm-linux-gnueabihf/libstdc++.so.6 (0xf6377000)
libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xf62fc000)
libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xf62d3000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xf61d9000)
/lib/ld-linux-armhf.so.3 (0xaaf45000)
libudev.so.1 => /lib/arm-linux-gnueabihf/libudev.so.1 (0xf61b1000)
libGLESv2.so.2 => /opt/vero3/lib/libGLESv2.so.2 (0xf6098000)
libpng16.so.16 => /lib/arm-linux-gnueabihf/libpng16.so.16 (0xf6066000)
libharfbuzz.so.0 => /lib/arm-linux-gnueabihf/libharfbuzz.so.0 (0xf5fa3000)
libicui18n.so.63 => /lib/arm-linux-gnueabihf/libicui18n.so.63 (0xf5dc5000)
libicuuc.so.63 => /lib/arm-linux-gnueabihf/libicuuc.so.63 (0xf5c84000)
libpcre2-16.so.0 => /lib/arm-linux-gnueabihf/libpcre2-16.so.0 (0xf5c1e000)
libdouble-conversion.so.1 => /lib/arm-linux-gnueabihf/libdouble-conversion.so.1 (0xf5bfe000)
libglib-2.0.so.0 => /lib/arm-linux-gnueabihf/libglib-2.0.so.0 (0xf5b1d000)
libexpat.so.1 => /lib/arm-linux-gnueabihf/libexpat.so.1 (0xf5ae8000)
libcrypt.so.1 => /lib/arm-linux-gnueabihf/libcrypt.so.1 (0xf5aa9000)
libutil.so.1 => /lib/arm-linux-gnueabihf/libutil.so.1 (0xf5a96000)
librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0xf5a80000)
libfreetype.so.6 => /lib/arm-linux-gnueabihf/libfreetype.so.6 (0xf5a02000)
libgraphite2.so.3 => /lib/arm-linux-gnueabihf/libgraphite2.so.3 (0xf59d8000)
libicudata.so.63 => /lib/arm-linux-gnueabihf/libicudata.so.63 (0xf3fdb000)
libpcre.so.3 => /lib/arm-linux-gnueabihf/libpcre.so.3 (0xf3f7c000)
hyperiond:
libQt5Widgets.so.5 => /lib/arm-linux-gnueabihf/libQt5Widgets.so.5 (0xf674a000)
libpython3.7m.so.1.0 => /lib/arm-linux-gnueabihf/libpython3.7m.so.1.0 (0xf63c6000)
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xf63b3000)
libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xf638f000)
libjpeg.so.62 => /lib/arm-linux-gnueabihf/libjpeg.so.62 (0xf6356000)
libQt5Sql.so.5 => /lib/arm-linux-gnueabihf/libQt5Sql.so.5 (0xf6314000)
libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xf62ef000)
libQt5SerialPort.so.5 => /lib/arm-linux-gnueabihf/libQt5SerialPort.so.5 (0xf62ce000)
libQt5Gui.so.5 => /lib/arm-linux-gnueabihf/libQt5Gui.so.5 (0xf5f5c000)
libQt5Network.so.5 => /lib/arm-linux-gnueabihf/libQt5Network.so.5 (0xf5e2f000)
libQt5Core.so.5 => /lib/arm-linux-gnueabihf/libQt5Core.so.5 (0xf5a9a000)
libstdc++.so.6 => /lib/arm-linux-gnueabihf/libstdc++.so.6 (0xf598f000)
libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xf5914000)
libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xf58eb000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xf57f1000)
/lib/ld-linux-armhf.so.3 (0xaaca3000)
libexpat.so.1 => /lib/arm-linux-gnueabihf/libexpat.so.1 (0xf57bc000)
libcrypt.so.1 => /lib/arm-linux-gnueabihf/libcrypt.so.1 (0xf577d000)
libutil.so.1 => /lib/arm-linux-gnueabihf/libutil.so.1 (0xf576a000)
libudev.so.1 => /lib/arm-linux-gnueabihf/libudev.so.1 (0xf5742000)
libGLESv2.so.2 => /opt/vero3/lib/libGLESv2.so.2 (0xf5627000)
libpng16.so.16 => /lib/arm-linux-gnueabihf/libpng16.so.16 (0xf55f5000)
libharfbuzz.so.0 => /lib/arm-linux-gnueabihf/libharfbuzz.so.0 (0xf5532000)
libicui18n.so.63 => /lib/arm-linux-gnueabihf/libicui18n.so.63 (0xf5354000)
libicuuc.so.63 => /lib/arm-linux-gnueabihf/libicuuc.so.63 (0xf5213000)
libpcre2-16.so.0 => /lib/arm-linux-gnueabihf/libpcre2-16.so.0 (0xf51af000)
libdouble-conversion.so.1 => /lib/arm-linux-gnueabihf/libdouble-conversion.so.1 (0xf518f000)
libglib-2.0.so.0 => /lib/arm-linux-gnueabihf/libglib-2.0.so.0 (0xf50ae000)
librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0xf5098000)
libfreetype.so.6 => /lib/arm-linux-gnueabihf/libfreetype.so.6 (0xf501a000)
libgraphite2.so.3 => /lib/arm-linux-gnueabihf/libgraphite2.so.3 (0xf4fee000)
libicudata.so.63 => /lib/arm-linux-gnueabihf/libicudata.so.63 (0xf35f1000)
libpcre.so.3 => /lib/arm-linux-gnueabihf/libpcre.so.3 (0xf3594000)
hyperion-framebuffer:
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xf6e2e000)
libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xf6e0a000)
libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xf6de5000)
libQt5SerialPort.so.5 => /lib/arm-linux-gnueabihf/libQt5SerialPort.so.5 (0xf6dc4000)
libQt5Sql.so.5 => /lib/arm-linux-gnueabihf/libQt5Sql.so.5 (0xf6d82000)
libQt5Gui.so.5 => /lib/arm-linux-gnueabihf/libQt5Gui.so.5 (0xf6a10000)
libQt5Network.so.5 => /lib/arm-linux-gnueabihf/libQt5Network.so.5 (0xf68e5000)
libQt5Core.so.5 => /lib/arm-linux-gnueabihf/libQt5Core.so.5 (0xf6550000)
libpython3.7m.so.1.0 => /lib/arm-linux-gnueabihf/libpython3.7m.so.1.0 (0xf61cc000)
libstdc++.so.6 => /lib/arm-linux-gnueabihf/libstdc++.so.6 (0xf60bf000)
libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xf6044000)
libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xf601b000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xf5f21000)
/lib/ld-linux-armhf.so.3 (0xaaafe000)
libudev.so.1 => /lib/arm-linux-gnueabihf/libudev.so.1 (0xf5ef9000)
libGLESv2.so.2 => /opt/vero3/lib/libGLESv2.so.2 (0xf5de0000)
libpng16.so.16 => /lib/arm-linux-gnueabihf/libpng16.so.16 (0xf5dae000)
libharfbuzz.so.0 => /lib/arm-linux-gnueabihf/libharfbuzz.so.0 (0xf5ceb000)
libicui18n.so.63 => /lib/arm-linux-gnueabihf/libicui18n.so.63 (0xf5b0d000)
libicuuc.so.63 => /lib/arm-linux-gnueabihf/libicuuc.so.63 (0xf59cc000)
libpcre2-16.so.0 => /lib/arm-linux-gnueabihf/libpcre2-16.so.0 (0xf5966000)
libdouble-conversion.so.1 => /lib/arm-linux-gnueabihf/libdouble-conversion.so.1 (0xf5946000)
libglib-2.0.so.0 => /lib/arm-linux-gnueabihf/libglib-2.0.so.0 (0xf5865000)
libexpat.so.1 => /lib/arm-linux-gnueabihf/libexpat.so.1 (0xf5830000)
libcrypt.so.1 => /lib/arm-linux-gnueabihf/libcrypt.so.1 (0xf57f1000)
libutil.so.1 => /lib/arm-linux-gnueabihf/libutil.so.1 (0xf57de000)
librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0xf57c8000)
libfreetype.so.6 => /lib/arm-linux-gnueabihf/libfreetype.so.6 (0xf574a000)
libgraphite2.so.3 => /lib/arm-linux-gnueabihf/libgraphite2.so.3 (0xf5720000)
libicudata.so.63 => /lib/arm-linux-gnueabihf/libicudata.so.63 (0xf3d23000)
libpcre.so.3 => /lib/arm-linux-gnueabihf/libpcre.so.3 (0xf3cc4000)
hyperion-remote:
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xf7145000)
libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xf7121000)
libpython3.7m.so.1.0 => /lib/arm-linux-gnueabihf/libpython3.7m.so.1.0 (0xf6d9d000)
libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xf6d78000)
libQt5SerialPort.so.5 => /lib/arm-linux-gnueabihf/libQt5SerialPort.so.5 (0xf6d57000)
libQt5Sql.so.5 => /lib/arm-linux-gnueabihf/libQt5Sql.so.5 (0xf6d15000)
libQt5Gui.so.5 => /lib/arm-linux-gnueabihf/libQt5Gui.so.5 (0xf69a3000)
libQt5Network.so.5 => /lib/arm-linux-gnueabihf/libQt5Network.so.5 (0xf6878000)
libQt5Core.so.5 => /lib/arm-linux-gnueabihf/libQt5Core.so.5 (0xf64e3000)
libstdc++.so.6 => /lib/arm-linux-gnueabihf/libstdc++.so.6 (0xf63d6000)
libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xf635b000)
libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xf6332000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xf6238000)
/lib/ld-linux-armhf.so.3 (0xaafe0000)
libexpat.so.1 => /lib/arm-linux-gnueabihf/libexpat.so.1 (0xf6203000)
libcrypt.so.1 => /lib/arm-linux-gnueabihf/libcrypt.so.1 (0xf61c4000)
libutil.so.1 => /lib/arm-linux-gnueabihf/libutil.so.1 (0xf61b1000)
libudev.so.1 => /lib/arm-linux-gnueabihf/libudev.so.1 (0xf6189000)
libGLESv2.so.2 => /opt/vero3/lib/libGLESv2.so.2 (0xf6070000)
libpng16.so.16 => /lib/arm-linux-gnueabihf/libpng16.so.16 (0xf603e000)
libharfbuzz.so.0 => /lib/arm-linux-gnueabihf/libharfbuzz.so.0 (0xf5f79000)
libicui18n.so.63 => /lib/arm-linux-gnueabihf/libicui18n.so.63 (0xf5d9b000)
libicuuc.so.63 => /lib/arm-linux-gnueabihf/libicuuc.so.63 (0xf5c5a000)
libpcre2-16.so.0 => /lib/arm-linux-gnueabihf/libpcre2-16.so.0 (0xf5bf6000)
libdouble-conversion.so.1 => /lib/arm-linux-gnueabihf/libdouble-conversion.so.1 (0xf5bd6000)
libglib-2.0.so.0 => /lib/arm-linux-gnueabihf/libglib-2.0.so.0 (0xf5af5000)
librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0xf5adf000)
libfreetype.so.6 => /lib/arm-linux-gnueabihf/libfreetype.so.6 (0xf5a61000)
libgraphite2.so.3 => /lib/arm-linux-gnueabihf/libgraphite2.so.3 (0xf5a37000)
libicudata.so.63 => /lib/arm-linux-gnueabihf/libicudata.so.63 (0xf403a000)
libpcre.so.3 => /lib/arm-linux-gnueabihf/libpcre.so.3 (0xf3fdb000)
hyperion-v4l2:
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xf73d2000)
libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xf73ae000)
libjpeg.so.62 => /lib/arm-linux-gnueabihf/libjpeg.so.62 (0xf7375000)
libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xf7350000)
libQt5SerialPort.so.5 => /lib/arm-linux-gnueabihf/libQt5SerialPort.so.5 (0xf732f000)
libQt5Sql.so.5 => /lib/arm-linux-gnueabihf/libQt5Sql.so.5 (0xf72ed000)
libQt5Gui.so.5 => /lib/arm-linux-gnueabihf/libQt5Gui.so.5 (0xf6f7b000)
libQt5Network.so.5 => /lib/arm-linux-gnueabihf/libQt5Network.so.5 (0xf6e50000)
libQt5Core.so.5 => /lib/arm-linux-gnueabihf/libQt5Core.so.5 (0xf6abb000)
libpython3.7m.so.1.0 => /lib/arm-linux-gnueabihf/libpython3.7m.so.1.0 (0xf6735000)
libstdc++.so.6 => /lib/arm-linux-gnueabihf/libstdc++.so.6 (0xf662a000)
libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xf65af000)
libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xf6586000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xf648c000)
/lib/ld-linux-armhf.so.3 (0xab141000)
libudev.so.1 => /lib/arm-linux-gnueabihf/libudev.so.1 (0xf6464000)
libGLESv2.so.2 => /opt/vero3/lib/libGLESv2.so.2 (0xf634b000)
libpng16.so.16 => /lib/arm-linux-gnueabihf/libpng16.so.16 (0xf6319000)
libharfbuzz.so.0 => /lib/arm-linux-gnueabihf/libharfbuzz.so.0 (0xf6256000)
libicui18n.so.63 => /lib/arm-linux-gnueabihf/libicui18n.so.63 (0xf6078000)
libicuuc.so.63 => /lib/arm-linux-gnueabihf/libicuuc.so.63 (0xf5f35000)
libpcre2-16.so.0 => /lib/arm-linux-gnueabihf/libpcre2-16.so.0 (0xf5ed1000)
libdouble-conversion.so.1 => /lib/arm-linux-gnueabihf/libdouble-conversion.so.1 (0xf5eb1000)
libglib-2.0.so.0 => /lib/arm-linux-gnueabihf/libglib-2.0.so.0 (0xf5dd0000)
libexpat.so.1 => /lib/arm-linux-gnueabihf/libexpat.so.1 (0xf5d9b000)
libcrypt.so.1 => /lib/arm-linux-gnueabihf/libcrypt.so.1 (0xf5d5c000)
libutil.so.1 => /lib/arm-linux-gnueabihf/libutil.so.1 (0xf5d49000)
librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0xf5d33000)
libfreetype.so.6 => /lib/arm-linux-gnueabihf/libfreetype.so.6 (0xf5cb5000)
libgraphite2.so.3 => /lib/arm-linux-gnueabihf/libgraphite2.so.3 (0xf5c8b000)
libicudata.so.63 => /lib/arm-linux-gnueabihf/libicudata.so.63 (0xf428c000)
libpcre.so.3 => /lib/arm-linux-gnueabihf/libpcre.so.3 (0xf422f000)
protoc:
libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xf6f24000)
libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xf6f00000)
libstdc++.so.6 => /lib/arm-linux-gnueabihf/libstdc++.so.6 (0xf6df5000)
libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xf6d7a000)
libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xf6d51000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xf6c57000)
/lib/ld-linux-armhf.so.3 (0xaab6a000)
Unfortunately, I have no idea what that means
Try:
sudo apt-get install ibpcre16-3
Thanks Tom.
P.S.
I’ve tidy up your posts to make them easier to read.
Thanks Tom.
As Tom Doyle says, the output highlights one missing library:
libpcre16.so.3
An easy fix for you. It’s odd this is only an issue now though. Perhaps a Buster thing. You’d have been fine if you were building from source. Installing from binary is the issue. I’m fixing that in the installer now.
FYI - If you didn’t spot the typo in the command it’s:
sudo apt-get install libpcre16-3
Thanks a lot . In fact, after installing this library, the server started up. I have access to the web-Gui, but the LEDs do not light up. I tried the smartphone application, it also synchronizes, but the LEDs are not lit. I have no idea what to do. I have uploaded the soft to the usb converter again, but it does nothing. Any advice?Config
Sorry I couldn’t read the config as shared.
Perhaps use the osmc-paste? Also, where are you getting this file from? I thought settings were stored in a database these days.
You could also paste the output from hyperiond --debug again, to see if that indicates where it is has fallen down
Ok, I have reset Vero again. I compiled hyperion.ng from source. I had internet access for a while, but now I don’t. The LEDs were lit for a while (129 should). Config that I managed to download from web gui:
"backgroundEffect": {
"color": [
255,
138,
0
"effect": "Warm mood blobs",
"enable": true,
"type": "effect"
"blackborderdetector": {
"blurRemoveCnt": 1,
"borderFrameCnt": 50,
"enable": true,
"maxInconsistentCnt": 10,
"mode": "default",
"threshold": 5,
"unknownFrameCnt": 600
"boblightServer": {
"enable": false,
"port": 19333,
"priority": 128
"color": {
"channelAdjustment": [
"backlightColored": false,
"backlightThreshold": 0,
"blue": [
0,
0,
255
"brightness": 100,
"brightnessCompensation": 100,
"cyan": [
0,
255,
255
"gammaBlue": 1.5,
"gammaGreen": 1.5,
"gammaRed": 1.5,
"green": [
0,
255,
0
"id": "default",
"leds": "*",
"magenta": [
255,
0,
255
"red": [
255,
0,
0
"white": [
255,
255,
255
"yellow": [
255,
255,
0
"imageToLedMappingType": "multicolor_mean"
"device": {
"colorOrder": "bgr",
"delayAfterConnect": 1500,
"hardwareLedCount": 1,
"latchTime": 15,
"lightberry_apa102_mode": true,
"output": "/dev/ttyACM0",
"rate": 1000000,
"rewriteTime": 5000,
"type": "adalight"
"effects": {
"disable": [
"paths": [
"$ROOT/custom-effects"
"flatbufServer": {
"enable": true,
"port": 19400,
"timeout": 5
"foregroundEffect": {
"color": [
0,
0,
255
"duration_ms": 3000,
"effect": "Rainbow swirl fast",
"enable": true,
"type": "effect"
"forwarder": {
"enable": false,
"flat": [
"127.0.0.1:19401"
"json": [
"127.0.0.1:19446"
"framegrabber": {
"cropBottom": 0,
"cropLeft": 0,
"cropRight": 0,
"cropTop": 0,
"device": "/dev/fb0",
"frequency_Hz": 10,
"height": 45,
"pixelDecimation": 8,
"type": "auto",
"width": 80
"general": {
"name": "My Hyperion Config",
"showOptHelp": true,
"watchedVersionBranch": "Stable"
"grabberV4L2": {
"blueSignalThreshold": 5,
"cropBottom": 0,
"cropLeft": 0,
"cropRight": 0,
"cropTop": 0,
"device": "auto",
"fps": 15,
"greenSignalThreshold": 5,
"height": 0,
"redSignalThreshold": 5,
"sDHOffsetMax": 0.75,
"sDHOffsetMin": 0.25,
"sDVOffsetMax": 0.75,
"sDVOffsetMin": 0.25,
"signalDetection": false,
"sizeDecimation": 8,
"standard": "NO_CHANGE",
"width": 0
"instCapture": {
"systemEnable": true,
"systemPriority": 250,
"v4lEnable": false,
"v4lPriority": 240
"jsonServer": {
"port": 19444
"ledConfig": {
"classic": {
"bottom": 41,
"edgegap": 0,
"glength": 0,
"gpos": 0,
"hdepth": 8,
"left": 24,
"overlap": 0,
"position": 85,
"reverse": true,
"right": 23,
"top": 41,
"vdepth": 5
"matrix": {
"cabling": "snake",
"ledshoriz": 10,
"ledsvert": 10,
"start": "top-left"
"leds": [
"hmax": 0.5122,
"hmin": 0.4878,
"vmax": 1,
"vmin": 0.92
"hmax": 0.5366,
"hmin": 0.5122,
"vmax": 1,
"vmin": 0.92
"hmax": 0.561,
"hmin": 0.5366,
"vmax": 1,
"vmin": 0.92
"hmax": 0.5854,
"hmin": 0.561,
"vmax": 1,
"vmin": 0.92
"hmax": 0.6098,
"hmin": 0.5854,
"vmax": 1,
"vmin": 0.92
"hmax": 0.6341,
"hmin": 0.6098,
"vmax": 1,
"vmin": 0.92
"hmax": 0.6585,
"hmin": 0.6341,
"vmax": 1,
"vmin": 0.92
"hmax": 0.6829,
"hmin": 0.6585,
"vmax": 1,
"vmin": 0.92
"hmax": 0.7073,
"hmin": 0.6829,
"vmax": 1,
"vmin": 0.92
"hmax": 0.7317,
"hmin": 0.7073,
"vmax": 1,
"vmin": 0.92
"hmax": 0.7561,
"hmin": 0.7317,
"vmax": 1,
"vmin": 0.92
"hmax": 0.7805,
"hmin": 0.7561,
"vmax": 1,
"vmin": 0.92
"hmax": 0.8049,
"hmin": 0.7805,
"vmax": 1,
"vmin": 0.92
"hmax": 0.8293,
"hmin": 0.8049,
"vmax": 1,
"vmin": 0.92
"hmax": 0.8537,
"hmin": 0.8293,
"vmax": 1,
"vmin": 0.92
"hmax": 0.878,
"hmin": 0.8537,
"vmax": 1,
"vmin": 0.92
"hmax": 0.9024,
"hmin": 0.878,
"vmax": 1,
"vmin": 0.92
"hmax": 0.9268,
"hmin": 0.9024,
"vmax": 1,
"vmin": 0.92
"hmax": 0.9512,
"hmin": 0.9268,
"vmax": 1,
"vmin": 0.92
"hmax": 0.9756,
"hmin": 0.9512,
"vmax": 1,
"vmin": 0.92
"hmax": 1,
"hmin": 0.9756,
"vmax": 1,
"vmin": 0.92
"hmax": 1,
"hmin": 0.95,
"vmax": 1,
"vmin": 0.9565
"hmax": 1,
"hmin": 0.95,
"vmax": 0.9565,
"vmin": 0.913
"hmax": 1,
"hmin": 0.95,
"vmax": 0.913,
"vmin": 0.8696
"hmax": 1,
"hmin": 0.95,
"vmax": 0.8696,
"vmin": 0.8261
"hmax": 1,
"hmin": 0.95,
"vmax": 0.8261,
"vmin": 0.7826
"hmax": 1,
"hmin": 0.95,
"vmax": 0.7826,
"vmin": 0.7391
"hmax": 1,
"hmin": 0.95,
"vmax": 0.7391,
"vmin": 0.6957
"hmax": 1,
"hmin": 0.95,
"vmax": 0.6957,
"vmin": 0.6522
"hmax": 1,
"hmin": 0.95,
"vmax": 0.6522,
"vmin": 0.6087
"hmax": 1,
"hmin": 0.95,
"vmax": 0.6087,
"vmin": 0.5652
"hmax": 1,
"hmin": 0.95,
"vmax": 0.5652,
"vmin": 0.5217
"hmax": 1,
"hmin": 0.95,
"vmax": 0.5217,
"vmin": 0.4783
"hmax": 1,
"hmin": 0.95,
"vmax": 0.4783,
"vmin": 0.4348
"hmax": 1,
"hmin": 0.95,
"vmax": 0.4348,
"vmin": 0.3913
"hmax": 1,
"hmin": 0.95,
"vmax": 0.3913,
"vmin": 0.3478
"hmax": 1,
"hmin": 0.95,
"vmax": 0.3478,
"vmin": 0.3043
"hmax": 1,
"hmin": 0.95,
"vmax": 0.3043,
"vmin": 0.2609
"hmax": 1,
"hmin": 0.95,
"vmax": 0.2609,
"vmin": 0.2174
"hmax": 1,
"hmin": 0.95,
"vmax": 0.2174,
"vmin": 0.1739
"hmax": 1,
"hmin": 0.95,
"vmax": 0.1739,
"vmin": 0.1304
"hmax": 1,
"hmin": 0.95,
"vmax": 0.1304,
"vmin": 0.087
"hmax": 1,
"hmin": 0.95,
"vmax": 0.087,
"vmin": 0.0435
"hmax": 1,
"hmin": 0.95,
"vmax": 0.0435,
"vmin": 0
"hmax": 1,
"hmin": 0.9756,
"vmax": 0.08,
"vmin": 0
"hmax": 0.9756,
"hmin": 0.9512,
"vmax": 0.08,
"vmin": 0
"hmax": 0.9512,
"hmin": 0.9268,
"vmax": 0.08,
"vmin": 0
"hmax": 0.9268,
"hmin": 0.9024,
"vmax": 0.08,
"vmin": 0
"hmax": 0.9024,
"hmin": 0.878,
"vmax": 0.08,
"vmin": 0
"hmax": 0.878,
"hmin": 0.8537,
"vmax": 0.08,
"vmin": 0
"hmax": 0.8537,
"hmin": 0.8293,
"vmax": 0.08,
"vmin": 0
"hmax": 0.8293,
"hmin": 0.8049,
"vmax": 0.08,
"vmin": 0
"hmax": 0.8049,
"hmin": 0.7805,
"vmax": 0.08,
"vmin": 0
"hmax": 0.7805,
"hmin": 0.7561,
"vmax": 0.08,
"vmin": 0
"hmax": 0.7561,
"hmin": 0.7317,
"vmax": 0.08,
"vmin": 0
"hmax": 0.7317,
"hmin": 0.7073,
"vmax": 0.08,
"vmin": 0
"hmax": 0.7073,
"hmin": 0.6829,
"vmax": 0.08,
"vmin": 0
"hmax": 0.6829,
"hmin": 0.6585,
"vmax": 0.08,
"vmin": 0
"hmax": 0.6585,
"hmin": 0.6341,
"vmax": 0.08,
"vmin": 0
"hmax": 0.6341,
"hmin": 0.6098,
"vmax": 0.08,
"vmin": 0
"hmax": 0.6098,
"hmin": 0.5854,
"vmax": 0.08,
"vmin": 0
"hmax": 0.5854,
"hmin": 0.561,
"vmax": 0.08,
"vmin": 0
"hmax": 0.561,
"hmin": 0.5366,
"vmax": 0.08,
"vmin": 0
"hmax": 0.5366,
"hmin": 0.5122,
"vmax": 0.08,
"vmin": 0
"hmax": 0.5122,
"hmin": 0.4878,
"vmax": 0.08,
"vmin": 0
"hmax": 0.4878,
"hmin": 0.4634,
"vmax": 0.08,
"vmin": 0
"hmax": 0.4634,
"hmin": 0.439,
"vmax": 0.08,
"vmin": 0
"hmax": 0.439,
"hmin": 0.4146,
"vmax": 0.08,
"vmin": 0
"hmax": 0.4146,
"hmin": 0.3902,
"vmax": 0.08,
"vmin": 0
"hmax": 0.3902,
"hmin": 0.3659,
"vmax": 0.08,
"vmin": 0
"hmax": 0.3659,
"hmin": 0.3415,
"vmax": 0.08,
"vmin": 0
"hmax": 0.3415,
"hmin": 0.3171,
"vmax": 0.08,
"vmin": 0
"hmax": 0.3171,
"hmin": 0.2927,
"vmax": 0.08,
"vmin": 0
"hmax": 0.2927,
"hmin": 0.2683,
"vmax": 0.08,
"vmin": 0
"hmax": 0.2683,
"hmin": 0.2439,
"vmax": 0.08,
"vmin": 0
"hmax": 0.2439,
"hmin": 0.2195,
"vmax": 0.08,
"vmin": 0
"hmax": 0.2195,
"hmin": 0.1951,
"vmax": 0.08,
"vmin": 0
"hmax": 0.1951,
"hmin": 0.1707,
"vmax": 0.08,
"vmin": 0
"hmax": 0.1707,
"hmin": 0.1463,
"vmax": 0.08,
"vmin": 0
"hmax": 0.1463,
"hmin": 0.122,
"vmax": 0.08,
"vmin": 0
"hmax": 0.122,
"hmin": 0.0976,
"vmax": 0.08,
"vmin": 0
"hmax": 0.0976,
"hmin": 0.0732,
"vmax": 0.08,
"vmin": 0
"hmax": 0.0732,
"hmin": 0.0488,
"vmax": 0.08,
"vmin": 0
"hmax": 0.0488,
"hmin": 0.0244,
"vmax": 0.08,
"vmin": 0
"hmax": 0.0244,
"hmin": 0,
"vmax": 0.08,
"vmin": 0
"hmax": 0.05,
"hmin": 0,
"vmax": 0.0417,
"vmin": 0
"hmax": 0.05,
"hmin": 0,
"vmax": 0.0833,
"vmin": 0.0417
"hmax": 0.05,
"hmin": 0,
"vmax": 0.125,
"vmin": 0.0833
"hmax": 0.05,
"hmin": 0,
"vmax": 0.1667,
"vmin": 0.125
"hmax": 0.05,
"hmin": 0,
"vmax": 0.2083,
"vmin": 0.1667
"hmax": 0.05,
"hmin": 0,
"vmax": 0.25,
"vmin": 0.2083
"hmax": 0.05,
"hmin": 0,
"vmax": 0.2917,
"vmin": 0.25
"hmax": 0.05,
"hmin": 0,
"vmax": 0.3333,
"vmin": 0.2917
"hmax": 0.05,
"hmin": 0,
"vmax": 0.375,
"vmin": 0.3333
"hmax": 0.05,
"hmin": 0,
"vmax": 0.4167,
"vmin": 0.375
"hmax": 0.05,
"hmin": 0,
"vmax": 0.4583,
"vmin": 0.4167
"hmax": 0.05,
"hmin": 0,
"vmax": 0.5,
"vmin": 0.4583
"hmax": 0.05,
"hmin": 0,
"vmax": 0.5417,
"vmin": 0.5
"hmax": 0.05,
"hmin": 0,
"vmax": 0.5833,
"vmin": 0.5417
"hmax": 0.05,
"hmin": 0,
"vmax": 0.625,
"vmin": 0.5833
"hmax": 0.05,
"hmin": 0,
"vmax": 0.6667,
"vmin": 0.625
"hmax": 0.05,
"hmin": 0,
"vmax": 0.7083,
"vmin": 0.6667
"hmax": 0.05,
"hmin": 0,
"vmax": 0.75,
"vmin": 0.7083
"hmax": 0.05,
"hmin": 0,
"vmax": 0.7917,
"vmin": 0.75
"hmax": 0.05,
"hmin": 0,
"vmax": 0.8333,
"vmin": 0.7917
"hmax": 0.05,
"hmin": 0,
"vmax": 0.875,
"vmin": 0.8333
"hmax": 0.05,
"hmin": 0,
"vmax": 0.9167,
"vmin": 0.875
"hmax": 0.05,
"hmin": 0,
"vmax": 0.9583,
"vmin": 0.9167
"hmax": 0.05,
"hmin": 0,
"vmax": 1,
"vmin": 0.9583
"hmax": 0.0244,
"hmin": 0,
"vmax": 1,
"vmin": 0.92
"hmax": 0.0488,
"hmin": 0.0244,
"vmax": 1,
"vmin": 0.92
"hmax": 0.0732,
"hmin": 0.0488,
"vmax": 1,
"vmin": 0.92
"hmax": 0.0976,
"hmin": 0.0732,
"vmax": 1,
"vmin": 0.92
"hmax": 0.122,
"hmin": 0.0976,
"vmax": 1,
"vmin": 0.92
"hmax": 0.1463,
"hmin": 0.122,
"vmax": 1,
"vmin": 0.92
"hmax": 0.1707,
"hmin": 0.1463,
"vmax": 1,
"vmin": 0.92
"hmax": 0.1951,
"hmin": 0.1707,
"vmax": 1,
"vmin": 0.92
"hmax": 0.2195,
"hmin": 0.1951,
"vmax": 1,
"vmin": 0.92
"hmax": 0.2439,
"hmin": 0.2195,
"vmax": 1,
"vmin": 0.92
"hmax": 0.2683,
"hmin": 0.2439,
"vmax": 1,
"vmin": 0.92
"hmax": 0.2927,
"hmin": 0.2683,
"vmax": 1,
"vmin": 0.92
"hmax": 0.3171,
"hmin": 0.2927,
"vmax": 1,
"vmin": 0.92
"hmax": 0.3415,
"hmin": 0.3171,
"vmax": 1,
"vmin": 0.92
"hmax": 0.3659,
"hmin": 0.3415,
"vmax": 1,
"vmin": 0.92
"hmax": 0.3902,
"hmin": 0.3659,
"vmax": 1,
"vmin": 0.92
"hmax": 0.4146,
"hmin": 0.3902,
"vmax": 1,
"vmin": 0.92
"hmax": 0.439,
"hmin": 0.4146,
"vmax": 1,
"vmin": 0.92
"hmax": 0.4634,
"hmin": 0.439,
"vmax": 1,
"vmin": 0.92
"hmax": 0.4878,
"hmin": 0.4634,
"vmax": 1,
"vmin": 0.92
"logger": {
"level": "warn"
"network": {
"apiAuth": true,
"internetAccessAPI": false,
"ipWhitelist": [],
"localAdminAuth": true,
"localApiAuth": false,
"restirctedInternetAccessAPI": false
"protoServer": {
"enable": true,
"port": 19445,
"timeout": 5
"smoothing": {
"continuousOutput": true,
"enable": true,
"time_ms": 200,
"type": "linear",
"updateDelay": 0,
"updateFrequency": 25
"webConfig": {
"crtPath": "",
"document_root": "",
"keyPassPhrase": "",
"keyPath": "",
"port": 8090,
"sslPort": 8092
sorry, i don’t know how to insert the file: /
Re-reset and installation. What am I doing wrong ??
sudo apt-get update && sudo apt-get dist-upgrade
cd hyperion-vero4k
sudo ./install.sh
This time installing from a binary
sudo systemctl start hyperion.service
sudo systemctl enable hyperion.service
I have access to web-gui
And thAnd the effect is this … a few LEDs on the top and on the left are lit.e effect is this … a few LEDs on the top and on the left are lit.
what am i doing wrong ??
This does sound like a configuration problem now. If Hyperion wasn’t compiled properly you wouldn’t get any USB output.
Some of these kits have some odd LED strips that require specific configuration.
Did they all work previously?
A darker room would help the photo. And an image with some bold colours as a test pattern to see what should be displayed where.
Yes the led strips worked fine, I had no trouble with them
this is what the menu looks like (without graber)
interestingly, the video looks like this (ok?)
after enabling the Enable USB capture grabber option,
the backlight disappears on vero (no matter if the image from an external device is fed or not). After switching the source to ps4, the backlight is but very faint
(after switching off ps4 and going to vero, the backlight is missing)
Sorry, I’m confused that you have USB grabbing available. I thought you were using the builtin grabber and driving a the LEDs over USB. What exactly is the layout of this Lightberry setup?
Right, so looking at the manual you are basically using an external USB grabber in one port and some sort of LED driver over the other USB port. Some basic rainbow type test images or starkly coloured video would make things more obvious, but it looks like things work ok when you are using the internal AML-grabber for Kodi playback.
When it’s the internal framebuffer-grabber for the menus the LEDs then aren’t mapped properly.
If you are using the external grabber the colour level is very low (I assume the PS4 was showing an all red screen for some reason? Not a great test image for working out mapping problems).
The missing lights when you go back to the Vero I assume are because you are still using the external USB grabber, so there are no colours to map?
When you say things worked ok before, what was the setup difference? Is this since updating from Stretch to Buster? New Vero?
Again, seeing the output from hyperiond --debug as you make these changes might give a clue as to what it is trying to do.
Also, in the setting image the hardware LED count was set to 1. That should 129 based upon your other images.
2020-11-15T00:16:22.185 hyperiond MAIN : Set user data path to ‘/home/osmc/.hyperion’
2020-11-15T00:16:22.252 hyperiond DAEMON : PythonInit.cpp:44:PythonInit() | Initializing Python interpreter
2020-11-15T00:16:22.349 hyperiond SETTINGSMGR : SettingsManager.cpp:107:SettingsManager() | Settings database initialized
2020-11-15T00:16:22.349 hyperiond DAEMON : The CEC handler can not be instantiated, because it has been left out from the build
2020-11-15T00:16:22.360 hyperiond EFFECTFILES : 39 effects loaded from directory :/effects/
2020-11-15T00:16:22.366 hyperiond EFFECTFILES : 22 effect schemas loaded from directory :/effects/schema/
2020-11-15T00:16:22.366 hyperiond EFFECTFILES : 0 effects loaded from directory /home/osmc/.hyperion/custom-effects
2020-11-15T00:16:22.403 hyperiond SETTINGSMGR : SettingsManager.cpp:107:SettingsManager() | Settings database initialized
2020-11-15T00:16:22.406 hyperiond BLACKBORDER : BlackBorderProcessor.cpp:64:handleSettingsUpdate() | Set mode to: default
2020-11-15T00:16:22.407 hyperiond COMPONENTREG : ComponentRegister.cpp:36:setNewComponentState() | Blackborder detector: enabled
2020-11-15T00:16:22.472 hyperiond DAEMON : set screen capture device to ‘amlogic’
2020-11-15T00:16:22.472 hyperiond AMLOGICGRABB : Grabber.cpp:30:setVideoMode() | Set videomode to 0
2020-11-15T00:16:22.472 hyperiond FRAMEBUFFERG : Grabber.cpp:30:setVideoMode() | Set videomode to 0
2020-11-15T00:16:22.472 hyperiond FRAMEBUFFERG : Display opened with resolution: 1920x1080@32bit
2020-11-15T00:16:22.473 hyperiond AMLOGICGRABB : AmlogicGrabber.cpp:31:AmlogicGrabber() | constructed(160 x 160), grabber device: /dev/amvideocap0
2020-11-15T00:16:22.473 hyperiond DAEMON : AMLOGIC grabber created
2020-11-15T00:16:22.473 hyperiond V4L2:AUTO : Grabber.cpp:30:setVideoMode() | Set videomode to 0
2020-11-15T00:16:22.474 hyperiond V4L2:AUTO : Signal threshold set to: {12, 12, 12}
2020-11-15T00:16:22.475 hyperiond V4L2:AUTO : Signal detection is now disabled
2020-11-15T00:16:22.475 hyperiond V4L2:AUTO : Signal detection area set to: 0.250000,0.250000 x 0.750000,0.750000
2020-11-15T00:16:22.475 hyperiond DAEMON : hyperiond.cpp:568:handleSettingsUpdate() | V4L2 grabber created
2020-11-15T00:16:22.476 hyperiond JSONSERVER : JsonServer.cpp:28:JsonServer() | Created instance
2020-11-15T00:16:22.477 hyperiond JSONSERVER : Started on port 19444
2020-11-15T00:16:22.478 hyperiond FLATBUFSERVE : Started on port 19400
2020-11-15T00:16:22.478 hyperiond PROTOSERVER : Started on port 19445
2020-11-15T00:16:22.479 hyperiond WEBSERVER : WebServer.cpp:33:initServer() | Initialize Webserver
2020-11-15T00:16:22.494 hyperiond LEDDEVICE : Start LedDevice ‘adalight’.
2020-11-15T00:16:22.494 hyperiond LEDDEVICE : LedDevice.cpp:147:init() | deviceConfig: [{“colorOrder”:“bgr”,“currentLedCount”:129,“delayAfterConnect”:0,“hardwareLedCount”:129,“latchTime”:30,“lightberry_apa102_mode”:true,“output”:"/dev/ttyACM0",“rate”:500000,“rewriteTime”:1000,“type”:“adalight”}]
2020-11-15T00:16:22.494 hyperiond COMPONENTREG : ComponentRegister.cpp:36:setNewComponentState() | Smoothing: enabled
2020-11-15T00:16:22.494 hyperiond LEDDEVICE : LedDevice.cpp:404:setLatchTime() | LatchTime updated to 30ms
2020-11-15T00:16:22.494 hyperiond LEDDEVICE : LedDevice.cpp:424:setRewriteTime() | Refresh interval = 1000ms
2020-11-15T00:16:22.495 hyperiond LEDDEVICE : LedDevice.cpp:430:setRewriteTime() | RewriteTime updated to 1000ms
2020-11-15T00:16:22.495 hyperiond LEDDEVICE : ProviderRs232.cpp:36:init() | DeviceType : adalight
2020-11-15T00:16:22.495 hyperiond LEDDEVICE : ProviderRs232.cpp:37:init() | LedCount : 129
2020-11-15T00:16:22.495 hyperiond LEDDEVICE : ProviderRs232.cpp:38:init() | ColorOrder : bgr
2020-11-15T00:16:22.495 hyperiond LEDDEVICE : ProviderRs232.cpp:39:init() | RefreshTime : 1000
2020-11-15T00:16:22.496 hyperiond LEDDEVICE : ProviderRs232.cpp:40:init() | LatchTime : 30
2020-11-15T00:16:22.496 hyperiond LEDDEVICE : ProviderRs232.cpp:52:init() | deviceName : ttyACM0
2020-11-15T00:16:22.496 hyperiond LEDDEVICE : ProviderRs232.cpp:53:init() | AutoDevice : 0
2020-11-15T00:16:22.496 hyperiond LEDDEVICE : ProviderRs232.cpp:54:init() | baudRate_Hz : 500000
2020-11-15T00:16:22.496 hyperiond FLATBUFCONN : Connecting to Hyperion: 127.0.0.1:19401
2020-11-15T00:16:22.496 hyperiond LEDDEVICE : ProviderRs232.cpp:55:init() | delayAfCon ms: 0
2020-11-15T00:16:22.497 hyperiond LEDDEVICE : LedDeviceAdalight.cpp:42:init() | Adalight driver with activated LightBerry APA102 mode
2020-11-15T00:16:22.497 hyperiond LEDDEVICE : LedDeviceAdalight.cpp:58:init() | Adalight header for 129 leds: Ada 0x00 0x81 0xd4
2020-11-15T00:16:22.497 hyperiond LEDDEVICE : Opening UART: ttyACM0
2020-11-15T00:16:22.497 hyperiond LEDDEVICE : ProviderRs232.cpp:141:tryOpen() | _rs232Port.open(QIODevice::ReadWrite): ttyACM0, Baud rate [500000]bps
2020-11-15T00:16:22.499 hyperiond EFFECTENGINE : Run effect “Rainbow swirl fast” on channel 0
2020-11-15T00:16:22.500 hyperiond EFFECTENGINE : EffectEngine.cpp:183:runEffectScript() | Start the effect: name [Rainbow swirl fast], smoothCfg [2]
2020-11-15T00:16:22.500 hyperiond HYPERION : PriorityMuxer.cpp:159:registerInput() | Register new input ‘System/EFFECT’ with priority 0 as inactive
2020-11-15T00:16:22.500 hyperiond HYPERION : Initial foreground effect ‘Rainbow swirl fast’ started
2020-11-15T00:16:22.502 hyperiond HYPERION : PriorityMuxer.cpp:159:registerInput() | Register new input ‘System/GRABBER’ with priority 250 as inactive
2020-11-15T00:16:22.502 hyperiond COMPONENTREG : ComponentRegister.cpp:36:setNewComponentState() | Framegrabber: enabled
2020-11-15T00:16:22.502 hyperiond AmLogic : GrabberWrapper.cpp:48:start() | Grabber start()
2020-11-15T00:16:22.503 hyperiond AMLOGICGRABB : FB mode
2020-11-15T00:16:22.503 hyperiond BOBLIGHT : BoblightServer.cpp:28:BoblightServer() | Instance created
2020-11-15T00:16:22.515 hyperiond WEBSERVER : WebServer.cpp:91:handleSettingsUpdate() | Apply Webserver settings
2020-11-15T00:16:22.515 hyperiond WEBSERVER : WebServer.cpp:109:handleSettingsUpdate() | Set document root to: :/webconfig
2020-11-15T00:16:22.516 hyperiond WEBSERVER : Started on port 8090 name ‘Hyperion Webserver’
2020-11-15T00:16:22.520 hyperiond WEBSERVER : WebServer.cpp:175:handleSettingsUpdate() | Setup SSL certificate
2020-11-15T00:16:22.520 hyperiond WEBSERVER : WebServer.cpp:191:handleSettingsUpdate() | Setup private SSL key
2020-11-15T00:16:22.521 hyperiond WEBSERVER : Started on port 8092 name ‘Hyperion Webserver’
2020-11-15T00:16:22.538 hyperiond LEDDEVICE : ProviderRs232.cpp:146:tryOpen() | portName: ttyACM0
2020-11-15T00:16:22.538 hyperiond LEDDEVICE : ProviderRs232.cpp:147:tryOpen() | systemLocation: /dev/ttyACM0
2020-11-15T00:16:22.539 hyperiond LEDDEVICE : ProviderRs232.cpp:148:tryOpen() | description: Arduino Leonardo
2020-11-15T00:16:22.539 hyperiond LEDDEVICE : ProviderRs232.cpp:149:tryOpen() | manufacturer: Arduino LLC
2020-11-15T00:16:22.539 hyperiond LEDDEVICE : ProviderRs232.cpp:150:tryOpen() | productIdentifier: 0x8036
2020-11-15T00:16:22.539 hyperiond LEDDEVICE : ProviderRs232.cpp:151:tryOpen() | vendorIdentifier: 0x2341
2020-11-15T00:16:22.540 hyperiond LEDDEVICE : ProviderRs232.cpp:152:tryOpen() | serialNumber:
2020-11-15T00:16:22.541 hyperiond COMPONENTREG : ComponentRegister.cpp:36:setNewComponentState() | LED device: enabled
2020-11-15T00:16:22.556 hyperiond HYPERION : PriorityMuxer.cpp:238:setInputImage() | Priority 250 is now active
2020-11-15T00:16:22.556 hyperiond HYPERION : Hyperion instance ‘First LED Hardware instance’ has been started
2020-11-15T00:16:22.556 hyperiond HYPERION : PriorityMuxer.cpp:333:setCurrentTime() | Set visible priority to 0
2020-11-15T00:16:22.556 hyperiond HYPERION : Hyperion.cpp:538:handlPriorityChangedLedDevice() | priority[0], previousPriority[255]
2020-11-15T00:16:22.556 hyperiond HYPERION : Hyperion.cpp:548:handlPriorityChangedLedDevice() | new source available -> switch LED-Device on
“No carrier”
2020-11-15T00:16:22.611 hyperiond HYPERION : PriorityMuxer.cpp:238:setInputImage() | Priority 0 is now active
2020-11-15T00:16:25.587 hyperiond WEBSOCKET : WebSocketClient.cpp:30:WebSocketClient() | New connection from ::ffff:192.168.178.3
2020-11-15T00:16:25.587 hyperiond WEBSOCKET : JsonAPI.cpp:81:handleInstanceSwitch() | Client ‘::ffff:192.168.178.3’ switch to Hyperion instance 0
2020-11-15T00:16:25.700 hyperiond HYPERION : PriorityMuxer.cpp:298:setCurrentTime() | Timeout clear for priority 0
2020-11-15T00:16:25.950 hyperiond HYPERION : PriorityMuxer.cpp:333:setCurrentTime() | Set visible priority to 250
2020-11-15T00:16:25.951 hyperiond HYPERION : Hyperion.cpp:538:handlPriorityChangedLedDevice() | priority[250], previousPriority[0]
“No carrier”
“No carrier”
2020-11-15T00:16:46.699 hyperiond AMLOGICGRABB : VPU mode
2020-11-15T00:16:46.718 hyperiond AMLOGICGRABB : Read of device failed: 61 - No data available
“No carrier”
“No carrier”
“No carrier”
“No carrier”
2020-11-15T00:17:30.531 hyperiond AMLOGICGRABB : Previous line repeats 1 times
2020-11-15T00:17:30.534 hyperiond AMLOGICGRABB : FB mode
“No carrier”
“No carrier”
“No carrier”
“No carrier”
indent preformatted text by 4 spaces
