Osmc and lighttpd?
ok
i’ve just installed osmc and want to know if it is possible to rub lighttpd on it together with other network applications…
let me know that
do i use the default webserver of kodi? or can i just use the lighttpd?
Yes, go and try! I had it installed for tests. As Kodi has its http port configured to 8080, you should have no problems reaching your additional Server on 80. But you could also hack yourself into configuring Apache to save resources. What are you planing to achive?
I think i read in some thread that Kodi now runs on port 80
Here is the thread.
Just change Kodi to a different port if you want lighty on 80
S
