OSMC and Odroid C1+
Hi OSMC people !
I need your help.
So far, I’m using an RPi2 and OSMC and all is good.
But I just bought an Odroid C1+ and I wanted to test OSMC on it.
But I don’t know if there is a special OSMC for it or the RPi2 install is good for that…
Anyone can help me, please ?!
Thanks in advance :slight_smile:
OSMC won’t run on an Odroid C1+
Oh no :’(
Thanks for your quick answer Sam !
How much different is Vero 2 (running on S805) from ODROID c1+? Clearly, there are some peripherals included in the Vero2 that is missing in the C1+, but the SOC is the same. Would be nice, if a ‘side’ effect of Vero2 would be that C1+ would also get some very limited support.
Unfortunately, it’s quite different (especially with the U-Boot process). You’d need to unify the kernel (for a similar experience) which isn’t trivial
I don’t have a C1 (and I’m not sure of any developers with one), but I’m not ruling this out in the future. I’ve also seen a lot of community work on OSMC lately; someone might even beat us to the mark.
Isnt ODroid allwinner SOC ?
it’s definitely amlogic: http://www.hardkernel.com/main/products/prdt_info.php?g_code=G143703355573&tab_idx=2
