I know OSMC is based on Debian Jessie and has all the optimizations for the Pi 2. This makes it the best base for Kodi for Pi 2… but… I am wondering about doing more with it.
I’d rather be inside of RetroPie at the start and then select either Kodi, XYZ System to Emulate or Desktop or Steam Streaming. I think I’d like OSMC as the base OS so some questions I hope you (or someone else) can help with:
Can you add a Desktop to OSMC? I recall you could with Raspbmc so I suspect yes. As simple as sudo apt-get install XXX ??
Can you stop OSMC from loading Kodi on startup and load RetroPie’s EmulationStation instead? Presumably editting a startup script?
Thanks again for Raspbmc (glad I donated!) and for OSMC.
Managed to setup and start a very basic Desktop (without browser & pi store & almost everything else). Still looking for a way to install the stock Raspbian browser at least.
Also, I’ve found that with LXDE installed in OSMC, epiphany-browser doesn’t work, at least on RPi 1. Iceweasel works, but it’s slow without hardware acceleration
Pi Store doesn’t work though… Maybe it has something to do with OSMC being on Jessie.
