I’m trying to play the music from a USB key attached to the Pi via OSMC + Bluetooth Dongle + Bluetooth Speaker.
What I have so far: USB Dongle paired and connected. “Ding sound” played on Speaker and bluetoothtcl shows that everyting is OK.
In the Systems/Audio settings I’ve selected the “Pulse Audio Server” option, however when I start the music the Pi just hangs, and is unable to play the music. This is what I get when I list the sinks:
Could anyone give me some pointers what I should look into/fix/do to get it play music from the Pi? (Please note, that I don’t care about streaming music to the Pi via my phone, I just want the Pi to output music to the bluetooth speaker via the USB key. Any help would be appreciated.
root@osmc:/etc/pulse# pactl list sinks
Sink #0
State: SUSPENDED
Description: bcm2835 ALSA Analog Stereo
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 44100Hz
Channel Map: front-left,front-right
Owner Module: 6
Mute: no
Volume: front-left: 26090 / 40% / -24.00 dB, front-right: 26090 / 40% / -24.00 dB
balance 0.00
Base Volume: 56210 / 86% / -4.00 dB
Monitor Source: alsa_output.0.analog-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = “16”
device.api = “alsa”
device.class = “sound”
alsa.class = “generic”
alsa.subclass = “generic-mix”
alsa.name = “bcm2835 ALSA”
alsa.id = “bcm2835 ALSA”
alsa.subdevice = “0”
alsa.subdevice_name = “subdevice #0”
alsa.device = “0”
alsa.card = “0”
alsa.card_name = “bcm2835 ALSA”
alsa.long_card_name = “bcm2835 ALSA”
device.bus_path = “/devices/virtual/sound/card0”
sysfs.path = “/devices/virtual/sound/card0”
device.string = “hw:0”
device.buffering.buffer_size = “65536”
device.buffering.fragment_size = “65536”
device.access_mode = “mmap+timer”
device.profile.name = “analog-stereo”
device.profile.description = “Analog Stereo”
device.description = “bcm2835 ALSA Analog Stereo”
alsa.mixer_name = “Broadcom Mixer”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card”
Ports:
analog-output: Analog Output (priority: 9900)
Active Port: analog-output
Formats:
pcm
Sink #1
State: SUSPENDED
Description: AMETHYST M1
Driver: module-bluez5-device.c
Owner Module: 23
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: bluez_sink.00_11_86_00_12_38.monitor
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
bluetooth.protocol = “a2dp_sink”
device.description = “AMETHYST M1”
device.string = “00:11:86:00:12:38”
device.api = “bluez”
device.bus = “bluetooth”
device.form_factor = “headset”
bluez.path = “/org/bluez/hci0/dev_00_11_86_00_12_38”
bluez.class = “0x240404”
bluez.alias = “AMETHYST M1”
device.icon_name = “audio-headset-bluetooth”
device.intended_roles = “phone”
Ports:
headset-output: Headset (priority: 0)
Active Port: headset-output
Formats:
pcm
