Good question. I do not have the MPEG2 license pack.
You can find my logs here: https://paste.osmc.tv/oloqomekop
One more bit I just discovered. The above log ends when ffmpeg returns an error saying the decoding for stream 0 failed. When I play the same video on the firestick with the same DVR client, I see the same error in the log, but then the log continues and the file actually plays successfully. (see below for log excerpt from the firestick kodi log). Not sure if this will help or not…but it looks like the error in OSMC is treated as a fatal one, while on the firestick some type of recovery allows the file to actually play.
Thanks for looking into this.
firestick log excerpt:
20:56:53.698 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [h264] SPS unavailable in decode_picture_timing
20:56:53.699 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [h264] non-existing PPS 0 referenced
20:56:53.699 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [h264] SPS unavailable in decode_picture_timing
20:56:53.700 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [h264] non-existing PPS 0 referenced
20:56:53.700 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [h264] decode_slice_header error
20:56:53.700 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [h264] no frame!
20:56:53.701 T:18446744072510105880 INFO: ffmpeg[B881E918]: [mpegts] decoding for stream 0 failed
20:56:53.792 T:18446744072510105880 DEBUG: ffmpeg[B881E918]: [mpegts] Could not find codec parameters for stream 0 (Video: h264 ([27][0][0][0] / 0x001B), none): unspecified size
20:56:53.807 T:18446744072510105880 DEBUG: ffmpeg[B881E918]: [mpegts] Consider increasing the value for the ‘analyzeduration’ and ‘probesize’ options
20:56:53.807 T:18446744072510105880 DEBUG: Open - av_find_stream_info finished
20:56:53.808 T:18446744072510105880 INFO: ffmpeg[B881E918]: Input #0, mpegts, pvr://recordings/tv/active/Bull/Bull s02e05 (2017)%20Play%20the%20Hand%20You%27re%20Dealt, TV%20(WWTVDT), 20171025_005900, http://192.168.88.11:1039/recorded/cmd?id=27d9ff52.pv’:
20:56:53.809 T:18446744072510105880 INFO: ffmpeg[B881E918]: Duration: 01:02:00.51, start: 86045.185611, bitrate: 3437 kb/s
20:56:53.809 T:18446744072510105880 INFO: ffmpeg[B881E918]: Program 3
20:56:53.811 T:18446744072510105880 INFO: ffmpeg[B881E918]: Stream #0:0[0x31]: Video: h264 ([27][0][0][0] / 0x001B), none, 29.97 fps, 29.97 tbr, 90k tbn, 180k tbc
20:56:53.812 T:18446744072510105880 INFO: ffmpeg[B881E918]: Stream #0:10x34: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/s
20:56:53.813 T:18446744072510105880 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 0
20:56:53.813 T:18446744072510105880 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 1
20:56:53.836 T:18446744072510105880 NOTICE: Opening stream: 0 source: 256
20:56:53.836 T:18446744072510105880 NOTICE: Creating video codec with codec id: 28
20:56:53.837 T:18446744072510105880 DEBUG: FactoryCodec - Video: mediacodec - Opening
20:56:53.837 T:18446744072510105880 ERROR: CDVDVideoCodecAndroidMediaCodec::Open - null size, cannot handle
20:56:53.838 T:18446744072510105880 DEBUG: FactoryCodec - Video: mediacodec - Failed
20:56:53.838 T:18446744072510105880 DEBUG: FactoryCodec - Video: - Opening
20:56:53.838 T:18446744072510105880 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:56:53.839 T:18446744072510105880 DEBUG: CDVDVideoCodecFFmpeg - open frame threaded with 6 threads
20:56:53.842 T:18446744072510105880 DEBUG: CDVDVideoCodecFFmpeg - Updated codec: ff-h264
20:56:53.843 T:18446744072510105880 DEBUG: FactoryCodec - Video: ff-h264 - Opened
20:56:53.843 T:18446744072510105880 DEBUG: CVideoPlayerVideo::OpenStream - open stream with codec id: 28
20:56:53.844 T:18446744072510105880 NOTICE: Creating video thread
20:56:53.844 T:18446744072510105880 NOTICE: Opening stream: 1 source: 256
20:56:53.846 T:18446744072510105880 NOTICE: Finding audio codec for: 86019
20:56:53.846 T:18446744072510105880 DEBUG: FactoryCodec - Audio: passthrough - Opening
20:56:53.847 T:18446744072510105880 DEBUG: FactoryCodec - Audio: passthrough - Failed
20:56:53.847 T:18446744072510105880 DEBUG: FactoryCodec - Audio: FFmpeg - Opening
20:56:53.849 T:18446744072510105880 DEBUG: FactoryCodec - Audio: FFmpeg - Opened
20:56:53.850 T:18446744072501604352 DEBUG: Thread VideoPlayerVideo start, auto delete: false
20:56:53.851 T:18446744072501604352 NOTICE: running thread: video_thread
20:56:53.851 T:18446744072510105880 NOTICE: Creating audio thread
20:56:53.852 T:18446744072503675208 DEBUG: Thread VideoPlayerAudio start, auto delete: false
20:56:53.852 T:18446744072503675208 NOTICE: running thread: CVideoPlayerAudio::Process()
20:56:53.853 T:18446744072510105880 DEBUG: ReadEditDecisionLists - Checking for edit decision list (EDL) for PVR recording: pvr://recordings/tv/active/Bull/Bull s02e05 (2017)%20Play%20the%20Hand%20You%27re%20Dealt, TV%20(WWTVDT), 20171025_005900, http://192.168.88.11:1039/recorded/cmd?id=27d9ff52.pvr
20:56:53.855 T:18446744072510105880 DEBUG: ReadPvr - Reading Edl for recording: Bull
20:56:53.856 T:18446744072510105880 DEBUG: OnPlayBackStarted: play state was 1, starting 1
20:56:53.856 T:18446744072490565648 DEBUG: PlayFile: OpenFile succeed, play state 2
20:56:53.856 T:18446744072490565648 DEBUG: OnPlayBackStarted: play state was 2, starting 0
20:56:53.857 T:18446744072510105880 DEBUG: CVideoPlayer::SetCaching - caching state 2
20:56:53.858 T:18446744072510105880 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
20:56:53.862 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.863 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.864 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.866 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.868 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.869 T:18446744072503675208 DEBUG: CDVDAudio::Pause - pausing audio stream
20:56:53.870 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.871 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.872 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.874 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.875 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.877 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.878 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.880 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.889 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.894 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.894 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.895 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.897 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.898 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.899 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.903 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.904 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.905 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.905 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.907 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.913 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.915 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.915 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.918 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.921 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.925 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.925 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.948 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.948 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.963 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.965 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.967 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.982 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.983 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.984 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.987 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.989 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:53.997 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:53.999 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.004 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.009 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.018 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.020 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.027 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.028 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.034 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.035 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.043 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.043 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.048 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.050 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.051 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.052 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.061 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.064 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.066 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.066 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.071 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.075 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.080 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.080 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.081 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.082 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.085 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.085 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.089 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.091 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.092 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.092 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.093 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.093 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.102 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.102 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.103 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.107 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.112 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.113 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.113 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.114 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.124 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.124 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.125 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.126 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.126 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.127 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.127 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.128 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.129 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.129 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.130 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.137 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.138 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.138 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.140 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] SPS unavailable in decode_picture_timing
20:56:54.140 T:18446744072510105880 ERROR: ffmpeg[B881E918]: [NULL] non-existing PPS 0 referenced
20:56:54.142 T:18446744072510105880 DEBUG: CDVDDemuxFFmpeg::Read() fetching extradata, extradata_size(57)
20:56:54.198 T:18446744072492252008 DEBUG: CGUIInfoManager::SetCurrentMovie(pvr://recordings/tv/active/Bull/Bull s02e05 (2017)%20Play%20the%20Hand%20You%27re%20Dealt, TV%20(WWTVDT), 20171025_005900, http://192.168.88.11:1039/recorded/cmd?id=27d9ff52.pvr)
20:56:54.258 T:18446744072510105880 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 0
20:56:54.260 T:18446744072510105880 NOTICE: Opening stream: 0 source: 256
20:56:54.260 T:18446744072510105880 NOTICE: Creating video codec with codec id: 28
20:56:54.261 T:18446744072510105880 DEBUG: FactoryCodec - Video: mediacodec - Opening
20:56:54.261 T:18446744072510105880 INFO: CBitstreamConverter::Open Invalid avcC
20:56:54.277 T:18446744072490578216 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
20:56:54.277 T:18446744072490578216 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
20:56:54.662 T:18446744072510105880 DEBUG: CDVDVideoCodecAndroidMediaCodec::Open m_codecname(OMX.MTK.VIDEO.DECODER.AVC), colorFormat(19)
20:56:54.663 T:18446744072510105880 DEBUG: CDVDVideoCodecAndroidMediaCodec::Open m_codecname(OMX.MTK.VIDEO.DECODER.AVC), colorFormat(2135033992)
20:56:54.663 T:18446744072510105880 DEBUG: CDVDVideoCodecAndroidMediaCodec::Open m_codecname(OMX.MTK.VIDEO.DECODER.AVC), colorFormat(2130706433)
20:56:54.718 T:18446744072510105880 DEBUG: CDVDVideoCodecAndroidMediaCodec:: width(1280), height(540), stride(0), slice-height(0), color-format(0)
20:56:54.718 T:18446744072510105880 DEBUG: CDVDVideoCodecAndroidMediaCodec:: crop-left(0), crop-top(0), crop-right(0), crop-bottom(0)
20:56:54.718 T:18446744072510105880 DEBUG: CDVDVideoCodecAndroidMediaCodec:: Multi-Surface Rendering
20:56:54.718 T:18446744072510105880 INFO: CDVDVideoCodecAndroidMediaCodec:: Open Android MediaCodec OMX.MTK.VIDEO.DECODER.AVC
20:56:54.719 T:18446744072510105880 DEBUG: FactoryCodec - Video: amc-h264 - Opened
20:56:54.719 T:18446744072510105880 NOTICE: Opening stream: 1 source: 256
20:56:54.720 T:18446744072501604352 DEBUG: CVideoPlayerVideo::OpenStream - open stream with codec id: 28
20:56:54.725 T:18446744072501604352 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0
20:56:54.725 T:18446744072501604352 DEBUG: CDVDVideoCodecAndroidMediaCodec::virtual void CDVDVideoCodecAndroidMediaCodec::SetCodecControl(int) 0->4000000
20:56:54.727 T:18446744072501604352 DEBUG: CDVDVideoCodecAndroidMediaCodec::Decode current state (2)
20:56:54.735 T:18446744072503675208 NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, no pass-through)
20:56:54.738 T:18446744072503675208 DEBUG: CVideoPlayerAudio:: synctype set to 0: clock feedback
20:56:54.744 T:18446744072510105880 NOTICE: Opening stream: 0 source: 256
20:56:54.745 T:18446744072510105880 NOTICE: Opening stream: 1 source: 256
20:56:54.745 T:18446744072510105880 NOTICE: Opening stream: 1 source: 1280
20:56:54.745 T:18446744072510105880 DEBUG: FactoryCodec - Overlay: Text Subtitle Decoder - Opening
20:56:54.746 T:18446744072510105880 DEBUG: FactoryCodec - Overlay: Text Subtitle Decoder - Opened
20:56:54.752 T:18446744072501604352 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0
20:56:54.884 T:18446744072492318824 DEBUG: Previous line repeats 8 times.
20:56:54.885 T:18446744072492318824 INFO: CActiveAESink::OpenSink - initialize sink
20:56:54.885 T:18446744072492318824 DEBUG: Draining Audio
20:56:54.891 T:18446744072492318824 DEBUG: CActiveAESink::OpenSink - trying to open device AUDIOTRACK:AudioTrack
20:56:54.892 T:18446744072492318824 DEBUG: CAESinkAUDIOTRACK::Initialize requested: sampleRate 48000; format: AE_FMT_FLOATP; channels: 2
20:56:54.892 T:18446744072492318824 DEBUG: Updated SampleRate: 32000 Distance: 144000
20:56:54.893 T:18446744072492318824 DEBUG: Updated SampleRate: 44100 Distance: 35100
20:56:54.893 T:18446744072492318824 DEBUG: Updated SampleRate: 48000 Distance: 0
20:56:54.893 T:18446744072492318824 NOTICE: Trying to open: 48000 samplerate 12 channelMask 4 encoding
20:56:54.896 T:18446744072492318824 DEBUG: Minimum size we need for stream: 32768
20:56:54.897 T:18446744072492318824 DEBUG: Created Audiotrackbuffer with playing time of 170.666667 ms min buffer size: 65536 bytes
20:56:54.968 T:18446744072492318824 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 48000 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 65536 m_frames: 4096 m_frameSize: 8 channels: 2
20:56:54.968 T:18446744072492318824 DEBUG: CActiveAESink::OpenSink - AUDIOTRACK Initialized:
20:56:54.968 T:18446744072492318824 DEBUG: Output Device : android
20:56:54.973 T:18446744072492318824 DEBUG: Sample Rate : 48000
20:56:54.973 T:18446744072492318824 DEBUG: Sample Format : AE_FMT_FLOAT
20:56:54.975 T:18446744072492318824 DEBUG: Channel Count : 2
20:56:54.975 T:18446744072492318824 DEBUG: Channel Layout: FL,FR
20:56:54.977 T:18446744072492318824 DEBUG: Frames : 4096
20:56:54.977 T:18446744072492318824 DEBUG: Frame Size : 8
20:56:55.000 T:18446744072492294600 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
20:56:55.011 T:18446744072501604352 DEBUG: Previous line repeats 1 times.
20:56:55.011 T:18446744072501604352 DEBUG: CDVDVideoCodecAndroidMediaCodec:: width(1280), height(540), stride(1280), slice-height(544), color-format(2130706433)
20:56:55.012 T:18446744072501604352 DEBUG: CDVDVideoCodecAndroidMediaCodec:: crop-left(0), crop-top(0), crop-right(1279), crop-bottom(539)
20:56:55.012 T:18446744072501604352 DEBUG: CDVDVideoCodecAndroidMediaCodec:: Multi-Surface Rendering
20:56:55.013 T:18446744072510105880 DEBUG: CVideoPlayer::HandleMessages - player started 1
20:56:55.024 T:18446744072501604352 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0
20:56:55.030 T:18446744072501604352 DEBUG: CRenderManager::Configure - change configuration. 1280x540. display: 960x540. framerate: 29.97. format: MEDIACODECSURFACE
20:56:55.041 T:18446744072490565648 DEBUG: DeleteRenderer - deleting renderer
20:56:55.042 T:18446744072490565648 DEBUG: LinuxRendererGL: Cleaning up GL resources
20:56:55.043 T:18446744072490565648 DEBUG: Previous line repeats 1 times.
20:56:55.044 T:18446744072490565648 NOTICE: Using GL_TEXTURE_2D
20:56:55.045 T:18446744072490565648 NOTICE: GL: Using MediaCodec (Surface) render method
20:56:55.046 T:18446744072490565648 NOTICE: GL: NPOT texture support detected
20:56:55.048 T:18446744072490565648 DEBUG: CLinuxRendererGLES: Reorder drawpoints due to method change from 1 to 2048
20:56:55.049 T:18446744072490565648 DEBUG: CRenderManager::Configure - 3
20:56:55.056 T:18446744072510105880 DEBUG: CVideoPlayer::HandleMessages - player started 2
20:56:55.057 T:18446744072510105880 DEBUG: CVideoPlayer::SetCaching - caching state 3
20:56:55.057 T:18446744072510105880 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
20:56:55.057 T:18446744072510105880 DEBUG: CVideoPlayer::SetCaching - caching state 0
20:56:55.058 T:18446744072510105880 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
20:56:55.058 T:18446744072510105880 DEBUG: VideoPlayer::Sync - Audio - pts: 2048000.000000, cache: 288000.017405, totalcache: 570666.670799
20:56:55.058 T:18446744072510105880 DEBUG: VideoPlayer::Sync - Video - pts: 2199466.000000, cache: 50000.000000, totalcache: 100000.000000
20:56:55.058 T:18446744072503675208 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_RESYNC(1759999.982595)
20:56:55.059 T:18446744072503675208 DEBUG: CDVDAudio::Resume - resume audio stream
20:56:55.060 T:18446744072501604352 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(1759999.982595)
20:56:55.072 T:18446744072501604352 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0
20:56:55.074 T:18446744072492294600 DEBUG: ActiveAE - start sync of audio stream
20:56:55.076 T:18446744072490565648 DEBUG: RenderUpdate: Dest - 0.000000+0.000000-1280.000000x720.000000
20:56:55.077 T:18446744072490565648 DEBUG: RenderUpdate: Adj - 0.000000+0.000000-1920.000000x1080.000000
20:56:55.091 T:18446744072501604352 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 1
20:56:55.095 T:18446744072501604352 DEBUG: CDVDVideoCodecAndroidMediaCodec::virtual void CDVDVideoCodecAndroidMediaCodec::SetCodecControl(int) 4000000->0
20:56:55.111 T:18446744072490565648 DEBUG: Activating window ID: 12005
20:56:55.111 T:18446744072490565648 DEBUG: ------ Window Deinit (MyPVRRecordings.xml) ------
20:56:55.113 T:18446744072490565648 DEBUG: ------ Window Init (VideoFullScreen.xml) ------
20:56:55.113 T:18446744072490565648 INFO: Loading skin file: VideoFullScreen.xml, load type: KEEP_IN_MEMORY
20:56:55.227 T:18446744072492294600 DEBUG: ActiveAE::SyncStream - average error of -95.049737, start adjusting
20:56:55.228 T:18446744072492294600 DEBUG: ActiveAE::SyncStream - average error -10.049737 below threshold of 30.000000
20:56:56.253 T:18446744072503675208 DEBUG: CDVDClock::ErrorAdjust - CVideoPlayerAudio::OutputPacket - error:-70587.226040, adjusted:-70587.226040
20:56:59.448 T:18446744072501604352 DEBUG: CPullupCorrection: detected pattern of length 1: 33366.67, frameduration: 33366.666667
20:57:01.846 T:18446744072490565648 DEBUG: Keyboard: scancode: 0x04, sym: 0x0008, unicode: 0x0000, modifier: 0x0
20:57:02.534 T:18446744072501604352 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:57:02.534 T:18446744072490565648 DEBUG: OnKey: long-backspace (0x100f008) pressed, action is Stop
20:57:02.558 T:18446744072490565648 NOTICE: CVideoPlayer::CloseFile()
20:57:02.558 T:18446744072490565648 NOTICE: VideoPlayer: waiting for threads to exit
