I seem to be unable to get the dongle running and connecting properly to a 5 ghz network. In the kernel log I found some error notifications apparently concerning mt7610u, but I am unable to make sense of them. Some logs are here:
At this point you should be able to establish a connection, if the connection speed is slower than expected; reverting to auto configuration should resolve this:
I tried this, and now the 2.5 ghz network seems to be working. But not so the 5 ghz network. As well, the error message in the dmesg output is still present.
I tried moving it to /lib/firmware/mt7610u_sta.dat and removing /var/lib/connman/wifi* again. After rebooting the osmc wifi config tool showed only 5 ghz networks and managed to connect to my 5 ghz network. But again, there was no working connection.
I can only confirm that the router is set to wpa2 but I couldn’t find out anything about the encryption method. As the router is fairly new (a German Telekom Speedport Smart with rather good WiFi, but a pretty poor user interface and documentation) I would expect it to use aes encryption. Also, I never had any issues with other linux systems, as long as I had the correct driver installed.
I tried wireless mode to 13 and 14 with and without setting the country code—no working 5ghz connection.
Meanwhile, I’m ready to install an ethernet connection. But anyway, if it seems to be useful, I’d happily continue to try to get the stick working with your help.
I would stick with the wired connection, I’m inclined to suspect the router is either presenting encryption as tkip/aes or tkip. If this is the case I think it will be a hard to get a 5ghz connection, unless this can be changed to aes only:
just to give some kind of a final feedback: In the meantime, I got my dLAN 1200+ WiFi ac and could establish a stable wired connection (even though it’s dlan). I tried to use the 5ghz wifi provided by the dlan device and it seemed to be stable.
Anyway, I’ll stick to the wired solution, of course.
