I have Pi B+ and install on it last OSMC .
I have some video files . These video are WebRIP-10bit-PSA-HEVAC.X265
but OSMC can not play these videos.
what I must do ?
Are they 1080p files?
This may be a bit of a struggle on Pi
No they are 720p
You may need a modest overclock to play them
I need another way help to solve this problem .
overclock maybe harm my Pi
I highly doubt Sam would suggest you do something that could harm your Pi
I think something like update or change config files , should solve the problem
Re-encoding your files to a supported format would be another way to go. H.264 is the preferred option I believe.
Read the FAQ on the Kodi site
https://kodi.wiki/view/Raspberry_Pi_FAQ
The Raspberry Pi can only partially accelerate hardware decoding for HEVC files.
Isn‘t it the perfect time for self-advertising, Vero?
Playing H265 files on a Pi just isn’t feasible. I had very little luck with a Pi3. The issue is hardware not software. Pi hardware is pretty useless for it. Your best bet is to use something like handbrake to re-encode to H264. This is what I did before finally upgrading to Vero4k rigs.
