I noticed from logs mediacenter crash/restart happened during early morning hours (06:40)… At the time my TV was switched off and i wasn’t using RPI2+OSMC. I cant say if this is the first time problem occured since i started debug logging some days ago.
My setup is:
osmc@osmc:~$ lsusb
Bus 001 Device 005: ID 0586:341f ZyXEL Communications Corp. NWD2205 802.11n Wireless N Adapter [Realtek RTL8192CU]
Bus 001 Device 004: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Power: USB Charger 5V 2.1A (never seen colourful block/rectangle at upper right corner)
Your log is covered in errors relating to unsupported repositories and addons. I suggest removing them and testing again. Then add back addons one at a time to see if you can figure out which one results in a crash.
Oct 13 12:37:59 osmc sudo[240]: pam_unix(sudo:session): session closed for user osmc
Oct 13 12:37:59 osmc mediacenter[217]: Kodi exited with return code 139 after 37 hours, 33 minutes and 56 seconds
Oct 13 12:37:59 osmc kernel: Console: switching to colour frame buffer device 154x46
From another post (sad face reboot loop) i saw similar return code 139 (seg fault?) but in my case i dont have any looping happenning
Any suggestion(s) how to debug this issue further to find the root cause ?
(I did remove problematic repository and as seen from the logs those ERROR messages are gone)
I’m on the latest stable realease and I can confirm that it happened a few times that when watching movie everything freeze and all I could do is take power cabel out and in again…
